Old 10-24-2009, 02:52 PM
poolman poolman is offline
Mein Auto: 525i station wagon
Stoping Oil Useage--Long
Well I have finally found a way to stop the oil from going through my engine. For those who aren't up on my dilemma--back over a year ago my ccv gave up the ghost and the car sucked up some oil while out on the road--I heard all sorts of stuff go on before I could shut her down--
I have replaced the CCV and all hoses now three times to no avail-- the car has used 1 quart of oil every 1000 miles and sometimes more---I tried to run the car with out the cranck case from being evacuated--did this with a tube going to the valve cover and running out the bottom and letting the gases be pulled out like the old days--via a road draft tube--didn't work still used the same amount of oil--tried to use a oil catch can--still used oil---
I started to read around on different Forums and found one idea that caught my eye--Mustang forum talked about a way to remidy the problem by adding more vacuum to the crank case--they used a scavenger system--don't have one of those though
I now have hooked the distribution unit direct to the valve cover and bypassed the ccv and instead of around 5 or 6 inches of vac goinging into the crackcase--there is now around 18 inches---this has ceased my oil useage---I have driven the car for around 2000 miles and the oil is right at the top of the dipstick like the old days. This is due to the vacuum being added to the crankcase--this helps seal the rings from down under and has stoped the oil useage.
I'm thinking that if I drive the car like this for another 30 days--this may seal my rings
back up enough that the ccv valve can be hooked back up again---
Anyone have any input on this idea?
Old 10-24-2009, 04:05 PM
MatWiz's Avatar
MatWiz MatWiz is offline
Psychology Reversalist
Mein Auto: 528
I don't know. You are a genius?
mw
MatWiz
"The greatest thing about the internet, is that you can quote something and totally make up the source." - George Washington.
Old 10-24-2009, 04:15 PM
I'm far from that---just trying to get an idea if I'm thinking right---if this approach will work--or if it's not viable.
I guess a vacuum pump could be hooked up someway to do the job--that would call for someknid of bracket to be configured and a longer belt for driving it--this type of system would have an added benifit of some extra hp gains---but it would be expensive to configure.
Old 10-24-2009, 05:13 PM
edjack edjack is online now
Mein Auto: '97 540i 6 speed
How much vacuum is in the crankcase when the system is properly configured? If just a very small amount (3-6 water inches), it may be that the oil separator is clogged, and is allowing oil to be sucked into the intake, and then burned.
If so, it will eventually ruin the cats.
Old 10-24-2009, 05:34 PM
Normal vac is around 3 to 6 as indicated--but here is the rub--I have changed out the seperator 3 times with new units and each time the same problem---before the origanal ccv went south--never used any oil between changes--afterwards--1 qt every 1000 miles. So there is no way the ccv is cloged---I have also checked the system with vacuum test to make sure everything is sealed properly also
Old 10-24-2009, 07:14 PM
gtxragtop's Avatar
gtxragtop gtxragtop is offline
Mein Auto: 2003 530IA
I do not see how higher vacuum could possibly help with sealing the rings in any way. If for example, you have badly leaking valve seals, high vacuum might be able to greatly reduce the oil leaking past the seals though the valve guides into either the intake or the exhaust.
Ever wonder why 5 series electrical issues are common and complicated.. Spend time here and you will understand why. http://www.bmw-planet.com/diagrams/r...9new/index.htm
Old 10-25-2009, 07:53 AM
I would have thought the very same thing until I started checking around as indicated above---vacuum brought into the crankcase can and will enhance piston ring seal---I'm not smart enough to know why
but there are oil scavaging systems out on the market that do that very thing for hot rods, using
vac pumps. These cars equiped with add on vac pumps hooked into the cranck case will develop more hp
and thats done by evaquating the crankcase of blow by---get the blowby out of the system--the system seals better--this can be proven on a dyno also. Check the following site for a little more info--now of corse I'm not adding a ton of vacuum like in the attached info--just what the engine now produces--but what I have inttroduced solved my problem.
http://www.highperformancepontiac.co...kit/index.html
Old 10-25-2009, 10:27 AM
TemporarySanity's Avatar
TemporarySanity TemporarySanity is offline
Mein Auto: 02 530, 02 540, 07 525
While it's nice to seem to have fixed the oil usage issue, I feel that its only temporarily hiding the real problem. Start with a compression test and a leak down test and go from there.
