Old 10-25-2009, 04:22 PM
e39BMW e39BMW is offline
Mein Auto: 1997 BMW 540i
m62 Blown head gasket?
So here is what happened.
My car was offline for about 3 days and when i came to start it i noticed a bigger then usual oil spot under the engine (my bimmer has an oil leak somewhere)
So then i started the car, let it warm up for a bit, got out to get something from my trunk and noticed lots of white smoke coming from my exhaust. I let it idle for about 5 more min and white smoke was still there. I reved it to like 3k and much more smoke came out.
The car idles fine and runs no problem, I didnt lose any coolant (at least i didnt notice a change in coolant level.)
Today I was at pepboys so decided to ask the parts guy to look up the price for my head gaskets and he said that the bmw doesn't have replaceable head gaskets.
Is that true...how can a car not have replaceable head gaskets?
Also if the smoke continues to happen or gets worse, ten ill replace it myslef (if they are replaceable lol)
Also i dont have any white or milk colored crap under my oil cap.
Any input will be apreciated,
thanks
Old 10-25-2009, 04:59 PM
spydrz's Avatar
spydrz spydrz is offline
Sandlapper Chapter
Mein Auto: 2013 X1 xDrive35i
You can definitely replace head gaskets.
1984 318i/man./Tornadorot*
1990 525i/man./Alpinweiß*
2001 525i/man./SP/PP/Cosmosschwarz/Sandbeige*
2002 X5 3.0i/man./SP/PP/Sirius/BT/Titansilber/Sandbeige*
2006 330i/man./SP/PP/CWP/Sirius/Blackline/Rear Fogs/Arktis/Grau*
2001 525i/step./SP/PP/CP/CWP/Xenons/Rear Shade/OEM Sirius/OEM BT/OEM AUX/M5 Rear Sway/Bilstein HDs/Beisan Vanos/Rear Fogs/Schiefergrün/Sandbeige*
2012 VW Golf R/Rising Blue*
2013 X1 xDrive35i Alpinweiß/Schwarz/M Sport/Premium/Tech/Dinan Stage 2
*retired
Old 10-25-2009, 05:08 PM
My39 My39 is offline
Mein Auto: 01 530i 5-spd M Package
sounds like a head gasket problem. is there oil in the coolant? you should also be able to smell a mixture of oil and coolant coming out of the tail pipe. another way is checking your spark plugs, they should have oil deposits on them.
Old 10-25-2009, 06:47 PM
bmw_n00b13's Avatar
bmw_n00b13 bmw_n00b13 is offline
Freude am Fahren
Mein Auto: 99 528iA
Isn't white smoke also related to CCV issues?
'99 528i ('98/12 build). 282,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals, increasing amounts of duct tape and glue
'99 540i (grandfather's)
Ill check the spark plugs when i get a chance to.
I just started up my car (after about 10 hours of it being off) and there was NONE smoke coming from tail pipe, only CEL was on...will scan it and tell you guys the codes
Old 10-25-2009, 06:55 PM
I replaced all the gaskets including ccv and intake gaskets about 600 miles away
Old 10-25-2009, 07:04 PM
Just ran obd scan and the code is for cat efficiency which is normal because I have high flow cats.
Old 10-25-2009, 07:21 PM
M///Chook's Avatar
M///Chook M///Chook is offline
I am the Wumpus
Mein Auto: 1996 E39 535i V8 sedan
White "smoke" that comes and goes can also just be condensation or light moisture sitting inside the exhaust system if the car has been sitting for a few days without running.
Dont panic about it unless you get oil in the coolant (or vice versa sometimes) or you notice a distinct loss of power or poor running or severe overheating/pressurisation of the coolant system or the engine starts to drink coolant (and its not spilling out on the ground.) Then panic.
We did the head gaskets on an M62 engine about 6 months ago, and yes, they are as replaceable as a Honda Civic head gasket. But far more expensive and extremely labor intensive. I think from memory it was $400 AUD PER cylinder bank for the gasket kits and new head bolts (and this was a non-Vanos engine) and the dealer had quoted us something like $2000 AUD to do the job. its not something for the backyard mechanic, because of all the factory BMW cam timing tools you need (and definitely more complicated if you had a Vanos-equipped M62, but I've never played with Vanos so I dont know for sure)
So dont stress too much unless the symptoms are catastrophically ominous. It could just be condensation in your exhaust system. Run a search. Other members have experienced the same thing before
1996 Carbon black/black BMW E39 3.5L M62 V8 535i -Australia Delivery-only model.
And this months "mods" are:
  • leaky power steering reservoir
  • Cracked windscreen
View my album- http://www.bimmerfest.com/forums/album.php?u=158428
Old 10-25-2009, 07:26 PM
cool thanks
