E34 (1989 - 1995)
Old 10-21-2009, 05:56 PM
BrothaMansWhip2's Avatar
BrothaMansWhip2 BrothaMansWhip2 is offline
Blue Miracle Whip
Mein Auto: e34 touring 525I
Couple of questions about touring light [B][/B]
I am still having a problem with my lights on my touring.I'm thinking of replacing my rear lights. But the ones i've looked have wires
http://cgi.ebay.com/ebaymotors/89-90...item20adb6461d
instead of the white plugs that screw into the sockets , making contact on the small tabs. My lights are fine except when i turn on the headlights at night. My turn signals remain on, very bright and do not flash. The hazards also do not work when the headlamps or parking lights are on. One of the plugs for the brake lights is not functioning. Should I be looking at the flasher/hazard relay?
So what is the difference between touring rear lights and regular e34 lights?
Anyway know where I can find some nice e34 touring rear lights?
I found the solution. I have the wrong bulbs installed. I need orange double filament bulbs. Any one know where I can find some? Send the link please....
Went from a 87 e30 with Stick Shift,
To a 92/3 e34 Touring with an M50 in it!
88 e30
87 e30
1992/3 525I Touring
Old 10-22-2009, 10:18 AM
ross1's Avatar
ross1 ross1 is offline
Mein Auto: Pretty much had 'em all
Those are crap.
Buy used factory parts.
your issue sounds to me like a bad ground causing the dash lights to remain on.
Take my advice, I'm not using it.
Old 10-22-2009, 08:41 PM
CarDriver's Avatar
CarDriver CarDriver is offline
Mein Auto: 1992 525it /2004 ML350
Originally Posted by ross1 View Post
Those are crap.
I was just going to say the same thing! You beet me too it.
BrothaMan, Some things you can not go cheap with. That is one of them. Most importantly, The lights that are made for a sedan will not fit a touring! Do not let any vendor tell you they will !!
Contact a salvage yard to replace the tail light. or you can try ebay. As for the problems you are having, look to the flasher relay as the culprit. I do not think it would be your LKM.
Old 10-26-2009, 10:23 PM
Blue Miracle Whip
i'm going to get some new relays. i think its the hazard/ turn signal relay
88 e30
87 e30
1992/3 525I Touring
Old 11-01-2009, 08:52 PM
attack eagle attack eagle is offline
No more e34!
Mein Auto: Nikes + Mongoose
you could have the inevitable hatch harness issues
you could have a set of warped tails from some PO or mechanic sticking a 1 series light in there instead of the 2. (brake issue)
you could have a bad socket/bulb holder (brake issue)
BUT...
you definitely have the wrong bulbs in the front turn signals.
You need a 2 filament bulb (1157 iirc) and someone stuck in a single filament turn only bulb (1156).
happens a LOT. especially with 'stealth' or LED bulbs.
Still cruising after all of these years...
now on iOS 9 (saves gas)
Mutual Admiration Society
Member #5
Old 11-15-2009, 02:57 PM
Blue Miracle Whip
BUT...
That is exactly the problem Wrong frickin bulbs.
Can you send me a link so I can get them. I didn't see them on the franchise sites
88 e30
87 e30
1992/3 525I Touring
Old 11-16-2009, 05:23 AM
CarDriver's Avatar
You can look up the part number from realoem.com and search with that number on google or you can get the correct bulbs from bavauto.com, pelicantparts.com or autohauzaz.com
Call a sales rep before you place the order to insure you are getting the correct OEM bulbs. Or, Just go to the dealer.
Old 11-16-2009, 06:43 PM
Tourburgring Tourburgring is offline
Mein Auto: 1993 525iT
Any quality Replacement Bulb of the correct size, number and wattage will work, PROVIDED it has a Silver (nickel) base and not a Brass base. Sylvania, Phillips, Osram are all good. BTW you should NOT need Orange Coloured Bulbs in any location on an E34 unless somebody has converted to Clear Lens's.
Old 11-16-2009, 09:26 PM
Blue Miracle Whip
I have indeed changed over to clear lenses. I'm having a hard time finding amber/orange colored bulbs that are compatible
88 e30
87 e30
1992/3 525I Touring
Old 11-18-2009, 04:45 PM
Maybe that's the reason BMW stuck with Orange Lens's all this time
Old 12-06-2009, 05:57 AM
No more e34!
sorry so late.
the FRONT turnsignals
use standard 1157 bulbs.
you can buy 1157 at any parts place, walmart, even some gas stations!
na means natural amber ( ie orange bulb) so you want an
1157NA
Member #5
Old 12-06-2009, 09:08 AM
Blue Miracle Whip
Thank you sooo much. I'm hoping to pick some up today. In addition, the brake light socket is bad. I switched out bulbs and switched sockets/bulb holders and it still didn't work. Its definitely the bulb holder...
88 e30
87 e30
1992/3 525I Touring
Old 12-08-2009, 10:36 AM
Blue Miracle Whip
I got 6 1157NA bulbs.. Put tow in .. voila!! I have turn signal while the headlamps are on,,,,,,Thanks everyone
88 e30
87 e30
1992/3 525I Touring
