Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > 5 Series DIY
5 Series DIY
Knowledge Is Power! ~ The place for do-it-yourself threads on a variety of topics. Start a thread describing a particular job (oil change, cooling system overhaul, brakes, shocks and springs, etc.) or search for one you need help with!
Old 11-01-2009, 04:03 PM
Fudman's Avatar
Fudman Fudman is offline
CCV Replacement on an M54 (E39)
Many thanx to Aioros, Cn90, Lbert, and others who have written extensively on this topic. Their writeups gave me the courage to attempt this myself. This DIY is specifically for M54 engines (2001-2003), which have not gotten the same attention as the older M52 and have some slight differences in procedure. This procedure is only for replacement of the CCV and hoses, and is specific to the insulated variant. Note: This procedure intentionally minimizes non-essential removal of components (i.e. intake manifold, oil filter housing, etc.). While space and access is difficult, it is not impossible. Removing things like the oil filter housing can improve access. It took me over 8 hours over two days to do this job but I took my time, documented everything, took pictures and was very, very careful. Knowing what I know now and following this procedure, I can probably do it in under 3 hours now. Absolutely NO technical knowledge of BMWs or auto repair experience is required (as I have very little of either). Caution is the key as there are occasional steps where things just don’t go simply or easily. I have developed workarounds for several of those. This procedure simply documents what I did and is for informational purposes only.
Tools
• T-40, T-27 & T-25 Torx
• 6mm, 10mm, & 13mm sockets
• Ratchet -1/4" & 3/8”
• Extension bars, various lengths - 1/4" & 3/8”
• ¼” drive handle
• Small mirror (absolutely necessary!)
• Assorted flat blade screw drivers in different lengths
• Magnetic pick up tool (optional)
• Small blade knife or cutter (for old hoses)
• WD-40
Parts
• 11 61 7 533 400 Pressure Regulating Valve - CCV (insulated)
• 11 61 1 533 398 Vent Pipe (insulated)
• 11 61 7 533 399 Connecting line (insulated)
• 11 61 7 532 629 Vent hose (insulated)
• 11 61 7 504 536 Return Pipe (insulated)
• 11 43 1 740 045 O-Ring, Oil Dip Stick Tube to Oil Pan
I should’ve replaced the throttle body gasket but they didn’t have it in stock and I didn’t want to wait to button her up. Oh well! Note that the RealOEM part #6 vacuum hose is not required. In fact, the connection point on the insulated CCV is capped and hidden under the foam jacket.
Here is what I did:
1. Undo the long spring clip to remove the filter housing cover and and the cabin air filter. Squeeze and remove the small spring clip on the bolt at the front housing support. Remove the sensor connector and then remove the filter housing by pulling forward and store
2. Remove the fuel rail cover by removing the (2) plastic caps and the (2) 10mm bolts underneath the caps. Remove the fuel rail cover and store.
3. Remove the Mass Air Flow sensor (MAF) (Ref. Bentley 130-33) by disconnecting wiring harness to MAF sensor (push down the metal clip and pull the connector). Loosen the hose clamps (6mm or flat blade) between MAF and upper air intake boot and the air filter box. Remove the MAF to give you the space to remove the air filter box (next step).
4. Remove the air filter box assembly. Detach wiring harness behind air filter box
Remove 10mm bolt on air box base. Remove both air filter box and reassemble the MAF and air filter box as a single unit. Note the air filter box can be difficult to remove without removing the MAF because of insufficient space to pull the components apart.
5. Remove upper air intake boot by loosening the hose clamp (6 mm or flat blade). Carefully disconnect the vent hose coming off the top of the upper air intake boot. This took me over 20 minutes of gently prying the elbow off with a screwdriver to avoid damaging the boot. Maybe I should’ve just yanked on it…
6. Remove the lower air intake boot by loosening the two hose clamps. Some DIYs say that you must replace the lower intake boot. I didn’t want to spend the extra $35 so I was careful not to damage it during removal. Access to the second hose clamp screw requires removing a small cable support (10 mm bolt). Note that the boot has a large rubber tab at its base. This tab aligns with guides located on the throttle body port. Align the tab with the guides when reassembling.
7. Remove the oil dipstick guide tube by cutting off CCV hose from the dipstick (it’s much easier than removing it!). Remove the 13mm bolt holding oil dip stick bracket. Disconnect a wiring bundle from the support bracket. Replace the O-ring at its base. No oil will spill as long as the oil pan is not overfilled. Insert a plug (I used tin foil) on the hole to prevent anything from falling in. Clean the guide tube going to the CCV with a flexible rod and clear with compressed air. If you drive in cold weather, you will probably find yellow-white oil condensate (“mayo”) inside this tube. This is why you are changing to the insulated CCV.
