Old 11-20-2009, 10:42 AM
bimmer5150 bimmer5150 is offline
Mein Auto: 2004 745Li, 1996 BMW Z3
Steering wheel controls not working
Has anyone had an issue on their 7 series. the controls on my steering wheel sometimes do not work and other times it does.. its done it a few times. and im not sure on how to go about fixing it. could it be a fuse? or could it be a computer issue.
does anybody have any suggestions on resolving this issue before taking it to a dealer.
thanks i'd appreciate anybody with some ideas
Old 11-20-2009, 12:22 PM
Slick44 Slick44 is offline
R.E.44
Mein Auto: 2011 BMW 750i/2007 750i
i have a similiar problem i notices. sometimes when i press the volume button to lower the radio it triggers the phone system and ends up calling the last number i dialed. it hasnt been a big deal but im thinking that it would be a good idea to fix it.
Old 11-20-2009, 03:43 PM
im hopeful this issue can be resolved, because my gf.. complaints when she drives it and happens to her. but anyways, im hoping this problem can be resolved
Old 11-20-2009, 08:01 PM
Seven11's Avatar
Seven11 Seven11 is offline
President
Mein Auto: BMW
if it was a fuse then it wouldn't work at all
cuz when fuse goes, it goes!
'08 BMW 535i - Sport - Sport Trans - JB4 - Catless DPs - Intake - E85 -
'07 SUZUKI GSXR-750 - Gray/Black - Akrapovic Titanium Exhaust -
'03 BMW 525i - Sport -
'98 Ford Expedition - 5.4L - 4WD - Eddie Bauer - 8 seater -
'03 BMW 745i - GONE -
'09 HONDA CBR600RR - GONE -
Old 11-20-2009, 08:03 PM
Seven11's Avatar
President
Mein Auto: BMW
are you sure you're pressing the volume button and not the phone button, cuz i do that a lot
Old 11-20-2009, 08:06 PM
Keif Keif is offline
Master Tinkerer
Mein Auto: 2007 Alpina B7
Bimmer5150: If you're lucky maybe it's just a loose connector or a wire shorting. Do the button blocks on both sides of the steering wheel not work, or just the left buttons or right buttons? Does the L/D or S/M/D button work correctly while the other buttons are not working? If both button blocks are not working but the shifting program button still works you might start by pulling any errors from the steering column modules -- a dealer thing. If only one button block is impacted then you might just have a loose connection in the steering wheel itself where the block connects to the module (or a wire between the two shorting to something it shouldn't be).
Black 2007 Alpina B7
Tension strut bushings
White 2007 Alpina B7
Supercharger clutch/bearings, replaced exhaust valve/pulled head, sunroof seal, 6000K angel eyes
Black 2002 BMW 745Li (sold)
KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator & mounting bracket gasket, sunroof seal, CCVs, plugs, sway bar bushings, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, sanded headlights...
Old 11-20-2009, 08:08 PM
at first i thought it could be a fuse going out or something, because whenever it does go out nothing works or lights up on the steering wheel controls. and then the next time i get in it, it will work normally and all the steering wheels controls are lighted up orange again.
Old 11-20-2009, 08:10 PM
hi keif
thanks for the info that seems to make sense but where could i check for loose connectors, would it be directly on the steering wheel or somewhere down on the column? thanks for any help guys.
Old 11-20-2009, 08:49 PM
Master Tinkerer
Make sure any fuses related to this are fully seated first -- get the low hanging fruit first. The connectors are behind the front cover on the steering wheel, but let me check wiring diagrams to see where it gets its power (maybe there is an easier place to check before the steering wheel -- to verify that power is getting to it consistently).
There is a 20A fuse in the glove box that leads to the steering column switch cluster then on to the steering wheel module. Do your turn signals work when the buttons stop working?
Old 02-21-2013, 06:14 PM
Kevin Halbleib Kevin Halbleib is offline
Mein Auto: 740il
Any idea exactly where the 20 amp fuse is in the glove box?
My steering wheel controls do not work. Radio and Nav does not work either. NO POWER
