Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series DIY
7 Series DIY
Do It Yourself forum dedicated for 7 Series BMW Owners
Closed Thread
Old 10-17-2009, 03:05 AM
07841-tb's Avatar
07841-tb 07841-tb is offline
Mein Auto: 02' BMW 745li & 04 Rover
DIY - Coolant pipe tools & procedure
Ok guys this is what is needed & how i did it. (NO LEAKS) Hope this makes any sense.
  • Tools needed:
  • metric torx socket set
  • metric inverted socket set
  • 27mm socket
  • air impact gun
  • harmonic balancer puller kit (rent @auto zone)
  • front engine support ( rent @ auto zone)
  • Magnet
  • Procedure:
  • Disconnect Battery
  • Remove hood (optional)
  • Jack up car & place on jack stands
  • Drain coolant & Freon
  • Remove radiator
  • Remove coolant resevoir
  • remove radiator hoses
  • Remove air filter box & hose
  • remove vibration damper pulley
  • remove water pump assembly
  • remove both belt tensioners
  • unbolt a/c compressor & set aside
  • un bolt p/s pum & set aside
  • Remove p/s resevoir
  • Remove the valvetronic motors, the big silver motors sticking out of the valve covers at the top of each. remove the four bolts & twist out.
    • unbolt the wire harness attached to the intake manifold. unplug all sensors & switches to this harness but mark all plugs & sensors.
    • Remove the intake manifold. (it has 5 nuts on each side)
    • remove the valve covers. ( remove the 2 sensors on the drivers side valve cover)Remove the body piece between the microfilters (above the back of the engine) early in the process will give you a lot of wiggle room on various items.
    • Support the engine w/ the engine support bar. (seen in picture)
    • Unbolt the driverside motor mount & bracket and set aside.
    • Remove the alternator & housing.
    • Remove the crankshaft bolt. very hard to remove it's torqed 250lbs. I used a 3/4 inch impact gun.
      Remove vibration damper hub w/ puller kit http://www.realoem.com/bmw/showparts...60&hg=11&fg=18
    • Remove the front oil pan bolts that attach to the timing cover
    • Remove upper timng covers.
    • Remove all bolts from lower timing cover.
    • NOW! use a nice flat head screwdriver or prybar and start sliding the timing cover forward.
    • There should not be any resistant when sliding the cover foward if so stop & find the problem.
    • Once the lower cover is removed your coolant pipe oring is exposed.
      • Remove the valley pan. Yuor coolant pipe will be visible.
      • slide the coolant pipe forward, (may be tight to move but just work it out).
      • once removed clean & prep all gasket surfaces.
    • Installation:
    • Slide new pipe and oring in carefully.
    • installl new valley pan.
    • NOW! Before we reinstall the lower cover inspect the oil pan gasket to make sure its not damaged and also both slightly exposed head gaskets (very slim chance of any damage but you always should check.
    • Place a small amount of black silcone in each corner wher the lower cover will be placed.
    • Very slow slide the lower cover in place w/o hitting the gaskets if successful reverse the procedure on all the remainig parts.
More questions feel free to call me @314-479-6659 PS. some people do remove the oil pan also to do this job but i did not & was successful. Thanks, Tommie B.
2002 BMW 745Li
2004 LAND ROVER RANGE ROVER HSE
Old 10-17-2009, 06:55 AM
mccabema mccabema is offline
Mein Auto: 2002 BMW 735i
Wow ! I don't need this right now but thank you so much. Its going to be invaluable when my time comes.
Any pictures by chance?
Old 10-17-2009, 08:18 AM
07841-tb's Avatar
YEP!