I discovered I scream the same way whether I'm about to be eaten by a great white shark or if a piece of seaweed touches my foot.
Old 10-25-2009, 11:17 AM
Did a comp test just a few weeks back--all cylinders read right at 180 lbs---car now has 160k miles --runs great and pulls just fine---only thing that I'm trying to rectify is this oil useage that came out of no where--as for a leak down test--I don't have the tools for that one--but I'm going to keep this project going for another few weeks and then go back to my ccv valve and see whats happening--As stated above--Driven the car over 2000 miles like this and no ill affects--just that the oil useage has stoped---got to add when driving at high speed the usage was bad--now driving at high speed no oil is being used--has me hopeful that I can at last get a handle on this problem with out swapping out with a new engine---thats what I had in mind if this didn't work.
Old 10-25-2009, 12:09 PM
Max_VQ Max_VQ is offline
Mein Auto: E39 with a sweet six
Question:
When you say "inches of vac" are you talking water or mercury?
It is my understanding the CCV (measured at the valve cover) is around 3-6 inches of water, and the intake is 18-22 inches of mercury at idle. 18 inches of mercury = 240 inches of water.
Old 10-25-2009, 05:11 PM
Hell if I know which it is--I'm pulling around a 19 on my vac gauge--what ever that is measured by is what
is going on inside the crank case---If this doesn't remedy the problem, there will be an engine swap--Don't want to go through that if it can be helped. Have read of many that have had this same problem come along and bite them--hoping this will work so that others can benifit----will be posting back with the results of course.
Old 10-26-2009, 08:24 AM
I'm pulling around a 19 on my vac gauge--what ever that is measured by is what is going on inside the crank case---
More than likely, we are talking "inches of mercury." (most vacuum gauges measure vacuum in this unit)
You have increased the negative pressure in the crankcase 40x more than stock. I don't think this will be a problem. It should reduce pumping losses and may increase your HP just a little. Many race engines do this.
Please keep us updated on this!
Old 10-26-2009, 09:02 AM
cn90 cn90 is offline
poolman,
Any pics of your setup?
Also did you ever clean the dipstick double channels? Read Post #31 by mad_dexter carefully:
http://www.bimmerfest.com/forums/sho....php?p=4491101
Old 10-26-2009, 09:29 AM
Hey CN90---I haven't a camera to make the pics happen--but what I have done is--used a peice of 5/8 outside diameter rubber vac hose and attached it to the large opening on the distribution unit----the small opening on the distribution unit is sealed with a vacuum cap. The other end of the 5/8th vac hose is inserted into the side of the valve cover that would be used to hook up the ccv valve--so all and all the vac is going straight from the intake to the crankcase without any ccv valve---works great so far---
On the dipstick tube--yes I cleaned it up to speck--even bought a new one to be sure--nothing helped the problem --except with what I have come up with in the above.
Max--on the vacuum increase--on hte link I provided above is info on adding vac pumps to older V* engine's and after dynoing--they were coming away with as much as 30 horse power---so I figure with the right pump added you might come away with 5 hp in one of the I6 cars.
Old 10-26-2009, 02:33 PM
ascott ascott is offline
Mein Auto: 1999 540i
I wouldn't hook the CCV back up again, ever. Regularly check your oil cap gasket and your dipstick o-ring to make sure they don't become huge vacuum leaks and keep going with this.
You may want to add a check-ball type conventional PCV valve and a catch can to the system to prevent you from pressurizing the crankcase under WOT and condense more of the oil out of the crankcase gases to keep them from being burned and possibly fouling a catalytic converter.
I'm considering bypassing the oil separator on my 540 with a catch can and PCV valve. Our oil separator is buried behind the timing chain and difficult to replace or clean if it clogs.
