Old 10-17-2009, 07:17 PM
jieg jieg is offline
Ivan
Mein Auto: 525i 2003
twisted seat surprise, see images
as indicated in my other post, I took out my driver seat to fix the twist seat
I must admit that I spent a long time "fixing" the cable ends of the motor that control seat height (wrong motor, the little one) at least I did not cause any damage
Later I started working on the other motor, there has to be that one!! (large one)
ok, I disengaged the cable from the motor and pulled the inner cable outwards and found what is shown in the picture, the cable pulls all the way out!!!!. I did not try all the way but I am sure it would come out of the sheath.
The short cable (shown in the picture for comparison) belongs to the height controller, for which I cannot pull the inner cable outwards
Image Hosted by ImageShack.us
By jieg at 2009-10-17
is the problem on the other end of the cable?
By jieg, shot with KF750 at 2009-10-17
any one has experience working on the other extreme of the cable?
All DIY´s I read are related to the motor end of the cable
any help is needed and welcomed
thanks
IVan
---------------Ivan
Old 10-17-2009, 08:24 PM
hieuu hieuu is offline
Mein Auto: 03 540i
Pulling out cable is normal, the cable is square on both ends you can even flip flop the cable it does matter. The other end goes to the gear box and the cable fix doesn't always work if your gears are stripped, because like most other bmw parts they are made of low quality plastic.
Old 10-17-2009, 09:52 PM
Ivan
my son helped me a lot!
finally sorted out!
Seems that not all cases can be sorted with the seat inside the car, in this case it was indispensable to take the seat out of the car.
remove the cable, heat the metallic silver sheath to take it off, then cut some sheat as shown
heat the metallic sheath again to reinsert it in the plastic sheathed cable, which sould have a longer metallic end now.
reassemble carefully, as is tricky to hold the assembly back as originally shown in the upper picture
---------------Ivan
Old 10-17-2009, 11:10 PM
chiefwej's Avatar
chiefwej chiefwej is offline
Freude am Fahren
Mein Auto: 2003 540i/6 //m-tech
On mine, I didn't unscrew anything. Once I confirmed which cable had the problem, I just used a cigarette lighter to heat the ferrule on the motor end of the cable, jerked the cable out, cut about 3/8 inch off the black sheath, heated the ferrule again and shoved it back in. Fixed, just that quick.
chiefwej 2003 540i ///m-tech 6-speed
Black Sapphire Metallic w/gray
Old 10-18-2009, 07:22 AM
anton-sa anton-sa is offline
Mein Auto: Bmw e39 525i 2001
on my 2001 525i, i got sports seats, manual ones. im actually glad they manual. less problems...
on my previous ride i had a e30 325i, which i fitted front electric sports seats from a 1997 M3.
i eventually had one of the gears stripped, was finnicky to replace...eventually replaced it though.. when i sold the car though, the driver side seat gear also had a problem (the dredded e36 electric seat recline gear)
i had no idea e39 electric seats also gave issues... again..hehe im glad ive got sports seats of the manual variety (has up/down,tilt,recline,forward/back)
Old 10-18-2009, 08:21 AM
andyffer andyffer is offline
WTB - your E39 M5
Send a message via AIM to andyffer
Mein Auto: 02 530i, 09 335d
lighter weight so you have that performance advantage. BMW sneakily put that kind of stuff in the 525.. sleeper
With 1 person driving the car I could live with the manual seats but if you have other drivers then its a real pain.
Unencumbered by the thought process
If you're not a ******* at twenty you have no heart, if you're not a ************ at forty you have no brain.
Old 10-18-2009, 02:20 PM
Ivan
i personally do not like all the electric options in the seat, I would prefer manual movements, especially on the back rest
---------------Ivan
Old 06-14-2010, 03:15 PM
540 bimm 540 bimm is offline
Mein Auto: 1994 BMw 540i
can you help me on my case sir's.. i checked on the cables already and its still good.. the motor is working but all of the right side of the driver seat is not working.. it seems like my seat just had a stroke.. LOL.. can someone help me pls.. thanks!!
Old 06-14-2010, 03:52 PM
cn90 cn90 is online now
LOL,
Leave the seat in one place, stop adjusting it and you will never have this problem....hehe!
Anyway, good DIY!!!
Old 04-16-2011, 08:42 PM
Vegas Jade Vegas Jade is offline
Mein Auto: BMW 5 series 3003
Great thread
Im new to the forums and finally got enuf money to buy a used 2003 5 series 525i
Got problems with the seat... it works both move but is twisted
Head rest doesnt go up and down.
Leg support that goes out of the seat is stuck in the extended position i think its a switch problem it doesnt make a clicking sound when i try to retract it... like that of when you try to extend it.
