Old 10-20-2009, 11:01 AM
tom @ eas's Avatar
tom @ eas tom @ eas is offline
european auto source
Mein Auto: BMW
eas | [YouTube Video DIY] - AiB Angel Eye Installation Overview - e92 M3
Gentlemen,
This short video will go over the steps on how to install the AiB Angel Eye kit on a MY08 M3 Coupe:
Models Supported:
2007+ e92 3-series Coupe/Convertible
2008+ e9x M3, including Sedan, Coupe and Convertible models
Hit "HQ" to watch the video in high definition
Enjoy!
Old 10-20-2009, 11:02 AM
tom @ eas's Avatar
Mein Auto: BMW
AiB Installation Process
1. Depress retaining barbs on headlight access cover with screwdriver and lift out of place
2. Locate OEM Angel Eye Connector Plug
3. Rotate bulb 90 degrees counter-clockwise (from front of vehicle) and remove from lamp
4. Remove bulb from connector using screwdriver to free retaining clips
5. Remove bulb
6. Route AiB lightsource into bulb housing
7. AiB lightsource in highbeam housing
8. Using softjawed pliers, slightly rotate AiB lightsource to lock into place
9. Route AiB lightsource power connector through supplied heatsink
10. Back out allen set screw with 5/64 wrench
11. Install heatsink onto AiB lightsource and lock into place with set screw
12. Plug AiB DriverPack into LightSource, connector is keyed to go in only one direction
13. Plug wires into OEM AE connection, wires are color-coded to to factory colors used on your BMW
14. Tuck wiring away from any high-seat sources or movable parts within lamp
15. Tuck DriverPack inside channel OUTSIDE of headlamp underneath radiator support away from view. DriverPack are potted design to resist elements. DO NOT INSTALL DRIVERPACK INSIDE HEADLIGHT HOUSING
16. Replace headlight access cover. No exposed wiring is seen with proper installation
tom @ eas's Avatar
Mein Auto: BMW
Completed installation - exterior view
Here are a few short videos:
From these angles you can see a number of things:
-High visibility from extended distance
-High visibility in direct sunlight
-Close up in shade
-Unlock and lock demonstration
-Ignition on/off
Also note that there is no flickering when the ignition is turned on or off, or locked/unlocked
Old 10-20-2009, 11:03 AM
tom @ eas's Avatar
Mein Auto: BMW
e92/e93 Angel Eye Overview and inner workings
The LEDs being used in the AiB assemblies are a 10W SMT LED 5500K equivalent which give off a bright white light. There have been a LOT of contenders in the Angel Eyes for coming up with a possible solution - most of them were failures for a number of reasons:
- Insufficient direction of LED light
- HID systems providing too much light/glare or excessive heat
- Insufficient LED power
- Little or no heatsink used
- Expecting drastic results with tinted or "Xenon" type bulbs
- Uneven brightness between rings
Here's a diagram of the fiber path used in the e92 setup:
The inner lamp will always get a direct shot from the bulb (H8). However, the outer projector will always be weaker due to the travel path needed in the fiber lines to illuminate the ring. This is why the outer rings are always dimmer than the inner.
All the latest and greatest bulbs on the market will not correct this design. This HID kits are interesting as they use a very high color temperature, reducing the lumen output in order to illuminate the rings. Unfortunately - this gives a very blue color, which is not what we're looking for. Also - HIDs run at very high temperatures. These headlamps are by no means cheap to replace.
Voltage Requirements:
E9x M3 headlights are very sensitive to voltage and can give off errors if the proper resistance is not detected as what the system would expect from a H8 bulb - a reason to why "resistor packs" are required on the HID setups. LED systems use a driver pack, which will be integrated into the system to keep these errors from appearing.
System uses very little power and is double the output (10W) than most kits with no flickering experienced from the vehicle's bulbcheck system
Durability Testing:
We have had 4 vehicles in testing since late December '07 before our initial release in June '08 with no errors produced. One car you haven't seen would be our Project1 from the 1Addicts forums:
Features:
- 5500-6000K temperature for a bright, white light.
- Easy 10-minute installation
- 100% Plug and Play, without the need for wire splicing, tapping or additional wire harnesses
- OEM-like integration
- Low heat output, unlike colored bulbs or HID kits
There's no need to complicate a mod that should be relatively simple on the end-user's side.
tom @ eas's Avatar
Mein Auto: BMW
reserved 01
Old 10-21-2009, 10:33 AM
xUberBMWx xUberBMWx is offline
Mein Auto: Strictly BMW
Do you know what exact resistor pack i need for the HID system for it to not give me a error for my angel eyes on my e92?
