E34 (1989 - 1995)
Old 11-17-2009, 06:35 PM
e34lad e34lad is offline
e34 lad
Mein Auto: 520i e34
e34 leakin clutch fluid.. HELP
my 1996 520 is leakin clutch fluid from somewere around gear box... when i pres the clutch pedal it goes to the floor as if there is no fluid at all in the resivour botlle.. there is fluid left in the botlle but there is no responce from the clutch wat so ever.... need advise urgently as to wat it could be...
Old 11-18-2009, 04:47 AM
yaofeng yaofeng is offline
Yaofeng
Mein Auto: 525/540it/540it/325/mini
Remove the slave to have a look see. Two nuts using an 8 mm socket.
'95 525i 5 speed, built 5/94, with a 93 m50tu engine
'94 540it built 3/93, converted to 6 speed with a 93 e32 m60 engine
'01 540it, built 6/01
'03 325i 5 speed, built 9/02
'10 mini 6 speed
Old 12-06-2009, 06:14 AM
e34 lad
Mein Auto: 520i e34
thanks checked it and it was the slave.. was surpriseinly easy to do aswell
Old 12-06-2009, 08:12 AM
BrothaMansWhip2's Avatar
BrothaMansWhip2 BrothaMansWhip2 is offline
Blue Miracle Whip
Mein Auto: e34 touring 525I
+1 yao
Went from a 87 e30 with Stick Shift,
To a 92/3 e34 Touring with an M50 in it!
88 e30
87 e30
1992/3 525I Touring