8. Remove the wiring harness box by removing (1) 10 mm bolt and (2) 10mm nuts. One of the nuts is located at bottom right of the throttle body, next to one of the throttle body bolts. Use a mirror to view the location. The wiring harness connectors have a metal locking wire clip. Push down and pull on the connector to disconnect. To re-install, insert connector without touching metal clip until you hear it click into place. Several cables leave the front of the wiring box. Disconnect those electrical connectors that terminate toward the front to allow freedom to move the wiring box to the rear. Label all connectors to simplify reassembly. One cable has three connectors, one at the top of the radiator and the other two connectors at the front right of the radiator. Tie the two connectors together with a 24” string before you pull them to get slack. The string is so you can pull them back through when you’re done.
9. Remove the throttle body by removing (4) 10mm bolts on the corners of the throttle body. Move it aside (to the rear) to access the CCV.
10. Remove (2) T-25 screws that hold the CCV in place. Then cut the hoses to allow removal of the CCV. When removing the old hoses from their connection points, it is far easier to simply cut or break the old locking rings with a screwdriver than to try and squeeze the locking rings to remove them. Once the locking rings are broken, simply pull the hose off. You will find most of the hoses to be somewhat brittle, which is why you are replacing them.
11. Warm weather uninsulated CCVs can skip this step I installed the insulated CCV and there is barely room to put it into place due to the foam insulation jacket. Since the connection to the connecting line requires that you rotate the CCV to lock the connection, I decided to modify my insulated CCV by cutting off about 1/8” of the foam jacket on the flat circular disk side of the CCV with a razor. I did not cut through the foam jacket, I just removed enough of the foam so the surface is flat (see photo). This creates enough room to rotate the CCV when in place. This makes a HUGE difference.
12. Installing the connecting line is the most difficult. It requires you to rotate the line about 1/3 turn to lock the line onto the CCV (practice this connection process on the bench). The other hoses use the locking snap connectors that just insert and snap to lock. After trying for over 2 hours to assemble these parts in their location , I was unsuccessful and decided to modify the locking mechanism. Use a Dremel tool and a sanding cylinder to sand the two retaining ridges on the CCV nozzle smooth from about 1” long to about 1/3 inch long (see photo). This simply reduces the rotation required to lock the connecting line to about 1/8 turn (~45 degrees). Mark the spots with paint where the connecting line aligns with the CCV nozzle to aid in assembly (see photo). Insert the connecting line into the original position from above the intake manifold. Much wiggling and bending of the line is required to get it into place. Once the lower connection is in place, insert the CCV into place. Align the marks, insert the hose into the CCV and rotate the 1/8 turn. This whole process took 10 minutes (vs. over 2 hrs!) with a minimum of effort after modifying the parts! Insert the upper connection line to the engine nozzle until you hear a click. Insert the CCV screws and tighten.
13. Remove the old hoses and install the new return pipe to the top of the engine. The other end attaches to the small branch nozzle at the top of the connecting line. Insert each hose connector onto the connecting nozzle until you hear a click.
14. Remove the old vent pipe and insert the new vent pipe down into the same location. The 90 degree turn is at the top and the angled turn is at the bottom. Align the lower vent pipe connector to the lower CCV nozzle, insert and push until you hear the click. The upper vent pipe connection connects to the valve cover in the same way.
15. Work backwards from Step 9 and it is clear sailing from there. When reconnecting the wiring cables, pull the string to pull the connectors out from the radiator. Be sure to route cables so they are not exposed to the fan. Make sure the right cable goes to the right connector.
16. Prepare the oil dipstick tube by inserting the vent hose onto the branch muzzle on the dip stick tube. The vent hose does not use a locking ring and simply inserts onto the nozzle. When reinstalling the dip stick, you must make sure that the one connector that is attached to the wiring box (all others are cables exiting the wiring box) is disconnected to allow you access to reconnect the upper end of the vent hose to the bottom of the CCV. Insert the hose connector onto the CCV nozzle until it clicks.
When I was done, there were no parts lying around (a good sign). I fired the car up, she purred like always and no CEL lights were lit. A short drive confirmed that I didn’t screw anything up. I don’t notice any difference in the way she runs but there was nothing wrong before the change. Hopefully, I won’t be blowing the black smoke that I had last winter. Hopes this helps someone who does this job on an M54.
ID:	206738   Click image for larger version
ID:	206739   Click image for larger version
ID:	206740   Click image for larger version
Old 11-01-2009, 04:14 PM
cn90 cn90 is offline
Mein Auto: 1998 528i 5-sp 103K miles
Thank you for such a wonderful DIY. I wrote one for M52, but your M54 CCV write-up is fantastic.
Good addition to the Library!