http://www.bimmerfest.com/forums/sho...453&highlight=
2002 BMW 745Li
Old 10-17-2009, 09:46 AM
msdallasbeamer msdallasbeamer is offline
Mein Auto: BMW
Hey I really want to Thank you for posting this. I am a female that have no clue about cars, but I knew for sure I wasn't about to pay 7565.00 to a BMW dealer to fix this. Apparently there is and should be some kind of recall with this coolant pipe. I recently had to replace water pump, upper and lower hoses, thermostat, and this was right after a coolant flush by the dealer. After the coolant flush and replacement of these parts, got home, and coolant was leaking in my garage, next day took it back and they claimingly stopped the leak and then the windshield wiper wlasn'tskeeting water under the car when you turned them on, took it back they told me I had to pay to replace the wiper motor when there was nothing wrong with when I brought it to them. Less than a week later the service engine light came on, I took it back again after having Auto Zone read the engine light and they told me a hose was disconnected, secondary air vacuum hose, or some hose was not connected to take it back, did spoke to manager and a female tech that had no clue. They told me that now this had nothing to do with what they did and it would be 1400 to replace, I insisted that they fix and it was not one trouble with my car until they touched my car. I really believe they clearly messed up something when they put the water pump in. However they are telling me the two parts have nothing to do with eachother. Someone else tells me they do. I am asking you are there some possibilities they did something wrong installing a Reman Water Pump in Could have affected this coolant pipe?
Old 10-17-2009, 10:31 AM
Keif Keif is offline
Master Tinkerer
Mein Auto: 2007 Alpina B7
On behalf of everyone, thank you very much for posting this! Even if some people don't do this themselves, they will surely still save a good bit of money at an indy shop or dealer knowing it can be done this way. Easily one of the most valuable posts on this board.
Black 2007 Alpina B7
Tension strut bushings
White 2007 Alpina B7
Supercharger clutch/bearings, replaced exhaust valve/pulled head, sunroof seal, 6000K angel eyes
Black 2002 BMW 745Li (sold)
KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator & mounting bracket gasket, sunroof seal, CCVs, plugs, sway bar bushings, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, sanded headlights...
Old 10-17-2009, 12:03 PM
johndade johndade is offline
Mein Auto: 2002 bmw 745li
Excellent write up. If i ever have that problem i still wont be able to do that type work myself.
Old 10-17-2009, 12:26 PM
07841-tb's Avatar
Yes & No. If they performed a coolant pressure test and the coolant pipe was on the verge of failing well then that pressure test just placed it over the top, but that would still make them responsible. Just keep fighting. The crazy thing about what the dealer charges is that I received my info from the BMW Techs on how to replace the pipe w/o pulling heads & engine.
2002 BMW 745Li
Old 10-17-2009, 02:46 PM
tagsports's Avatar
tagsports tagsports is offline
Mein Auto: 02 745i
WOW!!! You are the man and my new hero! I would have never tried this even though I have rebuilt many motors in my time. After your write up I feel confident I could pull this off if the need should arise. Many thanks for taking the time to write up, photograph and share.
02 745i
(Titanium Silver-Black Interior/Roof Spoiler/Staggered 20" Breyton Wheels/H&R springs/Bell Built-in Radar Detector- Laser blocker/Sun Shades/L7/Cold Weather Package/Convenience Package/BTUM/Other stuff I have forgotten)
Old 10-17-2009, 03:41 PM
07841-tb's Avatar
No problem, hopes this helps alot of people.
2002 BMW 745Li
Old 10-17-2009, 05:26 PM
Judd944 Judd944 is offline
Mein Auto: 03 745i Sport / 01 986S
Wonderful write up! Thank you for taking the time to do that !
2003 745i Sport Sterling Gray/Black
2001 986S Seal Gray / Boxster Red
Past:
98 540i Sport
6 944's
Old 10-17-2009, 05:31 PM
rustar's Avatar
rustar rustar is offline
Mein Auto: 745i
ha how does it feel to be a new and loved 7 series hero
Old 10-17-2009, 07:18 PM
07841-tb's Avatar
I would'nt call being a hero but THANKS ANYWAY!!! just trying to put this out there to help others.
2002 BMW 745Li
Old 06-20-2010, 02:57 PM
theoutlander theoutlander is offline
The Outlander
Send a message via MSN to theoutlander
Mein Auto: 2003 BMW 745 LI
Thanks - this seems like useful info! I hope I never have to do this though ... I just replaced the thermostat and it was quite a project! Glad I had a bike to rely on for a few weeks...
Old 06-25-2010, 07:42 PM
kpeterson kpeterson is offline
Mein Auto: 2002 745i
Do you need to remove the radiator to replace the coolant pipe or just buy a collapsible pipe kit from bimmerparts and do the job.
Closed Thread
HTML code is Off
