E36 (1991 - 1999)
Old 11-08-2009, 09:40 PM
jackrules's Avatar
jackrules jackrules is offline
Mein Auto: E36 328i, E60 530xit 535i
Talking Valve Cover Gasket Removal
OK, so I'm new at working on my BMW, and this is my first job I've done on the car, other than head lights. So please be patient with me.
I'm replacing my valve cover gasket and I've got everything undone ( bolts around valve cover - ignition wiring for spark plugs ( I'm doing the plugs at the same time ) etc. and my valve cover WONT come off so that I can get the old gasket out and the new on in.
Would you recommend using a hammer or skew driver to wedge under the valve cover to loosen it and take it off or what. I searched and found nothing helpful.....
Tonight it got kinda dark while I was out working on it ( damn day-light savings ) so I closed up the car and came in for dinner.
I plan on finishing off the job tomoro... and will probably end up going around it with a screw driver ( the pelican parts DIY recommends a hammer I believe )
Thanks for help
Oh yah - I have a 1998 328i
_____________________________
1998 E36 328i
2008 E60 535i
2014 E85 X1 sDrive
Old 11-08-2009, 09:49 PM
cmybimmer's Avatar
cmybimmer cmybimmer is offline
IM DA BES
Mein Auto: A rental
All it takes is a little wiggling and it comes off . Make sure when you put the new gasket on, use some silicone or sealant around some of the edges or curvature of the head.
-Usama
"The American Dream only makes sense if you're sleeping" - Lowkey
Old 11-09-2009, 01:54 AM
PhilipWOT's Avatar
PhilipWOT PhilipWOT is offline
Turn Burglar
Location: Atl: Come for the pollution, stay for the traffic
Mein Auto: Red Assless Chaps
I wouldnt use anything made of metal to pry it off. The valve cover is aluminum, and if you dent the edge with a stainless steel screw driver you might cause a leak that wasnt previously there. Try a plastic putty knife or something like that.
Old 11-09-2009, 02:40 AM
dc_wright's Avatar
dc_wright dc_wright is offline
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
On the later 328s the valve cover is PLASTIC and you definitely don't want to use a screw driver and pry on it! Make certain that you have all of the fasteners removed including the 3 stud top fasteners for the grounding straps and the two fasteners at the very back of the engine. Then tap on the side of the cover GENTLY with a RUBBER MALLET not a hammer. Exercise a LOT of patience because the plastic covers get brittle with age and will crack easily.
Once you've got it off DO NOT use any solvents to clean the underside if there's a lot of gunk. The solvents can weaken the plastic and make it much more likely to crack.
When you are putting it back together be VERY careful when you are tightening it back down to pull it down evenly by just taking a few turns at a time on each of the fasteners.
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 11-09-2009, 03:12 PM
jackrules's Avatar
OK - thanks for the replies - I'll try this tomoro ( no time today )
I wasn't going to hammer or pry at anything without asking on here first.
1998 E36 328i
2008 E60 535i
2014 E85 X1 sDrive
Old 11-09-2009, 03:43 PM
stock328is stock328is is offline
Mein Auto: 328is
check out pelicanparts.com, there is a DIY for this by Wayne Dempsey. It shows the points for silicone sealant plus, it gives what kind of sealant is recommended. I believe it is Permatex high temp sealant, but go to that site it actually has about 20 free DIY's. I would highly recommend spending $25 and getting Wayne Dempsey's book. It is a huge asset and very well done.
98 328is
Old 11-09-2009, 05:23 PM
Corey Milne's Avatar
Corey Milne Corey Milne is offline
FixItFaster
Mein Auto: EuroS50B30, e83m54b30
+1 Listen to Mr. Wright, guy knows his stuff.
Old 11-09-2009, 07:20 PM
ffej's Avatar
ffej ffej is offline
Tightrope walking
Mein Auto: Jackwagon!
Best. Advice. Evar.
Seriously. The rubber mallet in one of your best friends when working on your E36. I love mine. So much so that I have one in the garage tool box and one in the track box. You'll be stunned at how many things on your car will respond some gentle persuasion from a rubber mallet.
Building a ZHP wagon... click the pic!!!
Because BMW wouldn't do it for me
For Sale - HUGE part out of 2005 ZHP sedan
Originally Posted by KrisL View Post
My input is that ffej knows what he's talking about .
Old 11-09-2009, 08:33 PM
jackrules's Avatar
Originally Posted by ffej View Post
Best. Advice. Evar.