Old 11-02-2009, 05:51 AM
GSA1's Avatar
GSA1 GSA1 is offline
Mein Auto: '02 E-39
here is the diagram and description of parts
No. Description Supplement Qty From Up To Part Number Price Notes
01 Pressure regulating valve 1 11617501566 $72.04
For vehicles with
Cold-climate version
S842A=Yes
01 Pressure regulating valve 1 11617533400 $82.22
02 Vent pipe 1 11611432559 $32.16
For vehicles with
S842A=Yes
02 Vent pipe 1 11617533398 $35.10
03 Connecting line 1 11617504535 $42.34
For vehicles with
S842A=Yes
03 Connecting line 1 11617533399 $42.34
04 Vent hose 1 09/2003 11151437641 ENDED
04 Vent hose 1 11157532649 $19.21
For vehicles with
S842A=Yes
04 Vent hose 1 11157532629 $19.21
05 Oval head screw 2 07/2006 11611705032 ENDED
05 Screw K60X22 2 11617533331 $1.09
06 VACUUM HOSE BLACK 3,5X1,8 ? 11727545323 $18.52
06 VACUUM HOSE BLACK 3,3X1,75 ? 51731257971 ENDED
06 VACUUM HOSE BLACK 3,3X1,8 ? 11747797175 ENDED
07 Return pipe 1 11617504536 $42.34
Old 11-02-2009, 05:55 AM
spydrz's Avatar
spydrz spydrz is offline
Sandlapper Chapter
Mein Auto: 2001 525iA
Subscribed.
1984 318i/man./Tornadorot*
1990 525i/man./Alpinweiß*
2001 525i/man./SP/PP/Cosmosschwarz/Sandbeige*
2002 X5 3.0i/man./SP/PP/Sirius/BT/Titansilber/Sandbeige*
2006 330i/man./SP/PP/CWP/Sirius/Blackline/Rear Fogs/Arktis/Grau*
2001 525i/step./SP/PP/CP/CWP/Xenons/Rear Shade/OEM Sirius/OEM BT/OEM AUX/M5 Rear Sway/Bilstein HDs/Beisan Vanos/Rear Fogs/Schiefergrün/Sandbeige*
2012 VW Golf R/Rising Blue
*retired
Old 11-02-2009, 06:09 AM
GSA1's Avatar
Mein Auto: '02 E-39
thanks for the diy. this will be a big issue for our cars as the weather gets colder. what was the condition of the old CCV? was there sludge/mayo in the lines?
Old 11-02-2009, 06:38 AM
'lowkillz's Avatar
'lowkillz 'lowkillz is offline
Mein Auto: 2002 525i
Thank You
Nice write-up. I will be doing this very soon. Where did you order your parts from?
Old 11-02-2009, 08:14 AM
Fudman's Avatar
I found a little bit of the mayo in the return pipe. None in the others and I have not autopsied the CCV yet. I suspect that warm weather driving may have cleared a lot of it out. I never had any driveability issues other than black smoke at startup (in winter only)and higher than normal oil consumption (previous e39). All the smoke issues clear up in the summer. This was primarily preventative maintenance.
I ordered my parts from Bill Dodge BMW in Westbrook ME because I wanted BMW parts. They offer ~40% off the RealOEM list price. I think I paid around $135 for everything I listed (except the O-ring which I bought locally). Call them (207-854-3200) and ask for Dan in Parts to set up an account (no cost). That's it. 40% off everything.
Old 11-02-2009, 09:04 AM
kingbled kingbled is offline
Mein Auto: 1999 540i 6speed
good job man....nice writeup it will be a help to someone on here...You are right about Cn90...He is the man I see him doing all kinds of things.
Old 11-02-2009, 09:30 AM
nyclad's Avatar
nyclad nyclad is offline
Mein Auto: 2002 530i Sport
Good write up! I'm hoping to do mine, provided the parts get here in time, this upcoming weekend.
Thanks,
Steve
Old 11-02-2009, 09:01 PM
Jason5driver's Avatar
Jason5driver Jason5driver is offline
Mein Auto: E39 hamster w/ pin-wheel
Awesome job!
I am getting ready to do this!
Jason
Old 11-26-2009, 05:35 PM
spydrz's Avatar
Sandlapper Chapter
I just ordered the parts for this. Smolck over on the E46 forum has a GREAT set of videos on how to do this. This M54 writeup is amazing, combine it with these videos and you'll have the needed info to make this as easy as can be.
*retired
Old 11-27-2009, 09:13 AM
Edgy36-39's Avatar
Edgy36-39 Edgy36-39 is offline
Constantly Learning
Mein Auto: 1999 M3, 2002 M5
Thanks for the fantastic write-up.