Old 10-26-2009, 03:29 PM
Have thought of doing that very thing Ascott----I would indeed just drive on except for one thing--with this hooked up this way I have codes from both banks 1 and 2 that says the car is running rich---also the cars a little harder to start in the morning when cold---I have checked the crank case through the vent hole in the valve cover for a vacuum leak yesterday---all is sealed and the crank case holds vacuum---so to get the car back into open loop --gotta get the emmisions hooked back the way the car came from the factory---if this doesn't work though--I will drive the car just like it is--I'm still getting good gas mileage and the car doesn't burn one drop of oil the way it is right now---the service engine light is on and I can live with that if I gotta.
Guess time will tell how all this turns out---going to add---before hooking this up like this the exhaust pipe would be wet and gummy with black looking oily exhaust residue--now the pipe is burning so clean you can drag your finger through it and not see a hint of carbon.
Old 10-26-2009, 07:17 PM
M///Chook's Avatar
M///Chook M///Chook is offline
I am the Wumpus
Mein Auto: 1996 E39 535i V8 sedan
If it has good compression (180psi on all cylinders) then you need to perform a leak down test as the next step. This will show you more about the condition of your rings.
I think you've got the vacuum pump idea slightly wrong- the main reason we put vacuum pumps on the older muscle cars and hotrods is not to gain power. Its because when we install performance camshafts, the camshaft has more overlap. This inherently reduces vacuum at idle by a large amount. So crankcase gas evacuation and power-assisted brakes dont work very well with such low vacuum. So we run the vacuum pumps as a substitute.
Car Craft magazine has a lot of good online articles on this (its a hotrod/muscle car magazine), that are worth reading if you can google them up
1996 Carbon black/black BMW E39 3.5L M62 V8 535i -Australia Delivery-only model.
And this months "mods" are:
  • leaky power steering reservoir
  • Cracked windscreen
View my album- http://www.bimmerfest.com/forums/album.php?u=158428
Old 10-26-2009, 07:19 PM
Jase007 Jase007 is offline
Wrenchin' fool ...
Mein Auto: e39 528it
I give you points on the ingenuity scale for sure ! I haven't delved into my CCV repair yet (just passed 180k on the motor) ... but I am sure it is coming.
Hope the results of my pending R&R are different but if I end up with a BMW burning oil like my air-oil-cooled p-cars ... this thread will help.
Sorry for your troubles.
Jason
2000 528iT Sport 5M (mfg. 5/1999) ~ 1990 325iX 5M
BMW CCA member #130075
JScottRacing
Old 10-26-2009, 07:41 PM
If you're coding rich, then you have a leak that's allowing air into the intake tract via the crankcase.
The engine is a closed system with one inlet - the MAF, and one outlet - the exhaust behind the last O2 sensor. That means your inlet for the crankcase ventilation system must be AFTER the MAF. If you're venting from somewhere else, or your oil cap leaks air, or some other spot, then you get extra air in the system, the computer will dump fuel to compensate, and you get an uncontrollably rich situation.
Old 10-26-2009, 08:11 PM
gtxragtop's Avatar
A Leakdown test does not tell you the state of the oil control rings. Only the compression rings.
Old 10-26-2009, 08:14 PM
gtxragtop's Avatar
I'd bet at 18 inches of mercury compared to 3-6 inches of water that your air leak is called blowby.
Old 10-26-2009, 08:24 PM
gtxragtop's Avatar
From your link...
Since the factory PCV system is not used on most race engines because it's less effective than on a stocker, positive pressure in the crankcase builds as engine rpm is increased. The result is pressure on the underside of the piston on the intake and power strokes, which reduces efficiency by offering more resistance to the piston's downward movement in the bore. It also places more stress on the piston rings, thereby reducing their seal capabilities and increasing the chance of blow-by. If that weren't enough, high crankcase pressure also forces oil to evacuate through any seal it can breach.
