How to: Adjusting headlight lights on an E-92 - Bimmerfest - BMW Forums
Old 10-24-2009, 11:57 AM
CarlosCA CarlosCA is offline
Mein Auto: 2007 Jet Black 328i
I don't know if this has been done before, but I thought I'd share some knowledge on how to adjust the headlights on the newer generation 3-series cars. I am only talking vertical adjustment too. I have not figured out if there is a horizontal adjustment, but mine seem to be okay there, so why mess with it?
I just bought my 07 328 and immediately noticed the headlights were aimed very low. In fact, they were lighting up a small area just a few feet in front of the car, but it was dark beyond that. Not good, especially here in rural SC.
Yes, I could have taken it to the dealer, but I've been working on cars for over 25 years and would rather do it myself and learn something in the process.
So, let's get started. The first thing I had to do was determine where the adjustment is. Fortunately, BMW made the adjustment hardware as obvious as daylight. The adjustment screws look like knurled knobs with an Allen head and a cross-tip head further down.
Using a 6mm wrench, rotate the knob as necessary to bring the headlight(s) up or down. The threads must be very fine too because it will take several revolutions of the knob to get the headlights to move.
Here are pics of both sides of the car to show where the knobs are relative to some reference points. The wrenches are in knobs in these pics.
Now the problem is to figure out where to set the headlights to. I tried a couple of settings before coming up with something that would give me excellent vision and would not result in constant flashing from oncoming vehicles. What worked for me - and it may be different for you - is to set the height of the light projection to 25 inches at 4 feet. I set up a card table 4 feet from the center of the bumper and adjusted the height of the center of the beam on each side to 25 inches above the ground.
Old 10-24-2009, 01:35 PM
Grentz's Avatar
Grentz Grentz is offline
BMW d Driver
Mein Auto: e46 M3, 335d
Interesting. Do you have Xenons? I would guess not as Xenons are supposed to be self leveling (that is the up down motion they do when turning on) to compensate for different weights in the car. Remember as the car is weighed down it will effect the light beam.
Old 10-24-2009, 02:32 PM
Yes, they are Xenons and they do adjust. Even if they do self-level, there has to be an initial adjustment though. Think of it this way...if there was no need to adjust them, why would they have adjustment knobs? I have already experimented by having the family sit in the back and the headlights do level to maintain whatever they are adjusted to.
Old 10-24-2009, 02:39 PM
MiPo MiPo is offline
Mein Auto: E92
Just curious, what were they set before? I do notice they don't light up very far, but have been reluctant to change fearing I'd blind the person in front of me, how did you manage to determine a good height for it? Thanks a ton!
Old 10-24-2009, 02:46 PM
Grentz's Avatar
BMW d Driver
Makes sense.
Old 10-24-2009, 02:58 PM
ProfessorCook's Avatar
ProfessorCook ProfessorCook is offline
Not a real doctor.
Mein Auto: 2009 328i Coupe
Great post. Thanks.
I've noticed that my left headlight is set lower than the right and I'm sure this is on purpose. If I get a chance, I'll get a picture of how mine are set. My car is a January build and was built in Germany.
'09 328i Coupe: MT, Monaco Blue, Black Dakota, Dark Burl, ZPP, ZSP, ZCW, CA, Logic7, HD Radio, IPod
Ordered: 14Jan09; Delivered: 24Feb09 from Stratham, NH BMW
Old 10-24-2009, 03:03 PM
caradd caradd is offline
Mein Auto: e92 335i
Usually the passenger side light is adjusted higher. Yours look even. Thanks for the write-up
Old 10-24-2009, 03:17 PM
Unfortunately, I did not measure them beforehand, but it required about 30 full rotations to bring them up to 25". They were ridiculously low to the point where I was concerned about driving at night. Let's face it, we know when something isn't quite right and I knew the headlights were way off.
I live in a cul de sac. At the end of our street, there is a long privacy fence. I watched where our other cars and my neighbors' cars' headlights were hitting on the fence. Particularly useful was my wife's Honda, which has similar headlights with a well-defined light height. I then adjusted my lights to roughly match her pattern and drove it around to see how they lit up the road, lit up road signs, and if they bothered anyone. 25 is the magic number I came up with. Of course, your car may be different as no two cars are exactly alike, but 25" at 4' should at least give you a starting point.
Glad I could help.
Old 10-24-2009, 03:23 PM
Actually, the picture you see is only of the driver's side light. At 4', you can set up the card table in front of each light and make adjustments to each independent of the other. That is, you will only project one light onto the card table at a time.
I knew about the passenger light needing to be higher for road signs, but I have not had any problems illuminating signs, so for the time being, I am leaving them as is.
No problem with the write-up. Just hanging around here recently I have learned a lot from other members. I am glad I can make a contribution.
Old 08-24-2010, 11:57 AM
arrambide arrambide is offline
Mein Auto: e91
Hello people!!..
I have the problem but is was after a big hole on the street and I needed to replace the lower control arm of the left side.
The thing is that on that arm, is the little arm that attach to the leveling sensor so when the lower control arm goes up, the sensor detect that the car is lower than normal position and when the lower arm goes down, the sensor detect that the car is higher that normal so that sensor "ask" to the headlight to lift or lower the direction of the lights.
