Old 11-20-2009, 10:17 AM
Trev530 Trev530 is offline
Mein Auto: 530i
Coolant for 03 530i
Getting the "Coolant Low" error message. Manual doesn't get specific on the coolant to use other than steering you to the stealership. Called the fools at Concord BMW stealership (only thing they ever did right was sell me a great car but they've flailed since) and they refused to tell me the type so that I could go to my nearby NAPA and pick up a jug. Would someone who's topped off please let me know the type of coolant and distilled H2O ratio if advised? Many thanks.
Old 11-20-2009, 10:23 AM
cn90 cn90 is online now
How many miles fo you have?
The purists in this forum will tell you to use BMW coolant at $20/gallon.
I have used Green Prestone (now Extended Life) in all my bimmers for 25 years, not a single problem.
Old 11-20-2009, 10:28 AM
TheStig TheStig is offline
Some say...
Mein Auto: N/A
Zerex G-05 is close to what BMW uses.
Old 11-20-2009, 10:32 AM
And what BMW recommends is not necessarily the best.
Old 11-20-2009, 10:44 AM
Some say...
Mein Auto: N/A
Blue coolant is prettier.
Old 11-20-2009, 10:49 AM
bmw_n00b13's Avatar
bmw_n00b13 bmw_n00b13 is offline
Freude am Fahren
Mein Auto: 99 528iA
I use the good old green stuff. Works fine. Don't expect anything from the stealer and they won't disappoint you. However, when I do my overhaul, which is very much overdue, I plan on using BMW or Merc coolant.
'99 528i ('98/12 build). 282,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals, increasing amounts of duct tape and glue
'99 540i (grandfather's)
Old 11-20-2009, 10:55 AM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
Agree. Very nice color. Have it in and out on my car
Old 11-20-2009, 11:29 AM
Mein Auto: 530i
Right now the Silver Beast is at 83,500 miles.
Which blue coolant to you guys recommend? Do you dilute?
Old 11-20-2009, 12:10 PM
blue, green red, pink, it is just the dye colors.
Always use 50-50 mixture.
Old 11-20-2009, 12:11 PM
Some say...
Mein Auto: N/A
The blue coolant is the BMW brand coolant.
Do you dilute?
50/50 and use distilled water.
Some coolants are already diluted so read the label carefully.
My recommendation is to top off the coolant with the same chemistry that's already in there.
If it's BMW coolant use BMW coolant; if it's Prestone coolant use Prestone, etc.
Old 11-20-2009, 02:21 PM
bmw_n00b13's Avatar
Freude am Fahren
Mein Auto: 99 528iA
Best advice yet.
Don't use tap water if you can help it, certainly avoid any water that's hard. If you have scale in your kettle, don't use tap water.
Old 11-20-2009, 02:32 PM
BMWBLUES BMWBLUES is offline
Mein Auto: 2001 540i 6speed
I would use the blue bmw coolant, It is really easy to find very small leaks because it crusts up where it is leaking from, Also if you ever take it to the stealership and you have another color mixed in I am sure they would hastle you about it. I just did my timing chains and the only reason I knew I needed a new valley pan was because of the the stalagmites of blue crusty stuff coming up from the bolts on it.
Import Sports, Glen burnie MD, 410-553-6910
Old 11-20-2009, 03:55 PM
Jason5driver's Avatar
Jason5driver Jason5driver is offline
Mein Auto: E39 hamster w/ pin-wheel
I disagree.
They ARE different.
http://forums.bimmerforums.com/forum...ferrerid=56200
" As for coolants - there are three types. In the most basic of categories, green, blue, and orange. Green is the old "regular" coolant. Blue is what is in my 330Ci...not sure if it is in every BMW model. Orange is marketed as a coolant that never has to be changed.
More specifically (and I am sure someone on here will trump my limited knowledge), blue is NAP-free (nitrate, ammonium, phosphate free as in the post above). Orange is NAP-S- free, meaning also silicate free. What does this all mean? You CAN change coolant types, however, you CANNOT mix all coolants, as they will precipitate out in solutiuon. i.e. you can drain "regular" and replace it with blue, or orange....but if your "regular" coolant is low, I am sure it would be a good idea to simply ADD blue or orange to top it off (basically I am not sure which coolants cannot mix).
Big picture: go to BMW and buy their coolant($13 for more than you will need), mix it 50/50 with distilled water, and add to the car. Alternatively, just call BMW and ask which coolant type they use (or the color) and go buy that at the local auto shop. Like mixes with like."
http://forums.bimmerforums.com/forum....php?t=1270934
http://forums.bimmerforums.com/forum...1270934&page=2
[QUOTE]
I've seen mixing different coolants cause weird gelling/sludging and discolorations.
yes, that is true. I don't think anyone is suggesting mixing coolant. The system should probably be flushed of all the old blue coolant before making the switch. I know orange and green don't get along.
Old 11-20-2009, 07:29 PM
Originally Posted by Jason5driver View Post
I disagree.
They ARE different.......
I never said they are the same. All I said is the color of the coolant comes from the dye.
The actual ingredients are colorless.
I have access to a lab and know exactly what goes into each coolant on the market.