The addition of a vacuum pump to remove the positive pressure in the crankcase and introduce a few inches of negative pressure (vacuum)
OK, this makes sense when positive pressure builds in the crankcase. In theory, this should not be happening on your Bimmer during normal driving. you did state at one point you tried leaving the crankcase open to the air like the old draft tubes and this did not help. There would not be any positive pressure in this case. I'm still thinking that you
may have bad valve seals. I'd also worry with 18" of vacuum that oil will not flow down the valve guides and you will end up with valves stems scoring /wearing in the guides. You do need some oil to flow into the guides. Note your link states that the vacuum pump adds a few inches of vacuum not 18".
I also forgot to mention that most race engines use low tension 1/16" rings compared to standard engines that use 3/16" standard tension rings. The low tension rings reduce drag which adds HP. But low tension rings also do not control oil as well and can result in higher blowby. Here is a good read on rings. http://www.stockcarracing.com/techar...ics/index.html
How much vacuum should you use? You should check with your engine builder as there may be some special issues or firm opinions that they may have. In general GZMS recommends no more than 15" of vacuum in a drag race wet sump application without pressure feeding oil to the wrist pins. In our own in house testing, anything over 12" seemed to offer relatively nominal increases in horsepower (maybe 15% between 10" and 15").
Why limit vacuum? Engine builders appear to believe that the lack of oil to wrist pins caused by removal of too much oil mist from the crankcase causes wrist pin damage. Some engine builders report fluctuations in oil pressure above 12", we have not noticed that on engines we have observed during testing. However in a recent article, it was suggested that the air velocity passing through the block to heads at the oil return locations causes resistance to oil flowing back to the pan, which could indeed reduce oil pressure. An air line from the fuel block off on a Chevrolet to the valve cover helps mitigate this problem as well as possibly helping to balance the vacuum in the crankcase to that in the valve cover.
Old 10-26-2009, 09:24 PM
bmw_n00b13's Avatar
bmw_n00b13 bmw_n00b13 is offline
Freude am Fahren
Mein Auto: 99 528iA
Very interesting reading. THIS is what I come here for! Not nitrous kits
'99 528i ('98/12 build). 282,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals, increasing amounts of duct tape and glue
'99 540i (grandfather's)
Old 10-26-2009, 09:48 PM
Jason5driver's Avatar
Jason5driver Jason5driver is offline
Mein Auto: E39 hamster w/ pin-wheel
WOW!
I wish there was this kind intelligence on BimmerForums!
Obviously a more mature crowd....
Old 10-26-2009, 10:16 PM
PCV is as old as gasoline engine was invented.
In the early days such as 1930-40 etc., the crank case gas is simply vented to the outside world, causing polution. Thus the idea behind the PCV system.
In the E39, the slope of the hood is more downward (designed to reduce air drag ---> better fuel mileage), BMW engineers brought the Intake Manifold down lower than the Valve Cover, therefore the current stupid PCV setup (the PCV itself is around $80, the dipstick has double channel), complicating the design for nothing.
Let's look at my previous E23 (1983 735i 5sp) PCV design that I posted in E23 forum:
http://bimmerboard.com/forums/posts/216219
Now look more carefully:
The E39 Intake Point (where the PCV enters) is below the Valve Cover:
The E23 Intake Point (where the PCV enters) is above the Valve Cover.
No. 11 is the PCV: it is simply a short rubber hose connecting the Valve Cover to the Intake Manifold (which itself sits above the Valve Cover)!
As long as the PCV Hose climbs uphill (oil flows back down and gas goes up), you are OK.
This means that for E39, it you hook a hose to the Valve Cover and somehow make an Upward U-turn, then downward into the Intake Manifold, it will work because oil cannot climb uphill but gas can pass through the tubing.
So poolman, whatever you do (maybe the long hose prevents the oil from travelling through, but allows gas to pass), if it works, then leave it the way it is. Great trick though!
PS: Jason5driver, you are correct, bimmerfest people are better than bimmerforums! The quality of the posts on bimmerforums is retarded.....a blind leads a blind sort of thing....
