Windshield Wiper Fluid not Spraying - Bimmerfest - BMW Forums
E46 (1999 - 2006)
Old 10-23-2009, 08:15 PM
themrvin themrvin is offline
Mein Auto: 2002 BMW 330CI
Hey guys, this is what happened,
One day I used the windshield wiper spraying mechanism thingy to clean my windshield and noticed my wiper fluid light turned on after I did (This part worked perfectly). I opened the hood and noticed the tank had about a 5th of fluid left so I went to the dealership and picked up a bottle of fluid concentrate. I poured about half the bottle into the tank then filled the rest up with water. Then i turned the car on and noticed the light disappeared but stupid me never actually tested the spray again!
So a couple days later my windshield was a little dirty so I tried to clean it by pulling the windshield wiper thing towards me and then my windshield wipers started to swing but no fluid was spraying out!!
I dont understand what could have happened? How bad can you screw up filling up the fluid lol? What do you recommend me checking?
Old 10-23-2009, 08:28 PM
jcourcoul jcourcoul is offline
Supporter of Bimmer Lore
Mein Auto: 2006 325Ci
Dead pump.
Replace. Part 4, #67128362154. Do same to strainer 5, #61667006063.
2006 325Ci
Old 10-24-2009, 10:42 AM
aw man, so im guessing it was just bad timing?
Old 06-22-2010, 09:52 AM
ventsyv ventsyv is offline
Mein Auto: 03 BMW 330ci
I'm having a similar problem. The pump was leaking a little, so I replaced the little gasket shown as #5 on the diagram above. The leak is gone but the sprayer hasn't worked since. Before I replaced the gasket, the sprayer was working but all the fluid will leak out within a couple of days.
I check all connections and everything looks OK. Is there a way to test the pump or should I just go ahead and replace it?
Old 12-29-2014, 09:31 AM
Alteclover Alteclover is offline
Mein Auto: 750LI
hi Im having a bit of a similar problem. just bought my 2008 750li and noticed my drivers side wiper would not spray. bought from a MB dealer and they said pump and lines cleared but still no spray , they recommended taking it to bmw. Took it to bmw and was told entire wiper assembly has to be replaced @ $700 ouch. any suggestions please? MB might resolve this under the 60day/2000 mile warranty that came with the car. waiting to hear from them.
Old 12-29-2014, 10:39 AM
3LOU5's Avatar
3LOU5 3LOU5 is offline
Slacker Extraordinaire
Mein Auto: '02 3LOU5i
99% of the time, this problem can be corrected by replacing the windshield washer pump.
I think I got mine from www.autohausaz.com. There's a good DIY floating around, and it's very simple.
Good luck !!
2016 Toyota Sienna SE - hers
2002 BMW 325i - his
1994 Chevrolet Silverado K1500 Sportside Z71 - whoevers vehicle is in the shop
2009 Harley-Davidson Sportster XL883 Low (Vivid Black) - his
2007 Harley-Davidson Sportster XL883 Low (Pearl White) - hers
2011 Tao Tao 50 - whoevers bike is in the shop
2007 Reinell 186 FNS - Aly's and Susi's (our two Miniature Schnauzers)
1995 Fleetwood Flair 27R - EVERYBODY'S