Yes they are great - I've got a couple of them, I can't believe that I didn't think of using it - I use it all the time to move parts around on our latter that moves in a million directions ( Christmas lights )
1998 E36 328i
2008 E60 535i
2014 E85 X1 sDrive
Old 11-11-2009, 09:37 PM
jackrules's Avatar
OK, so I tried to get my valve cover off again today, and there is no way it seems like it's coming off.
I am pretty sure that I got all the bolts off, including the 2 in the back and 4 down the center and an assorted number on the left and front of the VC.
I used a rubber mallet as described above, and there was NO budge at all...
Please tell me what I'm doing wrong? There is a very very little leak, and zero oil down by the spark plugs, so I might give it a little while and go over this on thanksgiving break.
I am a beginner, so there is probably a good chance I'm doing something wrong, so please give me tips on the basic kinda stuff that I COULD be missing!
Thanks for the help!
Jack
1998 E36 328i
2008 E60 535i
2014 E85 X1 sDrive
Old 11-11-2009, 10:03 PM
jhstealth jhstealth is offline
Mein Auto: 97 540i6
check to make sure you got all the bolts in the middle, there is a coupe down the center it seems like you did but just check again. If for some odd reason the gasket isnt oem sometimes people put rtv on them and that makes them stick pretty hard after being on there awhile so you may have to use a little muscle. Id use my hands cuz its the safest and wiggle very hard, stern and slow and it should come off if you infact DID get all the bolts. Definitely check the middle ones tho and re check all the sides.
Old 11-12-2009, 12:41 AM
TrainwreckFilms TrainwreckFilms is offline
Mein Auto: 1995 E36 318i
Feel free to keep us updated with photos! I need to do this on mine. as well as figure out how to remove my tranny
Old 11-12-2009, 11:10 PM
jackrules's Avatar
Talking
I would defiantly hope that you could do a VC easily if you plan on doing a trannie, but I will defiantly keep everyone updated here
--- I am sure that I got all the bolts off - and I was using my hands to pull it off, but it felt like I was lifting the car before I was going to get the VC off
As my dad and I have been the only owners, I am sure that the car has the OEM gasket on it, do any of you know if the factory used sealant or if they just put it in there?
I will plan on doing a DIY on this - I have put everything back together, because I had to drive the car - so now I'm great at taking the getting all the bolts off down to the VC and taking the ignition coils off.
In the mean time, Pelicanparts has a GREAT DIY on it - I just wish they had tips for VC's that won't come off... hahah
1998 E36 328i
2008 E60 535i
2014 E85 X1 sDrive
Old 11-13-2009, 08:25 AM
dc_wright's Avatar
When say you had all the nuts off of the VC, did you also have the 3 that have the stud on top that the ground straps for the ignition system connect to? (see photo) If you did then it should be coming off with some taps from the mallet.
They do use a little bit of sealant for the factory installation but no so much that it would have your VC bonded to the head.
Old 11-13-2009, 08:54 AM
kc chief kc chief is offline
Mein Auto: 95 325i & 71 SS Chevelle
I used the write up from Pelican parts and this took me less than an hour. There is a technique to using a mallet, and you can use your hands as well. Alternate directions of your taps/pulls. Get a firm grip on that beyotch and rock her back/forth and up/down with all your might for 30 seconds at a time. Also, as in all the write ups USE A TORQUE WRENCH WHEN PUTTING BACK TOGETHER. I know that's 101 stuff, but worth reiterating.
Old 11-13-2009, 06:00 PM
jackrules's Avatar
Talking
yah - I had the 3 on the top off, and the bolts for the grounds were all off....
If I have the ignition coils off and the ground's disconnected - do I need to take anymore of the ignition system off............... I can't find anything more that could possible need to be taken off
I'll try this weekend and I'll wiggle the VC harder!
1998 E36 328i
2008 E60 535i
2014 E85 X1 sDrive
Old 11-14-2009, 08:44 PM
sksiazek sksiazek is offline
Mein Auto: 1998 328i
I don't remember the value cover being significantly difficult to remove, although it definately won't budge without removing all 15 value cover bolts. I forgot the one's down the middle at first, but it came off without too much effort once the bolts were off.
The gaskets were a PITA to change, especially the ones around the spark plug openings.
The new gaskets are obviously very flexible rubber, but after being on the car for almost 12 years, the old gaskets were hard and very brittle. They did not want to come out without a fight. My fingers have the battle scars too prove it.
cover, e36, gasket, pelican parts, valve
