Welcome to Bimmerfest -- The #1 Online Community for BMW related information! Please enjoy the discussion forums below and share your experiences with the 100,000 current, new and past BMW owners. The forums are broken out by car model and into other special interest sections such as BMW European Delivery and a special forum to voice your questions to the many BMW dealers on the site to assist our members!
You are currently viewing the forum as a guest which does not give you access to all the great features at Bimmerfest including the ability to search, interact with existing members and the option to turn off contextual advertising in posts. Registration is fast, simple and absolutely free so please, join our community today!
Go Back   bimmerfest - BMW Forums > Welcome to Bimmerfest > BMW News Articles and Announcements > Member Submitted News!
Do you have some great BMW news that you want to share with members of bimmerfest.com? Submit your article in this forum today.
All articles are reviewed before going public.
Old 10-22-2009, 01:47 PM
tim330i's Avatar
tim330i tim330i is offline
Administrator
Mein auto: Alpine White 330i
BMW Heat Energy Recovery Technology
This sounds really cool. I'm growing more and more impressed with BMW's EfficientDynamics concepts!
Story -
For years, engineers have avoided heat in cars to protect components from overheating. Now, this goal is being turned on its head as automakers attempt to harness previously wasted energy for practical purposes such as improving fuel consumption and reducing CO2 emissions.
Even a highly efficient engine can only convert about one-third of the energy contained in fuel to actually propel a car. Two-thirds is lost as waste heat via the car's exhaust and radiator, according to BMW.
To capture some of this lost energy, BMW is working on a number of promising projects that make use of heat normally lost. The first idea may banish cold starts forever to reduce emissions. The second approach can convert the heat from a car's exhaust into electricity and the third idea uses waste heat to heat the interior of a car.
BMW engineers are working all-out on largely avoiding cold start conditions by fully encapsulating engines. Improved heat insulation of engines would prevent them from cooling down quickly and retain as much residual heat as possible for the next start.
In addition to the air flaps already on some production models, a prototype has already been developed that is completely surrounded by fully clad walls and panels using proven materials that are normally used in the car's underfloor for insulation.
Thanks to this approach, the engine cools down much slower after being switched off and still has a temperature of approximately 40 degrees Celsius after 12 hours. Each degree Celsius above the ambient temperature reduces fuel consumption by 0.2%.
The next phase of BMW's heat recovery technology is the generation of electrical power from wasted exhaust gases, which the automaker claims can cut fuel consumption by up to 2%.
We've already seen this in principle with BMW's thermoelectric generator, which was presented last year. BMW is now presenting the next level of development in the form of an integrated component in the exhaust gas recirculation cooler. With the latest development, up to 250 W of energy are produced under typical driving conditions--equal to about half the on-board electricity consumption in a 5-Series sedan.
The device relies on a thermoelectric semi-conductor element that generates electrical voltage. The bigger the difference in temperature, the higher the voltage generated. Exhaust gas temperatures, which are usually between 300 and 900 degrees Celsius, are on the hot side of the generator, and engine coolant is used for the cold side.
Whilst still a prototype, the current solution gives engineers more information on the operating principles as well as obstacles yet to be overcome. According to BMW, between 3 and 8% of the total fuel consumed by modern cars is due to the rising number of electricity-dependent features, so there are potentially big savings to be made.
Finally, BMW is also working on an exhaust gas heat exchanger. With gasoline engines, it would be very effective in warming up the drivetrain more quickly to the right temperature, avoiding friction in, say, the gearbox. Such an exchanger conveys heat, or thermal energy, from one flow to another, in this case the heat of the exhaust gas to the oil in the automatic transmission, with additional heat being pumped in consistently from the start.
Diesel engines are now so efficient that the excess heat generated by the engine is usually insufficient to heat the interior of the car alone. It has become quite normal to fit cars with an additional electric heater, which increase fuel consumption.
To avoid this extra fuel consumption, hot exhaust emissions may be used by means of a heat exchanger close to the catalytic converter to provide an additional source of heat for the interior. Such a system may avoid the need for electrical heating modules which consume additional fuel.
Further down the track, we should be seeing more advanced features such as the aforementioned heat-energy recovery systems, as well as variable frontal aerodynamics, increase use of regenerative brakes, and even a satellite-aided traffic management system. This latter feature is designed to help improve efficiency by anticipating when acceleration or braking will be necessary, and smoothing out the transitions between the two, resulting in better fuel economy.
Old 11-01-2009, 10:15 PM
Silentelysium Silentelysium is offline
Send a message via AIM to Silentelysium
Mein auto: 2006 E90 330i
That's pretty awesome. I like reading about what BMW is doing to better further their future cars.
I'm a little scared of encapsulating the engine bay, though.
Current Car: 2006 330i - Alpine White| Tan Interior| Blacklines| Rogue Engineering Exhaust| XM| Premium| Sport| Ipod Adapter| Navigation.
Old 11-18-2009, 05:32 PM
bmw_n00b13 bmw_n00b13 is offline
Freude am Fahren
Send a message via MSN to bmw_n00b13
Mein auto: 99 528i. Pics soon!
Given what I know about BMW cooling systems and some of their brighter ideas (lifetime fills anyone), I'm sure I don't like that idea!
'99 528i ('98/12 build). 155,000km BY29428/Royalrot/no mods
'99 540i (grandfather's, and what got me hooked on E39s. 10/98 build.) 153,000km
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
© 2001-2009 performanceIX, Inc. All Rights Reserved .: guidelines .:. privacy .:. terms
