Old 02-03-2012, 05:45 PM
pistolpuma's Avatar
pistolpuma pistolpuma is offline
Ultimative fahrmaschine
Mein Auto: '08 328 E93 '12 X3 28i
Great write up. Oil changes are about all I feel comfortable doing nowadays. I miss lying on the driveway trying to replace a clutch in sub-freezing weather.....ummmmm maybe not.
Old 02-03-2012, 07:10 PM
icuc's Avatar
icuc icuc is offline
Mein Auto: 2012 X5, 2012 MINI ALL4
Originally Posted by RGBiMMER View Post
I took my car to an indy for my 1200 mile break in oil change. I bought the oil and filter from the dealer. My indy guy said, "did you get the synthetic filter." I told him this is what they gave me and he said that is fine but there is a better one from the dealer. Does this make sense to anyone?
How was the oil? Did you see anything on the oil?
BMW (Remote) Coding for E Series, F Series and G12 Models - www.bmwminicoding.com
Old 02-03-2012, 07:28 PM
DrSeuss99 DrSeuss99 is offline
Mein Auto: Bimmer
Great post!
I'm surprised the filter looked so worn...
RGBiMMER RGBiMMER is offline
Mein Auto: 2011 335i Sedan
I told him to keep it if he saw anything I should look at so I didn't get to see it. He did say it was darker than it should be for 1200 miles and it was good I changed it.
2011 335i Sedan/Space Gray/M Package
Old 02-03-2012, 07:39 PM
icuc's Avatar
I will have my oil sent to analysis to see if they find anything.
Old 02-03-2012, 11:27 PM
Let me know how those results come back.
Old 02-04-2012, 08:00 AM
DSXMachina's Avatar
Bimmerdex 7.4!
Pick up a set of left handed screwdrivers and metric Vise Grips, you'll need them to install that synthetic oil filter.
Good oil often gets dark quickly, it's doing its job and cleaning up the carbon and other guck. Color doesn't tell you the oil is bad unless it's milky or other than amber.
Old 03-21-2012, 09:00 AM
ProfessorCook's Avatar
ProfessorCook ProfessorCook is offline
Not a real doctor.
Mein Auto: 2009 328i Coupe
I thought I'd add a couple of notes:
The socket for the oil drain plug is 17 mm.
The drain plug goes back in at 18 ft-lbs which is about 215 in-lbs or about 24 N-m. (This is such a low torque, you can probably only find a 1/4" torque wrench that will work well.)
The Tischer oil filter wrench (the big silver cap) uses a 27 mm socket. (Which is quite large, btw. You may not have one.)
And here are the manual pages that cover how to check oil level after you're done.
'09 328i Coupe: MT, Monaco Blue, Black Dakota, Dark Burl, ZPP, ZSP, ZCW, CA, Logic7, HD Radio, IPod
Ordered: 14Jan09; Delivered: 24Feb09 from Stratham, NH BMW
Old 03-21-2012, 11:21 AM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
24.404723100000002 N-m, IIRC.
Old 03-21-2012, 06:53 PM
pointandgo's Avatar
Mein Auto: '13 F10 535i (loaner)
Excellent DIY and well illustrated, but if I lived close to DSX I'd let him do it...quite a messy job with too many "O ring" technicalities IMO. DSX's capable technicians could handle the job as I chatted with him in the waiting room and passed haggis recipes to the Englishman and recommend unique ingredients -- The English will eventually get the taste of it. Images of rubber gloves always frighten me as I have a particularly aggressive Urologist. He should have been more sensitive about these issues.
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
Member: BMW CCA
Old 03-22-2012, 04:35 AM
Not a real doctor.
If your doctor is using gloves like those, you need to find a new doctor.
Guys over 40, if you don't have a doctor give you a DRE and check your PSA every year, you could be making a huge mistake. Trust me on this one.
The O rings are easy. Doing the job yourself is satisfying. Having a cold one after is pleasant. Reserve the talents of a guy like DSX for jobs more demanding of his considerable talents.
Old 03-22-2012, 08:30 AM
wh00sh wh00sh is offline
Higher than you
Mein Auto: M235i xDrive
Is DSX qualified for the DRE and PSA checks? Maybe if we provide our own gloves?
Old 03-22-2012, 08:40 AM
Not a real doctor.
Interns and MD's are bad enough... I don't care if DSX is qualified, he's not checking my personal exhaust!
(Man has this thread gone downhill in a hurry.)
Old 03-22-2012, 10:43 AM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
DSX has access to an air compressor and associated tools. In my book that makes him forever disqualified, even if his office wall is covered floor-to-ceiling in sheepskins. (Or goatskins.)
(Downhill and picking up speed. )
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff
   N47 35' 30.13" E11 10' 33.36" - End of break-in...you can guess what came next. BMW CCA
Old 03-22-2012, 10:44 AM
Zeichen311's Avatar
Reported to the significant figure police.
Old 03-22-2012, 11:54 AM
Bcube's Avatar
Bcube Bcube is offline
Combat Commuter
Mein Auto: 2007 E93 335i
Since I use the BMW TIS, I'll go with what it states: 25 N-m for both the drain plug and oil filter cap.
And since the dealer's service coupons and my oil changes never seem to agree on dates, we have settled for a straight $88 charge for oil service only.
-Brian
"Used cars are our entry cars." - Luca di Montezemolo
Old 03-22-2012, 12:34 PM
Zooks527's Avatar
Hey, didn't we have this dance in this thread? http://www.bimmerfest.com/forums/sho...d.php?t=608007
Posts 14 -> 22.
Old 01-28-2013, 06:42 AM
rweaver rweaver is offline
Mein Auto: 2012 BMW 328xi E90
1/29/2013 UPDATE: The above feed was excellent in helping me do my first oil change on my 2011 328xi. I would like to add some things.
(1). Jacking up the car was the most difficult part of it(and it was not bad at all). I recommend using a wood block on the jack(esp for the rear) and for the jack stands. The points on the car for jacking are square and plastic, the the rear had no specific jack point, so I used the frame. This required the wood block as the car is so low.
(2). The washer indeed was stuck to the oil pan and needed some gentle persuasion with a small screwdriver.
(3). The drain plug is 17mm.
(4). The car drained 6 quarts and took the same amount of oil(mobile 5-30W).
(5). The car had 7500 miles, but the oil was "mud" like. I couln't imagine waiting for the prescribed 15,000 mile change.
