Old 11-06-2009, 02:17 PM
shamernj shamernj is offline
Mein Auto: 2006 X3 & 2008 Z4 3.0si
Another Speaker Thread
OK, I have finally given up on Bavarian Soundwerks ever producing an X3 specific speaker. They've been saying "soon" for the past two years.
I came across the Rockford Fosgate T142 and the mounting holes look like it might actually work with the X3 without any modification or additional bracket being required.
http://www.rockfordfosgate.com/produ...n_US&p_status=
Attached (assuming I did it right) is the cutout for the speaker giving diameter etc. Anybody out there measured their original speaker and can comment on the likelihood of these fitting? The depth is 1.79 inches which looks good but not sure about the sensitivity of 86 dB using the current amps though - I like my music loud. The speakers can be obtained for much less than the $199.99 on the website.
evlengr - just in case you're wondering I don't think your reputation was at all tarnished by that other thread and your opinion here would be very welcome.
Thanks,
Stuart
2006 X3, Gray with Black leather, Premium, Sport, Cold, Xenon, Navigation, Privacy, Tow Hitch, Ipod & Bluetooth
Old 11-06-2009, 03:02 PM
Evlengr's Avatar
Evlengr Evlengr is offline
Ukemi - that's how I roll
Mein Auto: 2013 Audi S4 2010 MT MCS
Thanks,
preciate the comment. I have the speakers in a box at home so I can give you exact measurements and a picture later on if that will help. Probably this evening some time.
EE
2013 S4 Loaded (and NO RFT's) Awesome is an understatement
2008 MT X3 RIP you were a faithful sidekick and will be missed.
2007 AT X3 RIPOS
2005 GC
2000 Jeep Cherokee
1997 Twin Turbo RX-7
1984 GTI Wolfsburg Edition Neuspeed and more
Old 11-06-2009, 03:06 PM
that would be great - thanks,
Stuart
Old 11-07-2009, 04:56 AM
Evlengr's Avatar
4 inch door speakers
Sorry long week, fell asleep last night. The speakers I installed had a depth of 1 7/8" and were 4" in diameter. Attached are pictures of the stock speakers. Look closely and you can see I took pictures of inner and outer ring as well as top shots.
Hope that will give some guidance. Sorry I never took pictures of original door installs as I was focusing on the project and a little nervous. Actually pretty easy as long as you use a plastic or nylon pry tool set as to not chip the wood inserts. And never never tear those darn vapor barriers. Lol.
Name:	4 inch or 100mm spkr 001.jpg
ID:	207447   Click image for larger version
Name:	4 inch or 100mm spkr 002.jpg
ID:	207448   Click image for larger version
Name:	4 inch or 100mm spkr 003.jpg
ID:	207449   Click image for larger version
Name:	4 inch or 100mm spkr 004.jpg
2007 AT X3 RIPOS
2005 GC
2000 Jeep Cherokee
Old 11-07-2009, 08:47 AM
codog2 codog2 is offline
Mein Auto: 5
Are those for the front doors? I assume you are keeping the head unit and amplifier stock? Let us know how much of a difference the just replacing the speakers make
Also those Rockford's are two way speakers? Will that work - aren't the factory speakers just one way? Is there a crossover from the factory to direct the sound to the tweeters on the dash?
General questions about removing the door panels. What precautions do you have to make about the side airbags? Are they in the front doors themselves?
Old 11-07-2009, 10:18 AM
Thanks. I took the two pictures, scaled them and then superimposed them. It looks like the holes match up but not sure about the depth. The attached picture shows the total depth to be 2.5 inches with 0.7 inches of that sticking out into the car.
Also concerned about the specs - primarily the 86 dB sensitivity. Anybody tried using speakers of this sensitivity with the stock amps?
They're two way with an internal crossover so I don't think there would be any issues from that perspective in getting them to work.
Thanks,
Stuart
Old 11-07-2009, 04:08 PM
Evlengr's Avatar
Thanks,
Stuart
The spl sensitivity is pretty low. I'm not sure they will give you the improvements you are looking for. I would suspect in the low 90's is much better.
Co-ax speakers are fine.
Let me do some quick research and get back to you.
2007 AT X3 RIPOS
2005 GC
2000 Jeep Cherokee
Old 11-07-2009, 05:59 PM
Evlengr's Avatar
Ok, here's what I have come up with based on experience. I couldn't find the specs for the internal amplifier. The business cd sound system is what I have so that is my base line.
It seems to me that it is a low level amp because the "subs" are set to 2 ohms and the door speakers are 4 ohms. For those who want to know the long winded engineering reasoning pm me. This is the abridged non sleepy version.
IMO the speakers you have selected will work with some minor exceptions:
  • Very tight fit because of the deep magnet on the back and the extruding tweeters
  • Low spl will work, but will overdrive the amp and at higher volumes may cause distortion
  • These will sound much better with an outboard amp.
  • You can add an outboard amp later without changing the H/U
  • This is what one board member recommended and looks great on paper http://www.crutchfield.com/p_236REQ5...428&tab=review
What most people don't realize is that you can upgrade your sound system in stages until you achieve the quality you like. An old saying applies: Plan your work, and work your plan.
If you only plan to do the speakers than I recommend a higher spl and different speaker. If not than go with them and plan on an amp that will work as a 2x1. Meaning one that will handle both bass and full range seperately. Alpine makes anumber of good amps from $200 to 600 that will do a good to great job.
If you are doing the work yourself and want to keep the original H/U expect to spend $800 to $1600 for a full system.
That speaker is good but a bit overkill without an external amp.