I LIKE OLDER BMWS, PLEASE HELP ME:
Fern Green 99 M3, Conforti Shark Software, Conforti CAI, Dinan Exhaust. Stamped LTWs, 235x40 square, OE Hella heads, ///M Pedal Kit, Clear Corners, OEM Rear Spoiler, CD43 stereo. MRegistry listing here.
Le Mans 2002 M5, Black/Titanium, Rogue SSK, Dinan exhaust, PSS9 coilovers, Euro rotors, iPod integration. MRegistry listing here.
Old 12-15-2009, 04:32 PM
spydrz's Avatar
Sandlapper Chapter
Thanks, just finished my work on this today.
*retired
Old 12-15-2009, 04:49 PM
How did it go?
Did you use the cold weather version?
Jason
Old 12-15-2009, 04:53 PM
spydrz's Avatar
Sandlapper Chapter
Originally Posted by Jason5driver View Post
How did it go?
Jason
I did get the cold weather version...but it arrived with half of the clamshell sheath hanging off (it's just secured by o-rings). So I just removed it and proceeded normally...we rarely get below freezing here and most of my travel is in the southeast.
It was a real pain though...and I've done some pretty intense repair work in my day. I did call my mother and tell her to go ahead and sell her garage queen E46 before it needs this!!
*retired
Old 12-15-2009, 04:56 PM
LOL!
My cold weather CCV is waiting for me to install it next week.
And, it gets pretty cold here..
Jason
Old 12-15-2009, 04:58 PM
spydrz's Avatar
Sandlapper Chapter
LOL!
Jason
It was a great opportunity to clean out the ICV and TB...and they both needed it...
Might as well add a few pics...
ID:	211902   Click image for larger version
ID:	211903   Click image for larger version
*retired
Old 12-15-2009, 05:58 PM
16valex's Avatar
16valex 16valex is offline
Mein Auto: 530I/5SC 97-528/5
Cold wheather or not still going to fail, so don't even bother paying the extra money. The so called "cold wheather" by BMW is the biggest design flaw ever seen, flimpsy, no R value whatsoever, difficult to install. Save your money and have a real cold one instead.
Old 12-15-2009, 06:24 PM
masaled masaled is offline
Mein Auto: 03 525i, 98 M3, 00 XTTERA
Nice DIY write up Fudman.
At what mileage should one expect the CCV to go out, or what symptoms should I look out for?
Infor. much appreciated
2003 525i M-Sport 5Speed (DINAN 5)
Dinan CAI, Stage-3 Eng Sw., HFT Body,FF Exhaust, & Mats. M5 Rear Sway Bar & BeastPower Rear Bracket. Mason Eng Front Strut Bar. 545i SSK. CDV Deleted. BMW OEM M-Tech Kit. Rear Shade. Connect2 BlueTooth. DICE iPod Silverline Pro & 2point5 Spec.Dock.
Old 12-15-2009, 08:25 PM
Wow!
Yours looks way bad!
Huge build-up!
Did you notice a difference after installing the new one?
Jason
Old 12-16-2009, 04:03 AM
Fudman's Avatar
Mileage is anytime. it all depends on how many short trips (<5 miles) you do in cold weather with how many long trips (> 10 miles) in between. The cause of CCV failure is condensation of oil vapors in the CCV itself. See spydrz pix for details. Can happen anywhere but is worst in cold climates. As 16valvex, the design "fix" is cheesy and a stopgap measure at best. But it is better than the original design. The real solution is to avoid short trips in cold weather. Short trips cause the oil condensation, long trips burn it off. Symptoms of CCV failure or clogging are increased oil consumption, black smoke in exhaust (typically at startup), etc. Cracked CCV hoses can create all sorts of running and idling problems due to vacuum leaks. The worst case scenario is engine hydrolock but that is rare and is typically where it is REALLY cold.
Old 12-16-2009, 05:15 AM
spydrz's Avatar
Sandlapper Chapter
Wow!
Huge build-up!
Jason
Not a huge difference...it revs a bit more freely...but that could be due to the cleaned ICV/TB. BTW this car has had 5k oil changes from new (94k miles now).
*retired
Old 12-16-2009, 01:22 PM
spydrz's Avatar
Sandlapper Chapter
BTW, if anyone doing this wants a cold weather unit, I have the brand-new clamshell foam cover and o-rings from mine. Shoot me a PM and we can work something out since I have no use for this cover.
*retired
Old 12-16-2009, 01:40 PM
poolman poolman is offline
Mein Auto: 525i station wagon
I just bought a new one the other day from Crown BMW of Greensboro--they told me that all of the new ccv valves have the cover on them at no extra charge.
Old 12-16-2009, 01:41 PM
spydrz's Avatar
Sandlapper Chapter
Interesting...
JD emailed me after I ordered this one and asked if it was the right part for my car, since I didn't have the cold weather CCV listed under my VIN.
*retired
