Old 11-18-2009, 09:15 AM
cn90 cn90 is offline
Oil Filter HOUSING: Additional Blue RTV Sealant?
A friend told me when he replaced the Oil Filter HOUSING Rubber Gasket (Black dots in the pic below), he also added a thin bead of RTV Blue Sealant around the perimeter (Blue dots).
Has anyone done this trick of a thin bead of RTV Blue Sealant or is it overkill?
Old 11-18-2009, 09:30 AM
TeaRex714's Avatar
TeaRex714 TeaRex714 is offline
Mein Auto: 2015 740Li
I just replaced mine about a week ago and didn't use any extra sealant. I would think it was not a great idea. That seal doesn't make that much contact with the engine as it is. Anything that increases the distance between the engine and the housing, even a little, would seem to me like a bad idea.
2015 740Li Black Sapphire Metallic. Her name is Samantha
2008 M3 Sedan Alpine White / Fox Red - Sold at 219K miles
Old 11-18-2009, 09:37 AM
poolman poolman is offline
Mein Auto: 525i station wagon
I would think it to be a good idea--the sealent will add insurance against another leak coming along--you would need to allow the sealent to dry throughly before starting up again--once the bolts are tuorqed down the sealeant would thin out and help not hinder. I would use the Permatex Black ultra seal instead of the blue--
Old 11-18-2009, 09:42 AM
Hey poolman,
Slightly off topic what is the main difference between Black and Blue RTV?
It looks like a "zoo" overhere:
http://www.permatex.com/products/Aut...ket_makers.htm
Old 11-18-2009, 01:00 PM
MatWiz's Avatar
MatWiz MatWiz is offline
Psychology Reversalist
Mein Auto: 528
I didn't do the housing sealant yet, but it is on my immediate to-do list. I AM planning to use a little bit of Permatex RTV right on the edges of the housing. Unlike your blue dots, I was planning to go right outside the 4 bolts, and put a little bit around the head of the bolts.
I am planning to use the 'copper' color RTV as this is what I already have from using it on the valve gasket cover. Why buy another one? The copper RTV has a very high temperature specs, so I am sure it will be ok.
I think its a good idea to use RTV to go into all those microscopic gaps and scratches to fill them up and seal them. It can't hurt, right? Just to put them on the very outside edge to make sure it is not going to get inside anything in there.
mw
MatWiz
"The greatest thing about the internet, is that you can quote something and totally make up the source." - George Washington.
Old 11-18-2009, 01:04 PM
MatWiz's Avatar
Mein Auto: 528
Originally Posted by cn90 View Post
Hey poolman,
This is the one I have, and used.
http://www.permatex.com/products/Aut...sket_Maker.htm
Part number 101BR.
mw
MatWiz
Old 11-18-2009, 04:11 PM
Hey CN90--I've used both the Blue and the Black Permatex for years now--the Black came out about 15 years or so ago and I was turned on to it by a freind in the biz--the stuff is much stronger thane the blue--oil won't touch it as long as there was no oil under it when applied--strong stuff---I've used it under 427 Ford FE intakes without the mounting end gaskets and the stuff held--in my book thats as strong as it gets.
Old 11-18-2009, 05:17 PM
MatWiz's Avatar
Mein Auto: 528
Originally Posted by Beenthere View Post
FYI-
From a technical standpoint using any sealant betwee the two surfaces reduces the pressure on the OE seal from what it is designed to be. The blue Permatex is formulated to cure even in the presents of oil, whereas most other silicone sealers are not.
YMMV
What is the thickness of the thin smear of RTV at the edge of the housing after the bolts have been torqued to spec?
I have no idea what it is. Maybe you have some info somewhere. But just using my common sense, it is definitely less then 0.1 millimeter.
If 0.1mm will reduce the pressure of the housing gasket by that much as to create a leak problem... ??? Than we are really in trouble. - I don't think so.
mw
MatWiz
Old 11-18-2009, 05:35 PM
BMWBLUES BMWBLUES is offline
Mein Auto: 2001 540i 6speed
http://www.intengineering.com/VW/18T...69812-1-2.html , victor reinz has a few different sealents that work excellent. When I look under the hood of a car at the shop and see blue or red sealent oozing out behind a waterpump or something of that nature I usually think the person that did this before didn't really know what they were doing. No offense just my two cents
Import Sports, Glen burnie MD, 410-553-6910
Old 11-18-2009, 09:04 PM
After the Gasket is installed in the Housing, it sticks out about 1mm before install.
I understand that BMW does not call for extra sealant, but it is this goofy design that allows the factory gasket to leak as early as 50K miles.
A very thin bead of RTV sealnt will be squeezed down to paper thin once the bolts are torqued down.
The key word here is thin bead.
I guess I will be the guinea pig and will report back.
Old 11-20-2009, 12:48 PM
oekundar's Avatar
oekundar oekundar is offline
Jedi Knight
Mein Auto: 5 Touring
anyone have a tutorial/DIY for this? I have the gasket and need to do it already
BMWCCA #389756
Old 11-20-2009, 01:09 PM
The DIYs you find on the web are mostly OK, some of them miss details such as torque and Freeze Plugs etc.
