Old 10-29-2009, 05:52 PM
NC_Creeker NC_Creeker is offline
Mein Auto: X3 w/6 speed manual
X3 Rear Differential Bushing?
When a rear differential bushing goes out (a clunking sound), are parts number two and three as illustrated in the picture below the issue ???
Part Numbers:
02 RUBBER MOUNTING front left 1 33316770783
02 RUBBER MOUNTING front right 1 33316770784
03 RUBBER MOUNTING rear 2 33316770781
(2005 X3, 2.5i with 6 speed manual gear box)
TIA
Jim
Old 10-30-2009, 06:24 AM
X3-terrestrial's Avatar
X3-terrestrial X3-terrestrial is offline
Aficionado
Mein Auto: '05 X3, '02 M3, '91 E30
Don't think those are the diff. bushings. 2 and 3 look more like the supports and the diff busshings should be in the actual diff. assembly.
Yuo should be looking at this diagram: (final drive)
http://www.realoem.com/bmw/showparts...92&hg=33&fg=05
Old 10-30-2009, 05:05 PM
Thanks for the link.
Looking at the picture below, which part do you think is the one that fails???
Old 11-01-2009, 06:12 AM
Aficionado
I never worked on a diff so I don't know. I'd guess the ones at the drive shaft's end, most probaby is sold by the kit and you need replace them all. I'd recommend that anyways.
