Old 10-31-2009, 04:40 PM
W2RKJ W2RKJ is offline
Mein Auto: 2011 E92 / 2014 F25
Dash storage bin
Greetings to all. Here's a question for the pro's. I am installing a transceiver in my 08 E83. I have placed the radio itself in the left rear compartment where the other electronics are located. I am planing on installing the remote head unit and microphone in the dash storage bin for maximum concealment. The question is, to remove the compartment, am I correct in understanding from posts in this site that the front vent plate has to be removed first to enable me to get to screws that will remove the compartment for access?
Old 10-31-2009, 05:20 PM
Mein Auto: 2004 X3 2.5i
That's correct.
That vent panel is easily disengaged by grasping it at the upper corners and pulling slightly down and out.
You can then see how to remove a cable end attached to it, and set it aside.
The 2 screws retaining the storage bin are fairly obvious. (Plastic moulding pieces on the base of the bin provide the other means of support by interlocking with the dashboard frame.)
On reassembly, make sure that the foam gaskets around the vents seal properly as you slide the vent panel back into place.
Old 10-31-2009, 07:49 PM
Evlengr's Avatar
Evlengr Evlengr is offline
Ukemi - that's how I roll
Mein Auto: 2013 Audi S4 2010 MT MCS
1000 Words
Hope this helps, since picture are worth a thousand words.
Name:	HU Install 001.jpg
ID:	206644   Click image for larger version
Name:	HU Install 002.jpg
ID:	206645   Click image for larger version
Name:	HU Install 003.jpg
ID:	206646   Click image for larger version
2013 S4 Loaded (and NO RFT's) Awesome is an understatement
2008 MT X3 RIP you were a faithful sidekick and will be missed.
2007 AT X3 RIPOS
2005 GC
2000 Jeep Cherokee
1997 Twin Turbo RX-7
1984 GTI Wolfsburg Edition Neuspeed and more
Old 11-01-2009, 07:12 AM
Thank you both, that's exactly what I needed. Now if I can snake the wires down to the console area I'm good to go. I really appreciate it.
