Old 11-09-2009, 04:45 AM
fsarris fsarris is offline
Mein Auto: 05' BMW 745LI
Replacing Alternator 2005 745LI
Does anybody have instructions on how to replace alternator on a 2005 745LI? Has anybody replaced one and if so do you have any input on steps and issues with replacing alternator? Are the alternators on these cars water cooled? Thanks, Frankie
Old 11-09-2009, 12:25 PM
magastos2 magastos2 is offline
magastos2
Mein Auto: 745LI
http://www.bimmerfest.com/forums/sho...ght=alternator
Old 11-09-2009, 12:37 PM
magastos2
Mein Auto: 745LI
here is another one.
Old 11-09-2009, 09:38 PM
Keif Keif is offline
Master Tinkerer
Mein Auto: 2007 Alpina B7
Yes, they are water-cooled. I strongly suggest having yours rebuilt instead of buying a new one (much cheaper) -- mine was totally seized when I finally brought it in and it only cost $200 to rebuild.
The basic steps are: remove the fan and fan shroud, remove the belts, remove the deflection pulley in front of the alternator (buy a set of crows' foot wrenches for this part and save yourself a ton of frustration --> see here), remove the alternator.
Black 2007 Alpina B7
Tension strut bushings
White 2007 Alpina B7
Supercharger clutch/bearings, replaced exhaust valve/pulled head, sunroof seal, 6000K angel eyes
Black 2002 BMW 745Li (sold)
KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator & mounting bracket gasket, sunroof seal, CCVs, plugs, sway bar bushings, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, sanded headlights...
Old 11-01-2013, 01:18 PM
DrMishka DrMishka is offline
Mein Auto: 745li e65
What amp would be the best, there a quite a few to choose from.