Give some thought to these as they will be very efficient, but you will need to do both front and back to keep the amps impedance balanced.
http://signature.crutchfield.com/s_1...9i.html?tp=102
I have to warn you --they are bright on the highs. Some people love them and others hate them. Kind of like our X3's, Lol.
If you can listen to them somewhere I would. Technically speaking they would work much better then the RF and are cheaper.
2007 AT X3 RIPOS
2005 GC
2000 Jeep Cherokee
Old 11-08-2009, 11:09 AM
Thanks Evlengr. I found the attached diagram of the Kappas online. It looks like the total envelope is almost identical to the Rockfords so they should fit. I'm not a fan of ultra bright speakers.
As for future upgrades I was hoping to change out the speakers only but I'm willing to install an amp if necessary to get the sound I want. Do you know of any amps that would fit in the same space as the factory amp or would I have to mount it where yours is?
Another change I would like to make is replace the "sub" woofers in the floor but that can wait. I imagine that would need an amp upgrade so maybe I could do that at the same time as adding an amp for the mains if required.
Thanks,
Stuart.
Old 11-08-2009, 03:05 PM
Evlengr's Avatar
I would suggest mounting it where mine is, but using a PDX-5 Alpine Amp. This will make returning your sound system to factory much easier should the need arise, less to remove and the amp I suggested will mount very easy without bloody knuckles or the Yosemite Sam cursing that comes with many jobs. I kept my bmw 8 inch subs for almost a year before changing them out and the added power made them sound so much better until I upgraded.
They are now down to $450.00 which is quite the price reduction. It is actually two amps in one.
4 channel for the doors. x 75 watts
1 channel for the subs x 300 watts.
Although this may seem like overkill it is inherently the same idea as our engines. It will be a very rare day that you hit 137 mph, but having all that power in check means never having to work your x3 hard to get up to highway speeds of 80.
Your amp will always deliver smooth sound without ever running hot. And heat equals distortion.
2007 AT X3 RIPOS
2005 GC
2000 Jeep Cherokee
Old 11-08-2009, 05:33 PM
thinset thinset is offline
Mein Auto: X3
I've been searching for some advice about upgrading the factory stereo for quite some time and just came across this post.
The plan is to keep the stock head unit, replace the front door speakers and add a sub, both of which will be powered from an Xtant 403a amp that has been gathering dust for way too long. The great thing about the Xtant 403a is that it accepts speaker level/ balanced inputs. Based on what I have read in a few other forums it seems that the factory Business CD puts out a fairly clean line level to the factory amp, so at this point I'm not expecting to add a JL Audio type clean sweep.
Has anyone come across any information for the wiring layout at the factory amp in the rear quarter panel? I plan to tap these plugs for the line level/ signal inputs, and again for the front speaker wiring.
The options presented for the front speakers don't seem too promising, is the main concern mounting depth? Does anyone have any info on the depth available? I've noticed that MB Quart makes a shallow coax that may be the ticket.
Lastly, what is the general consensus on keeping the 8" under the seats powered? Depending on the ohm load, I could wire them in parallel/ series with the fronts. Perhaps replacing these with some shallow Pioneer subs and powering from the amp may be sufficient enough reason to not need a sub box. Not looking for neighborhood waking bass, but certainly cleaning everything up at higher volumes.
Thanks in advance for all the help. I will be photographing the install to help future DIYers as well.
Old 11-09-2009, 05:51 AM
Evlengr's Avatar
Keep meaning to get speaker wiring layouts brown and yellow comes to mind when I recall using the existing wiring.
The MB quarts will work, but I have my concerns with the front mount and not the depth of these. As it appears that the seperate tweeter in the center of the driver extrudes a bit and may press up against the door grill. I never measured that distance.
Sub under the seat are driven at 2 ohms as opposed to the doors at 4 ohms.
They sound fine powered by a single Alpine amp, but I have never settled on just fine. They lack the bottom end frequency response below 200Hz that gives the nice punch to classical, dance, and rock alike. Not talking about the whump whump that the unknowledgeable use. Also, I recommend NOT using a ported box for your sub. If you want a nice tight punch to the bass this is the way to go, imo.
Hope that answers more than asks questions.
EE
2007 AT X3 RIPOS
2005 GC
2000 Jeep Cherokee
Old 11-09-2009, 09:59 AM
SpartanGA SpartanGA is offline
Mein Auto: 2007 550i, 2011 335i Vert
where do you mount the amp and how readily accessible is the speaker wiring to where you mount the amp?
Jim
2007 550i Sport - White - Tan
Old 11-09-2009, 11:47 AM
Evlengr's Avatar
SmithS,
I would say look it up, but I can't even find where I posted the pictures, hahahaa.
In other words, no problem give me til tonight when I can access my files at home and post pics.
One of these days I am going to take advantage of home file server and set one up. Cheap as all get out and allows for even video sharing remotely.
Cheers,
EE
2007 AT X3 RIPOS
2005 GC
2000 Jeep Cherokee
Old 10-14-2015, 06:43 AM
Matt Stauffer Matt Stauffer is offline
Mein Auto: 2006x3
Hello, My name is MAtt and this is my first post . I want to know if there are any updates to the options for 4" component speakers for a 2006 x3. I was thinking about focal or Rockford Fosgate? I have cahnged my head unit to alpine and my plan is to get a amp to powere a new set opf fronts and the 8 " subs. QAnd then have the head unit power a new set of rear doors. The main concern is on the front doors?? any new information on replacement speakers.. Also, Can a component crossover be used in the fronts?? thank you in advance, MAtt