Any help for a new enthusiast.
Old 04-16-2011, 08:45 PM
Trini23007 Trini23007 is offline
Account closed at users request
Mein Auto: 2003 525i sport
messing with the seat scares me dude, so many parts and wires...
Old 04-17-2011, 08:29 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
For the record, if someone comes here for twisted-seat DIYs, I'll add this to the existing list of twisted-seat DIYs, each of which has helpful advice.
- How to understand BMW seat cables that fall out causing twisted seats (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) & watching out for the accidental airbag light (1) (2) (3) (4) (5) & warnings about the seat twist DIY (1) (2) (3)
Old 01-04-2013, 07:15 PM
bluebee's Avatar
This thread just came to my attention today - it has some really nice pictures of seat twist repairs:
> E39 (1997 - 2003) > Another seat twist thread
Old 10-14-2013, 10:26 PM
bluebee's Avatar
This thread was updated nicely with a new seat twist lessons learned post:
> E39 (1997 - 2003) > Seat Twist Repair E39 2002 530i - DIY
Originally Posted by Gian View Post
I just finished this repair myself and, let me start by saying, it was a major pain. The #1 thing you will need is patience. If you don't have it, forget it. My passenger side seat had a problem when trying to recline and when trying to elevate. Therefore, both motors were affected. I decided to do it the "harder way", by removing both of the motors and cutting the sheath back on ALL FOUR connections. (IMO, You do not want to go back in there! Trust me. Do them all now! Even the sides that work! Eventually they may fail.)
I used this DIY guide
bellsouthpwp.net/m/i/miales/seatcablesfix.htm
Many thanks to the poster of this guide
Tools that I used...
Needle nose pliers
Socket wrench w/T-50 bit
Box cutter/razor blade
Reversible Flat 8mm built in socket wrench (A must have)
Bic Lighter
LED flash light (not pictured)
After careful consideration, I decided not to remove the seat from the car or disconnect the power. I ended up placing the twisted seat up against the back seat to get a good look underneath. I then placed a board underneath the twisted seat to brace it so that it wouldn't fall back forward.
Tips
-The smaller your hands are the better. It is really tight under there. Also you might want to wear some sort of gloves. There is a lot of rough metal parts and you can get your hands cut up easily. (I did, live and learn)
-There was a metal bracket that I had to bend in order to get to one or two of the bolts. It had some plastic housing attached to it with wires. I had to remove the plastic housing so that I could bend the metal. You'll know it when you see it. I just bent it back after I was finished.
-Take note of the location of the Bosch label on the motor so you can put it back in correctly.
-If you remove both motors at the same time, make sure you mark which cords go to each motor.
-Before finishing, make sure you bring both sides of the seat up in order to even them out. Once you put the cords back in you will not be able to do it. (After cutting the sheath and replacing the connector, put one cord in at a time and bring each side all the way up. This will even out both sides of the seat)
-Make sure you apply enough heat to the metal connector on each cord. It must be hot enough so that it can be put all the way back onto the sheath. That connector has teeth that cut into the sheath in order to stay in place. If you don't get it back on fully, then shortening the sheath did nothing. The cord will not stick out enough to engage the motor.
-One thing I wish that I had was a magnet of some kind. Putting the screws back in would have been so much easier.
That's all for now. I will add other tips if I can remember them.
See also:
- How to identify seat twist & fix twisted seats (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) (13) & BMW_E34_seat_twist_repair_diy.pdf
Old 06-01-2014, 06:35 PM
bluebee's Avatar
Yet another twisted seat thread today ...
> E39 (1997 - 2003) > Twisted Seat For Me Too
Old 08-03-2014, 09:41 PM
bluebee's Avatar
For the record, this was posted today ...
> E39 (1997 - 2003) > Question about seat twist.
Originally Posted by tygr1 View Post
Can the bottom of the seat become twisted for the same reason as the back of the seat i.e. the cable?
Originally Posted by Dking078 View Post
Yes it can, the fix is the same procedure. The cable for the bottom of the seat is near the back rest cable.
Old 08-05-2014, 02:42 PM
bluebee's Avatar
This thread today has good information:
Exactly how many cables are there under the seat?
Originally Posted by stickbuilder View Post
You will be dealing with 4 per seat. 2 on left and 2 on right. Did both seats in 3 hours. Take your time and do it right. Don't cut sheaths in the middle and clamp them. Do it on the ends. I cut about 1/2 inch from each end. My seats had bottom and back twist. They work perfectly now.
Old 09-05-2014, 09:07 AM
bluebee's Avatar
This thread today asks the basic question...
> E39 (1997 - 2003) > Permanent solution for twisted seat problem?