The main components are usually methanol (which is colorless and if ingested, methanol is converted by the enzyme alcohol dehydrogenase into formic acid causing blindness) and/or ethylene glycol.
Then the mfg adds corrsion inhibitors. Then the debate goes on between phosphate and phosphate-free etc. and all that blah blah blah.
Then a dye is added just to make the color.
So to make a long story short, take 2 Green coolants from Prestone and Peak, and yes they are slightly different, not much but there is a difference.
Similarly, take 2 Pink coolants from Prestone and brand B, and yes they are slightly different, not much but there is a difference.
I have used Prestone for 25 years in all of my BMW, Volvo, Hondas, absolutely no problems. So for me, why rock the boat?
Old 10-06-2010, 06:34 AM
energizedmortal's Avatar
energizedmortal energizedmortal is offline
so there's speculation that anything other than BMW coolant will mess up your car and then when cn90 says he's used prestone for 25 years with no problems the thread ends
Old 10-06-2010, 09:44 AM
ECSTuning's Avatar
Instructor of the Stig™
There are many different options, however for those who like the piece of mind that they are using a BMW approved products, (which many of us do) we have their full strength coolant/antifreeze available below...
Click HERE for more information.
Please let us know if you have any questions! Feel free to shoot me a PM or email.
Best,
Joe
Customer Service Hours: M - F 8:00am - 8:00pm EST | Saturday: 10:00am - 7:00pm EST
Sales Team Hours: M - F 8:00am - 11:00pm EST | Saturday: 10:00am - 7:00pm EST
800.924.5172 | OEM BMW Part Number Search
Click HERE to read what people are saying about ECS Tuning
Old 10-06-2010, 06:30 PM
Hooray!'s Avatar
Hooray! Hooray! is offline
Mein Auto: 2002 530i Sport Premium
BMW coolant (available discounted via the internet or with a CCA membership at a stealer) is the ONLY coolant to use... BMW coolant like Mercedes has a different PH then the regular green coolant you get at NAPA or PepBoys, etc. Using the wrong PH will weaken the plastic coolant system parts of our fragile BMW coolant systems and when and if they fail, you risk wrecking your engine. Considering how seldom you really change or add coolant, the BMW approved (correct PH) anti-freeze even at $20@ seems like a deal... interesting that it is blue, surprised me when I bought my first jug to top off after I did my VANOS.
2002 530i
Exterior: Black
Interior: Black
Packages: Sport, Premium, Cold Weather
Options: HID, Folding Rear Seats, Ski-pass
Old 10-06-2010, 07:08 PM
AnotherGeezer's Avatar
AnotherGeezer AnotherGeezer is offline
Entwicklung 39
Mein Auto: 2003 530i/5
+1
The difference in price between BMW coolant and other brands is negligible. Since our cooling systems can be "problematic", I just don't gamble on anything other than the factory fill.
I would find something else to save my money on.
Old 10-06-2010, 08:14 PM
bmw_n00b13's Avatar
Freude am Fahren
Mein Auto: 99 528iA
Considering that the cooling system only lasts 100k miles on BMW coolant it would surprise me if it really makes a huge difference.
I'm more concerned about compatibility with other coolants and more importantly engine metals.
Old 10-06-2010, 10:25 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
From the bestlinks thread ...
- Coolant, for engine, automatic transmission, power steering, and AC evaporator cooling (1)
Old 10-07-2010, 04:49 AM
Hooray!'s Avatar
There are a few good internet articles on why MB and BMW use different PH coolants... KEY is that you only put their coolant in your system and you never have to worry about compatibility with a wrong PH brand. May not matter to 99 out of 100 drivers as some other issue may come up larger then a coolant PH difference, but ask those guys whose coolant system plastic "necks" exploded, overheated their engine, warped their head and now have permanent oil leaks, overheating, loss of power, etc and I bet in hindsight they would pony up the $20 and stick to BMW coolant! ... my .02.
2002 530i
Exterior: Black
Interior: Black
Old 10-27-2010, 10:07 PM
jataiyan jataiyan is offline
Mein Auto: 1997 bmw 540 i
I recently flushed my 1997 BMW 540i radiator and added the recommended 50/50 BMW coolant to the system. I need to know how to bleed the system so I can get rid of the 'check coolant level' indicator on the cluster to disappear?
Old 10-27-2010, 11:52 PM
pleiades pleiades is offline
Mein Auto: '99 5-spd
It helps to bleed the system with the car pointed uphill or on ramps so trapped air bubbles can more easily come out the bleed screw vents. Do a search on the forum and read the "best of" links listed at the forum top.
Old 10-28-2010, 03:14 AM
DominguesE30's Avatar
DominguesE30 DominguesE30 is offline
BMW FETISH!!!
Send a message via MSN to DominguesE30
Mein Auto: `97 BMW 318is
http://www.pelicanparts.com/bmw/techarticles/E36-Coolant_Flush/E36-Coolant-Flush.htm
There ya go buddy, it's in there somewhere
Sent from my iPhone using BimmerApp
MADEINDEUTSCHLAND
`00 BMW e46 330i
`97 BMW e36 318is
Beeeeeeeee Eeeeem Double-YOU!!!!
