ABS Relay - 2001 530i - Location - Part# - Bimmerfest - BMW Forums
Old 10-21-2009, 04:17 PM
TechW TechW is offline
TechW
Mein Auto: 2001 BMW 530i
I have been reading up on the ABS and DSC dash lights. They come on and stay on. They will go off for a while as well. They do not flash on and off. So, from what I have read, a good place to start (cheap) is to replace the ABS relay. The only problem with that is, I have the Bentley manual but it doesn't show the location in my car or the part number I need. Looking around to find this information on the Internet is making me crazy as I can't find it there either!
Can anyone help me out here? Where is/are the ABS relay/s located and what is the part number I need to purchase? Pictures or diagrams would be nice if you have them.
I know it could be a sensor. If it gets to that I will take it in to have them tested.
Thanks in advance for your help on this.
Old 11-03-2009, 07:23 PM
Ariel22 Ariel22 is offline
Mein Auto: 528i
hi!! did you find the abs relay??? I have the same problem......Thanks
Old 11-03-2009, 07:38 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Start here and post there if you still have questions ...
Good luck!
Old 11-03-2009, 09:46 PM
TechW
ABS Diagnostics - E39
Wow! That is the best DIY repair write-up I have ever seen! Thanks for the information. I now feel like I can deal with this problem myself.
Old 11-03-2009, 11:20 PM
gibo27 gibo27 is offline
Mein Auto: 530i Sport
DSC Light ect
That is an intense write-up, very well done. I have recently bought a 2002 530i and have the same problem...sort of. I noticed the ASC and ABS lights on and the speedo and vacuum gauges not working. Again stopping and switching the ignition off cleared the fault...for a while. Anyway went up to a BMW service centre the other day to get it checked out and again on the way the ASC and ABS light came on....but this time the speedo and vacuum gauges were working??
(I did take both rear wheels off before I left and cleaned the inside of the rims and gave the speed sensors a bit of a wiggle to make sure everything was secure)
The BMW service report was "speed sensor fault on both L/H sensors, fault cleared, possibly control unit"
So does this mean that BMW dont know precisely either? Surely they dont change expensive parts on spec? BTW speed sensors over here in Australia are $500AU ($550US), so if they need changing I'll be buying them from the US ($78US),
Also no lights came on during the 60 mile trip home.
Thoughts anyone?
PS. How do I tell what model 530i I have, it is supposed to be a High-Tech Sport, I know it's a Sport but how do you tell if it's a High Tech ?
Cheers
Glen.
Australia
Old 11-04-2009, 05:31 AM
cn90 cn90 is offline
This is a pic from my 1998 528i, Pass Side Cabin Filter area, PINK Color Relay:
Old 11-04-2009, 04:59 PM
Mein Auto: 528i
Thank You Very Much!!!!!!
Old 11-04-2009, 06:54 PM
Please post a follow-up whether or not you fix the problem.
This way future readers can learn from it.
Old 05-22-2011, 11:19 PM
geneqco geneqco is offline
Mein Auto: 540i
DSC problem - ABS is fine
Hi all, I'm new to this forum but have been having a DSC issue so I hope someone can help!
Thanks for your photo cn90... very helpful, however my ABS/DSC relays are not in this location.
I have a RHD 1999 540i and the only issue I have is the DSC light is on and the DSC is not working. There is a fault code in the ABS system (I think 088) that relates to the pre charge pump... the ABS, cruise control, speedo etc are all working fine. The resistance across the pre charge pump (located under the driver's side cabin filter box next to the brake master cylinder and booster) terminals is 0.7 Ohms which I believe (from other research) is normal. A lot of research has suggested the issue may be the light pink ABS relays (Pelican says there are two of them). I have bought the new relays but cannot find where they are located. I have done many searches which all seem to suggest they are located under the passenger side cabin filter box where the DME and transmission computers are located but they don't seem to be there. There are numerous other relays there but not the ABS relays (I think they may have been there in earlier models or perhaps with the DME for LHD cars).
Any help as to the location of these relays or any other issues to check would be greatly appreciated.
Many thanks,
Scott (Sydney, Australia)
Old 01-16-2012, 01:04 PM
crazyb0064 crazyb0064 is offline
Send a message via AIM to crazyb0064 Send a message via MSN to crazyb0064 Send a message via Yahoo to crazyb0064
Mein Auto: 1997 528i
Mine looks about the same, except I have a trans ecu in there, I have a 97 528i. I'm having ABS asc issues I think, trans doesn't up shift by itself. Swapped wheel speed sensors, and now that I know where the relay is, will try that
Old 06-04-2012, 05:26 AM
hitchva hitchva is offline
hitchva
Mein Auto: 2001 BMW 530I
trying to locate ABS Relay and color for 01 bmw 530i e39
hi, i can not locate the ABS Relay, the relay box is similar or exact as E39 540. even though i have 2001 530i , the relay box looks exactly like the one you posted of the 540!!. my car is 6 cylinders not 8 as of in 540. i went to the dealer and i gave him a relay number he said that it goes by color so i asked him for a light pink assuming my relay box is of the 530 model where the ABS is in light pink color, guess what he came back to me with a black relay which i assume that maybe they did change their system but when i open the Relay box under the left cabin filter box, for my surprise there was no light pink nor black rely. and as i mentioned the layout was of the 540, the one posted . please advise and help. would appreciate very much with picture defining with arrows. thanks
Old 12-07-2015, 10:07 AM
Alika808 Alika808 is offline
Mein Auto: X5/330/Range Rover HSE
I know this is too old topic, but I am wondering if you find the ABS Relay location. I have 2002 525i with the same set-up like in the picture. Thank you.
530i, abs, relay