Originally Posted by bimmerZ5 View Post
So, my car has started to develop the twisted seat problem and I'm getting ready to fix it. From all the videos and postings on the internet that I've seen/read, the problem seems to be that the rubber tube/sheathing material expands over time and prevents the internal cable from making proper contact with the adjustment motors. The fix seems to be to shorten this tube/sheathing material to allow the internal cable to be exposed again. (correct me if my understanding is incorrect)
The solution seems fine, and it may not matter to most folks that the problem might reoccur in 10 yrs time, but being an engineer type, I just thought to myself, isn't there a better material that can be used that has better dimensional stability? For example, would some PEX tubing make a better sheathing material that would not expand over time? I don't have a Chem. Eng background or anything to do with polymers sciences, but thought maybe some fellow E39 owners might be and have some good ideas?
any thoughts?
Old 02-23-2015, 06:15 PM
jeffmgr jeffmgr is offline
Mein Auto: 2002 525i
A new post to an old thread...my wife has a 2006 330i whose driver's seat has the dreaded twisted seat problem. The indy mechanic told us that the motor has fallen off, and the cable has broken off. We now need a whole new frame which costs $1100 plus labor to put back in the cushions seats etc.
What do the folks here at bimmerfest think about this?
Jeffmgr
Old 02-23-2015, 06:33 PM
Burning2nd's Avatar
Burning2nd Burning2nd is online now
Under the lift arms
No you dont.. first thing first take the seat out..
and if the seat isnt going back in that same day...
Find a milk crate
15486372<-----
Old 02-23-2015, 10:34 PM
ha, do they deliver milk anymore!
Should I tell the indy mechanic not do the repair? Only my wife can use the seat as she's short and moving the seat back only makes the twisting worse, so I'm unable to drive the car.
On my 2002 525i, the same mechanic was able to just do the usual cut the cable and re-insert into the motor...fixed it for $200, but he says this seat is worse.
Any suggestions?
Old 02-24-2015, 07:15 AM
Burning2nd's Avatar
Under the lift arms
look for a new seat...
Or remove the seat find the issue and repair it,
either way it starts out with remove the seat,
unless your like one of those freaky people @ the shop that can stay in a car all hunched over for like 6 hrs @ a time
15486372<-----
Old 02-24-2015, 07:44 AM
540iman's Avatar
540iman 540iman is offline
resident, old fart
Mein Auto: 2002 540i sport
Any suggestions?
I have done this repair several times. Seat in, seat out, just removed 1/4" outer sheath from middle of cable not disconnecting either end. I don't see this mentioned, but on some broken seat functions, you can loosen seat rear bolts, remove two front seat bolts and tip seat backwards allowing access. Find where seat is level, even, whatever. Leave it there. Find bad cable and melt away about 1/4" anywhere in cable allowing center spline room to extend back into motor or gearbox. You can then use a cable tie that will kinda force cable sheath back together, tape, and then try. Center cable really *wants* to engage in both ends but the stretching outer sheath pulls one end of cable back and out of its mate. Takes very little to make cable *jump* back into engaging at both ends again. Using the motor makes the cable actually drive itself lengthwise. oh, forgot reason for posting-old age. Your indy is stroking you as he doesn't know what is wrong, but for your $1100 dollars he feels safe he can fix any issue or take to another shop, get fixed for him, and return car to you fixed and he is richer. Motor loose??!! Hardly. Save your $$$#
Old 02-24-2015, 08:44 AM
Ivan
Jeffmgr
If you cannot be without a car; for that money, rent a cheap one for 2 days while you take out the bimmer seat for a DIY fix
---------------Ivan
Old 02-24-2015, 08:53 AM
johnstern's Avatar
johnstern johnstern is offline
Mein Auto: 2000 BMW 528iT/5, S/C
Jeffmgr
This problem is different from the usual twisted seat issue which involves the seat back and/or the seat bottom twisting if adjusted for rake (seat back) or height (seat bottom cushion). From your description it sounds like the seat frame has broken, etc., etc. as it is rare to have a problem with the whole seat moving back and forth.
So you need to find someone who can repair (weld) the frame and reattach the motor, cable. I have welded a seat frame on a manual seat before and had no problems after the repair. I did not have to take any upholstery off, just had to be careful. Of course, the seat has to come out of the car for inspection to see if it can be repaired. Maybe an auto upholstery shop would be a better place to go. At the shop I used to work at, we usually sent seat problems to the upholstery shop as they were more skilled in that kind of repair.
On the other hand excellent condition seats in the correct color and style are available used on eBay or on www.car-part.com for probably less $ than a repair would cost unless you DIY. Certainly $300 would buy a good used seat.
Bottom line is that you'll have to do the research and find out whether to replace or repair.