I do have the DIY, I am writing it up this weekend if you can wait.
It is more complex than you think.
1- O.F. Housing Seal DIY is not difficult but one can strip a bolt if not careful:
http://bimmerboard.com/forums/posts/727932
2- The two (2) Freeze Plugs in the back are troublesome, they leak too:
http://www.bimmerfest.com/forums/sho...t=freeze+plugs
I am putting together a diy for the whole thing: gasket + two (2) Freeze Plugs.
So stay tuned. I will post it this weekend.
Old 11-20-2009, 03:25 PM
gtxragtop's Avatar
gtxragtop gtxragtop is offline
Mein Auto: 2003 530IA
It's not a gasket. It is an O-ring. It is not designed to have any additional sealers. Make sure that all surfaces are spotless that this O-Ring will contact. M8 bolts to be tightened to 22NM
or 16.2 foot pounds.
Ever wonder why 5 series electrical issues are common and complicated.. Spend time here and you will understand why. http://www.bmw-planet.com/diagrams/r...9new/index.htm
Old 11-20-2009, 05:23 PM
oekundar's Avatar
Jedi Knight
I can and will wait for the DIY
BMWCCA #389756
Old 11-21-2009, 04:54 AM
DHoang's Avatar
DHoang DHoang is offline
Gearhead
Mein Auto: '98 528i, '82 323i
When the oil filter housing leaks, is it obvious to see where the leak's coming from, or does it travel down the lip of the oil pan and whatnot ?
http://www.bimmerfest.com/forums/picture.php?albumid=4132&pictureid=24642
Old 11-21-2009, 04:15 PM
When it leaks, it leaks from either:
1. Gasket (common problem after 60K miles).....or
2. The 2 "Freeze Plugs" in the back.
Either way, the area BEHIND the OF Housing will be wet and the Oil Pan will have trace of oil dripping. Mostly because the wind created by Fan Blade and the road wind pushes the oil back.
Old 12-26-2014, 04:52 PM
MJB9 MJB9 is offline
Mein Auto: 2002 525i (E39)
CN90, do you have the DIY write-up? I don't see it in this thread. Thx
Old 08-11-2016, 08:41 AM
crazy4trains's Avatar
crazy4trains crazy4trains is offline
Mein Auto: 2002 530i Sport
Yes I know this is a somewhat old thread!!!
CN90, how has your oil filter housing gasket repair held up? I assume that you did use RTV as indicated above. Thinking about doing the same and would like to know about performance.
Looks like either the Permatex Black or Copper would be a good choice.
2002 530i
Old 08-11-2016, 08:45 AM
Brandon002's Avatar
Brandon002 Brandon002 is offline
Mein Auto: 2002 530I Sport
There is no need for RTV. The normal gasket alone is good for 100k miles plus.
Old 08-11-2016, 09:01 AM
Well , since the time this post was first installed, I had to do the job a couple of more times. The last time I used permatex product called,, The Right Stuff,,and it is , what it says it is.
Old 08-11-2016, 10:03 AM
Personally I think this gasket should last way beyond 100k miles, but it doesn't. My original gave out at about 75k miles. Nothing wrong with trying to extend the life of the new gasket installation as long as it is done prudently.
2002 530i
Old 08-12-2016, 08:48 PM
rbelton rbelton is offline
Mein Auto: E39
I agree with Brandon, there is no need to add anything other than the factory gasket. Here's a tutorial guide to replacing the OFHG on an M54:
Old 08-13-2016, 09:59 AM
Just a follow-up.
I posted that idea of extra RTV a few years back but ended using only the gasket (BMW OEM gasket). Six (6) years and 70K miles later, no leak.
No need for additional RTV. However, it does not hurt to have a bit of RTV as mentioned.
The key thing is "sequential torquing" of the bolts.
- Seat the housing down finger tight.
- Tighten the bolts in sequence, a bit at a time.
- The gasket will settle in.
- Then tighten sequentially a bit more.
etc. etc.
Anyway, in many vehicles I have owned, most of these gaskets leak around 100K, it is the nature of the beast.
Old 08-14-2016, 07:38 PM
Brandon002's Avatar
If your OFH is leaking after replacement you did something wrong during the install or there is pitting or warping of the parts.
Old 08-15-2016, 02:46 AM
Burning2nd's Avatar
Under the lift arms
theres lots of little tricks of the trades that a lot of people dont know about or never did... or never had the option to do ...
Adding a little rtv is one of them.. you can easily and safely add RTV to the OFH gasket... but BUT
the most importent part is you have to put it on... and let it set up... B4 you actually install and tighten it down
Like..... permitex coper gasket spray on a block face b4 and after seating the head gasket
Like RTV on the half moons of a valve cover gasket
There is always pitting and warping of parts after use... this includes just about every mating surface on the car
Litttle bit of gasket material..... let it sit.. 15-20 install like normal
15486372<-----
