Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series & 4 Series > E21 (1975 - 1983)
E21 (1975 - 1983)
Old 03-20-2009, 02:57 PM
dletts dletts is offline
Mein Auto: 1980 Bmw 320i
Suspension Kits?
I am looking for a front-end suspension kit for my 80 320i. Does one exist? For that matter I also would be interested in a rear-end kit. But first the front-end. This is my first post, so hello to all and I hope someone can help me out.
Old 07-29-2009, 07:51 AM
JetSetBen JetSetBen is offline
540i W/Dinan S1.
Mein Auto: 540i Dinan S1 suspension
Try Bavauto.com. Thay have some good stuff. SAk them about doing the rear. You will need to modify the suspension carrier so that you don't get too much neg camber. Good luck.
Old 09-28-2009, 03:55 PM
GCe21 GCe21 is offline
Mein Auto: '83 320i
vacmotorsports.com has a front adn rear sway kit for e21's bavauto is good people too. try some strut bars
Old 11-02-2009, 02:15 PM
edkwong8 edkwong8 is offline
Mein Auto: 83 e21 95 m3 2008 335i
e21 suspension
hey . ive got a set of bilstein shocks and springs and sway bar for a 1983 e21 . If you are interested email me back and i can send you pictures. edkwong8@yahoo.com.
Old 11-12-2009, 07:13 PM
77 320i 77 320i is offline
Mein Auto: '77 320i
as far as suspension parts go i have not found a "ton" of suspension parts for the e21...in a discussion with the folks over at ireland engineering i discovered that they sell a very common sense "kit" (i don't think they call it a kit however!) . . . as you may know most "modern" cars have adjustment in the rear end suspension that allows for a positive and negative adjustment in the rear end...
i had a over steering problem with my '77 320i and found that most of the bushing were badly worn and the corrected a lot of the problem...i have also discovered that the rear sway bar and the front for that matter has traditionally been "beefed up" with slightly larger diameter sway bars which is on my to-do-list...of course a good set of coil-over wouldn't hurt either . . .
