Old 10-20-2009, 10:11 AM
letoj letoj is offline
Mein Auto: 2000 740il
GPS Antenna
The GPS system in my 2000 740il is out of wack always saying that I am out of the map limits. The dealer checked it out and told me I needed to replace the antenna and it costs $450.00 for a new antenna. I found an antenna on ebay for $20.00 does any one have information on how to replace the antenna? I would like to try and do it myself to save some money.
Thank you very much,
Letoj
Old 10-23-2009, 01:56 PM
CodyItaliano's Avatar
CodyItaliano CodyItaliano is offline
Mein Auto: 2001 740i
my car has the same problem, saying i'm out of the maps limits. so maybe i need to replace my antenna? i know you need to remove some of the interior trim along with the headliner.
*Der E38*
manufactured: 7/01
color: anthrecite metallic
wheels: style 89 E66, 19X9F 19X10R
ext. lighting: 8000k D2S & LED plate light
*want to get sport rear diff*
Old 10-23-2009, 02:37 PM
That sounds like a big job.
Old 10-23-2009, 04:01 PM
it can be if you dont know where to pull the trim pieces apart, knowing where the clips are helps. also that headliner can be a pain. the main problem you will encounter will likely be manouvering it out and back into the car. even with the large door openings.
*Der E38*
manufactured: 7/01
Old 11-03-2009, 10:49 AM
I read on this forum that to reset the GPS system I would have to disconnect the battery. Well, that is a good idea because I had to get a booster to start my car the other day because the battery was down and all of a sudden the GPS start working.
Thank you for all your help guys. This forum is very helpful
Old 05-27-2010, 12:14 AM
safari112010 safari112010 is offline
Mein Auto: bmw
can anyone help i need to know how to replace my gps antenna for my 740i 2000
Old 06-02-2010, 05:59 AM
Mein Auto: bmw
disconecting the battery did not work. what is next anymoe ideas thanks
HTML code is Off
