Old 11-04-2009, 06:52 PM
bmwlover1985 bmwlover1985 is offline
Mein Auto: ...
led for license plate
any luck on this, i bought this item and for some reason the connection is not right and doesnt work please help
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
I know it says it will work for 650 but i tried everything and it doesnt
Old 11-04-2009, 07:03 PM
famous650i famous650i is offline
Mein Auto: 2008 Mercedes Benz S550
Those led are bull ....bought the same led and they last 3 days. 60 dollars went down the drain
Old 11-05-2009, 03:22 AM
md7562 md7562 is offline
Mein Auto: 2011 M3 Vert
Don't know about those, but LEDs gave me nothing but headaches. If they worked they didn't draw enough current and gave me constant warning indications.
Old 11-05-2009, 05:04 AM
Simon-Munich Simon-Munich is offline
Mein Auto: 650i X-Drive (F13)
Hi,
just buy the LED Plate-Lights from 1 Series (Faclift Modell). You have only to cut a piece of plastic from the connector. It fits perfect an ther will appear no warning in the BC.
I have done this on my own 6 Series
Simon
Old 11-05-2009, 06:57 AM
Prost's Avatar
Prost Prost is offline
Mein Auto: 06 650i, 08 MINI ClubmanS
Originally Posted by Simon-Munich View Post
Hi,
Simon
More details please...also, what is the parts number?
Old 11-05-2009, 09:01 AM
PEnglish11's Avatar
PEnglish11 PEnglish11 is offline
Pete
Mein Auto: '06 650i Conv
Buy it @ E92 Lighting
Buy it from E92 lighting (http://www.e92-lighting.com/products...RA-301-26.html)
Perfect fit, no modifications, no error codes. Only issue is that the light may be too bright!
PEnglish11 / Pete
2006 650i - Automatic - Black Saphire Metallic with Cream Beige Dakota Leather
Factory Options: Sport/Cold Weather, Prem Sound Pkgs & Sat Radio
Personal Mods:
20" Miro M6 rims; Red MGP caliper covers; Britalman cat-back exhaust; DINAN High Flow Air intake, throttle body & stage 3 software; RPi scoops; MTec V2 angel eyes; LED lighting; 70% window tint; //M Steering wheel; OEM iPod interface; //M footrest & pedal pads; //M3 Shifter
Old 11-05-2009, 09:13 AM
Zack G.'s Avatar
Zack G. Zack G. is offline
Mein Auto: 08 650i
Just saw some pics of it installed on a 6er. I think that since there is no bumper "stopping" the led lights reflection from hitting the ground, it will probably not look as good as it would on a 3 series or 5 series, where the bumper is positioned right after the license plate so that the light doesnt light up the road too.
Old 11-05-2009, 11:07 AM
Mein Auto: ...
guys that link you put up of the one from e92 lighting is the same exact thing that i ordered. IT simply does not work. The connection does not fit, even when using that little adapter cord, there just isnt a place to hook up to.
would like more info on the led lights from the 1 series
Old 11-05-2009, 11:27 AM
Hi,
Part number: 63267193294 --> $15.33
please be prepared, that it is neccesary to cut a piece of plastic from the LED Housing.
It is one year ago, but it was simple. You will need a Tool like a file or a "Dremel"
Greetings from Munich / Germany
Simon
Old 11-05-2009, 11:41 AM
Only the LED-Lights from the 1 Facelift-Series will fit! There is allready a electronic resistor integrated, that the BC will not bug you.
When you have both Parts (old an new one) in your hands, you will see a small Plastic-nose on the new one -remove it. So that the new part looks exactly like the old part.
Old 11-05-2009, 11:46 AM
Mein Auto: ...
i called bmw and the oem light for the 1 series tag light is the same number as you except it ends in 93 instead of 94 im confused here
Old 11-05-2009, 11:59 AM
63267193293 is for:
1Series E82
3 Series, E90, E91, E92, E93 ---->WRONG!
63267193294 is for:
1 Series E81, E87, E87 Facelift ---->RIGHT!
Old 11-05-2009, 01:24 PM
Mein Auto: ...
lights
well does it look like this????
this is what i have but i am guessing not use the connector cord and just cut the tabs???
http://www.e92-lighting.com/products...TRA-301-1.html
or
http://cgi.ebay.com/ebaymotors/ws/eB...5460&viewitem=
please please post pics when you are back
Old 11-05-2009, 05:21 PM
Mein Auto: ...
munich here is the part on the new facelift led tag lights
http://www.realoem.com/bmw/showparts...56&hg=63&fg=30
number 1
Old 11-05-2009, 06:18 PM
Concur. I bought their junk with no success.
Old 11-05-2009, 06:44 PM
Mein Auto: ...
led lights
im interested to see the 135 oem led lights, i dont want to order them at bmw because i cant return them if it doesnt work, i hope somebody can post a pic of one!!!
Old 11-05-2009, 11:11 PM
number 1
This is not the right Part Number! You will need 63267193294 (!!!)
The Size of the needed Part is much longer then the size of the wrong Part!
You can trust me, the Part number above is exactly what you need! Do NOT try to use other Parts, they will not fit!
Old 11-06-2009, 02:02 PM
Prost's Avatar
Where to get that?
Old 11-06-2009, 02:56 PM
Mein Auto: ...
Yes that is correct part number but thats not the one for the 1 series its the one for the rdash that i posted,
just post pics when your home
Old 11-07-2009, 05:44 PM
mike6auto's Avatar
mike6auto mike6auto is offline
Mein Auto: 97 850ci
i got those same ones from e92lighting,same prob the plug dose not fit they are still sitting in my trunk.
long gone
Old 11-09-2009, 07:54 AM
AEK AEK is offline
Mein Auto: 05 645 Cabrio
Smile
I just ordered this light from the local BMW dealer and It will be here later this week. He said it came up on his system for a Z4 and not a 1 series.
I will post back with my success or failure to get it to fit.
Old 11-09-2009, 03:44 PM
Mein Auto: ...
wow i like where this thread is going, please post pics there are so many people with sixes that want this to work. i am glad you took initiative to buy the lights, so these are off a z4 with leds?
Old 11-09-2009, 05:07 PM
wolfsden wolfsden is offline
Mein Auto: 2005 BMW 645ci
I bought the same one from e-92 lighting. Not only did the plug not match but when I push the light in place it would not remain in, it would slowly pop back out. I returned it and got my money back after having to continuously call him for my refund.
Old 11-09-2009, 05:44 PM
Mein Auto: ...
pics please
Waiting on pics of what you did!!!
Old 11-09-2009, 08:04 PM
Zack G.'s Avatar
Mein Auto: 08 650i
I think for the 6er, you can't go with R-Dash ones because it will be TOO BRIGHT and the light will light up the road. I think this will look bad as you don't want to light up the road behind you since they are so bright (atleast I wouldn't).
Its best to go with some less bright LED light, anyone know of something thats not as bright as the R-Dash brand?
