E46 (1999 - 2006)
The fourth generation 3 Series (E46 chassis) was introduced in 1999 and set the standard for engineering and performance during it's years of production including being named to Car & Driver's 10 best list every one of those years! ! -- View the E46 Wiki |
Hey all,
Did a search and nothing has been posted here. I am referring to the sensor located in the lower radiator hose. If you have DIY-ed your cooling system, one way or another you might have purchased a new sensor because there is no way of just replacing the o-ring. There is a buna-N replacement found in hardware store, which can be a bit of snug fit but not a perfect fit. But I found the right BMW part number for this o-ring: 13.62.1.743.299 Yes that's right. You can now just replace the o-ring WITHOUT having to buy a new sensor. Will set you back a whooping $1. This is the same o-ring used to replace the IAT sensor on slightly older E46s. These E46s have IAT in the manifold instead of a 5-wire MAF. Here's a pic. Nothing too exciting really. ![]() Now generally speaking, most of the o-rings found in hardware store (for plumbing and such) are Buna-N not Viton. The material if you compare side by side with this BMW o-ring is very different. Viton has better oil, temp characteristics compared to Buna-N. There are no hard rules as to identifying which material based on color, measure (metric/imperial) or feel of the material. But my educated guess is that this green metric o-ring used by BMW is most likely Viton.
Technik Engineering ASA Stage 1 Supercharged E46 M54B25. NASA TTD So Cal. Track blog: VSETrack
Excellent!
Wow was that ever insightful and right on time! I came out of the office today to find a nice puddle of coolant under my car and pinpointed it to have come from the temp sensor. A quick trip to the dealer up the road and I was back in business. I can't thank you enough for posting this!!!!
-Jay |
Arghhh I wish I had known this 6 months ago when I did my coolant system overhaul!! Oh well, an excellent find!!
Full 1995 530i Part-out! http://www.bimmerfest.com/forums/sho...d.php?t=568506 BMWCCA Member# 451235 (Summer) 2001 330Ci - ZSP (Winter) 1994 530i "Greenie" - LOADED
My sensor is leaking. How do I remove it? Does it just pull out or do I have to turn?
You may have to wiggle it a bit, but it should pull straight out. I just installed a new one last weekend and as I recall it pushed straight in..... no twist. Just be sure to unclip the electrical connector at the top, as you don't want to risk damaging it when pulling.
Very good information. Thanks.
_______________Going to Bimmerfest East AND West ![]() Youtube - Electric Fan Swap/Aux Fan Removal - Projector Retrofit - E46 Bulb Guide |
And a very good source as well.
Hello VINCE!!
Thanks!! I really appreciate this. Was driving home last night, coolant light came on.
Got the car in the garage and took a look and found the leak. I'm driving to Boston next week and need to get this taken care of. Again - thank you for the info. Chuck |
On the flipside, if you do replace the sensor, make sure to also order a new O-ring. I did mine and didn't realize I needed to replace the O-ring as well and ended up with a leak after installing the new sensor.
I would have expected a new sensor to come with a new O-ring. I did a cooling overhaul a while back and had another issue with the sensor. I bought a new lower hose and tried to use the original sensor. It leaked like crazy so I am still using the old hose and original sensor.
Will check with my dealer on the O-ring. Good information! |
Hi, I did a quick remedy of stopping the leak in my temperature sensor by wrapping around with teflon tape. It works ,,it is over a year already and no leaks at all. You can buy teflon tape in any harware store , it is used for sealing the plumbing threads.......
This is great! I went to Lowes and Advance Auto, and neither of them had an o-ring that was the right size. This sure saves me a lot of hassle. Thanks!
We have them available for anyone who is still in need...
Click HERE for more information. ![]() Please let us know if you have any questions! Feel free to shoot me a PM or email. Best, Joe
![]() Have questions? Need answers? Live Chat us! 8:30am to 12:00am Midnight EST sales@ecstuning.com | customerservice@ecstuning.com Customer Service Hours: 8:00am - 8:00pm EST Sales Team Hours: 8:00am - 11:00pm EST 800.924.5172 OEM BMW Part Number Search |
Hi Joe,
This is wonderful. Do you stock them from outside of BMW or do you use the part number of the intake manifold o-ring. Just curious how you do it. BTW, in the alternator & cooling system thread ... I measured a new FAE coolant temperature sensor o-ring at 0.330" ID by 0.115" thick (i.e., 8mmIDx3mmThick) which is the same 8x3 size as the BMW PN 13621743299 intake manifold air temperature sensor. It apparently fits all E39 and E46 vehicles; I'd recommended adding it to your cooling system overhaul recommended parts list. Last edited by bluebee; 08-06-2010 at 01:08 AM. |
We source all of our Genuine BMW parts BMW directly! Thanks, Joe
Just to be 100% accurate...it's not the same o-ring, but very, very close to the original sensor o-ring. I just returned from the bmw parts department where I picked up the new o-ring and the parts guy brough the brand new sensor, took off the original o-ring and we compared the two. They are slightly different color and I believe different material. The new one looks slightly thicker resulting in larger outer diameter and the inner diameter looks slightly smaller. But they are really, really close. So, there is no reason why the new one would not be successfully used as a replacement, but again to be 100% accurate it's not a direct replacement...
Regards, Alex *P/S Maint. and Flush DIY* *Exp. Tank DIY* *P0491 & P0492 Troubleshooting Info DIY* *CVV DIY* *ATF change GM trans. DIY* *FSU replacement DIY* *GM no reverse info * *E46 Jack Stand "Hockey Puck" Adaptor* |
replacing coolant temperature sensor
I am trying to replace the coolant temperature sensor in my 2000 328i which is located in the lower radiator hose. As many other posts have stated, mine is leaking. However, when I went to do the "easy" swap, the old sensor won't come out. I pinched the 2 little levers on the side to release it and pulled but it won't budge. Any ideas how to get it loose? Also, does this sensor have any control over the electric fan cooling the ac?
Holy crap, I wish I'd seen this thread a year ago. Stealership only sells the sensor with the o-ring, at a hefty price (~$40?)
Anyway, to your question, shobbs: This should be pretty easy to take out, compared to other items in normal DIY. Make sure the lead is off first, so you know what you're dealing with and don't frig it up. Then, get a flashlight in there to make sure you see what your are squeezing to pull it. And, make sure you aren't doing the classic passenger pulling-the-handle-before-unlock routine with the side clips. They have a good bit of travel, but need full disengagement prior to pulling to avoid clip flex.
![]() #232
Now tell them how much you will charge them to ship it to them.
I didn't really expect them to respond to that one.
Same Sensor
Is the pictured Sensor the same as the Sensor on the top of the Bottom Radiator Hose ?
Thanks |
#25
ECSTuning Shows A Diagram For The Sensor at the Intake.
Are both that Senor and the one on top of the Radiator hose the same Sensor [hense same Oring]. I just replaced the ORing on the Sensor on top of the Radiator hose with a Dorman 31. It did not stop the leak and the dealer says they "Don't sell the ORing seperately" Thanks In Advance !! |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