My problem is the lights are on the higher position that the electronic function can, just like the sensor were on the "lowered car position" so if I just manually use this method, will lower the lights, thatīs Ok, but when the car really need to up the lights because ir really lowered, the sensor is on the higher position so will not up the lights don't you think?
Do anyone of you took a picture of this sensor?, So I can see if mine is on the correct position and if not, try to fit as it has to be?
I leave some pics of mine.
Thank you all.
From rear to front..
From the front to rear
As you see, the car is leveled
Old 11-09-2011, 09:08 PM
taukappa taukappa is offline
Mein Auto: '07 335i
Great post! Thanks for the pics.
Old 02-17-2012, 05:24 AM
bben007 bben007 is offline
Mein Auto: 2009 328xi coupe
Hi there just wondering if any of you can help me...see the attached picture...do you know if this projector will remove that gap you see between the chrome housing and the projector lens? i have circled it with a red line....thnx!
Old 02-17-2012, 06:38 AM
MrAbbs325is's Avatar
MrAbbs325is MrAbbs325is is offline
Mein Auto: 2007 335xi
Thank you, I have been meaning to do this as my passenger side is a few inches lower then drivers. Thanks for the table jig as well as I always went off the wall in the garage to what I felt would suffice.
93' 325is Stage 2 M5 UUC Ltw. Flywheel Cerametallic clutch kit and Pressure plate, ANSA muffler, Bav Auto Headers, Dinan chipped, K&N, Bilsteins sport shocks with Eibach 1.2" lowering springs, Dinan struts, Bav Auto High Perf. Ignition coils, NGK Iradium plugs, 17" Chrome M3 Reps, M3 Rep Kit, 20% & 5% tint , eGay Headlight for the time being, Bav Auto camber Kit, Custom Naugahyde headliner and sunroof.
2007 BMW 335xi 6MT Monaco Blue, Sport Package
1997 Jeep Grand Cherokee 4.0 I6
Old 02-17-2012, 07:35 AM
suju suju is offline
Mein Auto: 328xi coupe
+10 for the effort on different angles.
07 e92 packages - Prem., Sports, CWP and grin ear to ear.
06 e90 - 103k(retired) packages - Prem., CWP and grin ear to ear.
Old 02-26-2013, 07:03 PM
Beauly Beauly is offline
Mein Auto: 328i Xdrive T
I know this is an old thread.... But just bought a gently used 2009 328i Xdrive wagon and drove it for the first time tonight. I feel like the low beam lights are only hitting about 20 feet ahead on the ground. So I will adjust for sure.
Old 01-04-2014, 07:51 AM
drbone641 drbone641 is offline
drbone641
Mein Auto: 01 Z3 3.0, 04 325 it
Same here for a 12 wagon. Low was loooow. thanks
Old 01-04-2014, 01:04 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
A-yesssssss....ride lowered? And if altered in any way, are you familiar with suspension components vis-a-vis headlight aim?
Old 01-05-2014, 08:12 AM
Mein Auto: '06 AW 330xi
If anyone is wondering, horizontal adjustment is under that round, rubber cap on the fender. Lift that cap up and you'll see another spot for a Phillips screwdriver.
Old 01-05-2014, 08:16 AM
ptrcd003 ptrcd003 is offline
Mein Auto: 328i LCI
Any particular reason the E90/92 are set so low? They're almost useless in the stock form...I actually had a bunch of friends park towards a wall and the E90s' cutoffs were very noticeably lower.
Old 04-10-2014, 07:12 PM
eyoussef eyoussef is offline
Mein Auto: E92 328xi
Sorry to bring this thread back to life, but I have a question. I just bought my car a few days ago and tonight was the first time I drove at night, I noticed the passenger side headlight is really high. I attempted to adjust it myself but as I was rotating the screw, nothing was happening to the level of the light. I know the OP said it may be a fine thread and could take several turns but I turned it a lot and it wasn't moving. Has anyone experienced this as well?
Old 04-11-2014, 06:54 AM
The projector carrier most likely popped off the stepper motor ball joint.
Does the headlight beam shake like crazy over bumps?
There's an easy fix for this. Though the dealer will tell you, you need a whole new headlight.
Old 04-11-2014, 07:44 AM
I found similar posts in other forums after doing more research. I'm hoping it's the same issue and it's just a matter of popping it back into place. It's really bugging me so i'm going to take a look after work tonight, fingers crossed it's nothing major.
Old 11-10-2014, 12:23 AM
XKxRome0ox XKxRome0ox is offline
e46+f30fanatic
Send a message via AIM to XKxRome0ox
Mein Auto: '01 325i, '16 328i
Same issue here
2007 e92 328i
Driver side adjusts up and down fine
Passenger side won't move at all
The self leveling no longer happens when the headlight first comes on
And the automatic adjustments when on a sloped driveway or such does not happen anymore
So... the xenon self leveling motor is probably messed up?
No shake at all
Totally shines on trees and street signs
Where is the easy fix?
I am gonna tape the upper half of the headlight lens for now so I don't blind people
[bimmerapp]
2016 BMW 328i - 6MT/M Sport Package/Track Handling Package/Dinan Shockware/Injen CAI/M Performance Exhaust
