Old 11-20-2009, 04:20 PM
BenattheTrack BenattheTrack is offline
Mein Auto: 06 Z4 M Coupe
Camber correcting bolt Location Z4MC
Hey guys,
Due to a lot of helpful info on this site, I have ordered and received my camber correcting bolts from Turner that I'm going to install on my Z4MC.
My only question is WHERE to install them. Does anyone have a picture of their installation location or some direction you can give me.
Old 11-20-2009, 07:30 PM
Ron Stygar's Avatar
19,585 Miles
Originally Posted by BenattheTrack View Post
Hey guys,
http://www.realoem.com/bmw/showparts...58&hg=31&fg=10
Old 11-21-2009, 03:26 AM
car62 car62 is offline
Mein Auto: Z4MC AW/IR
This is an old thread that discusses those bolts.
http://www.bimmerfest.com/forums/sho...ht=camber+bolt
Make sure you torque the bolts to 81 NM and use loctite on them. The factory uses red (high strength) thread locker.
Old 11-21-2009, 05:33 AM
Thank you!! I've looked about 20 times and feel like an IDIOT for not finding this thread
Old 11-21-2009, 08:14 AM
You're welcome. It's nice when we can have helpful threads that make a difference for the owner. Sometimes you have to look way back because the old timers are tired of repeating the same advice over and over again for years. Just make sure you don't cross thread the bolts, make sure they are torqued properly, and use a thread locking compound.
I believe that Mr. H. stated that each washer is good for about 0.5 degrees of negative camber, unless I am remembering that wrong.
Old 11-21-2009, 10:05 AM
gnx gnx is offline
Bimmerphile
Mein Auto: Z4 MC, 2lt x3, 120 vert
Hey guys,
Are these bolts the ones for the e36 on the Turner website? I guess this is only for the front, right?
Old 11-21-2009, 10:26 AM
Yes. That is what I used. Front only.
I just got finished with the install and it was pretty simple. The existing bolts were easy to break free but a little hard to back out. I have a long torque wrench that did the trick but is a little hard to manuever.
But, oh wow, what a difference!! The car handles much better. Turn in feels a little sharper and much more front end bite that makes the rear easy to rotate in the middle of slower turns (like the roundabout near my house). I haven't tried it on the track yet, so I can't really do a complete eval but I'm sold already!!
I highly recommend this.
Old 11-21-2009, 10:34 AM
You're welcome. It's nice when we can have helpful threads that make a difference for the owner. Sometimes you have to look way back because the old timers are tired of repeating the same advice over and over again for years. Just make sure you don't cross thread the bolts , make sure they are torqued properly, and use a thread locking compound
Done, Done and Done on your three pieces of advice!
Correct on the .5 degress of neg camber. I used 2 of the washers on the outside and should now have 2.5-2.7 degrees of neg camber. Whatever it actually is, it's perfect!
Thanks again for finding this old thread!!
Old 11-21-2009, 01:45 PM
jmillet's Avatar
jmillet jmillet is offline
Mein Auto: E86 Z4 M Coupe 7LM08376
Question Toe
Don't forget to check front toe after you've changed the camber. Factory spec for the Z4M is 0.16 degrees plus or minus 0.1 degree. I like my front toe at zero.
Jim Millet
2007 Imola Red Z4 M Coupe'
Premium Package, Nav, HD Radio, Heated Seats, CDV Delete, RPI Scoop, Strong-Strut fire wall braces, TCK DA Coil Over Suspension with Camber/Caster plates.
Old 11-23-2009, 12:22 PM
gnx gnx is offline
Bimmerphile
I tried to put an order in for these and I got a reply from Turner that they don't fit the Z4 M. Can you post a link to what you purchased?
Old 11-23-2009, 01:42 PM
jragan's Avatar
jragan jragan is offline
Mein Auto: 07 Imola Red/Black MCoupe
http://www.turnermotorsport.com/html..._ID=TSU3690036
I emailed Turner months ago to tell them that it works just fine and they emailed me back to tell me they don't LOL. They're obviously confused
His: E86 ///M Coupe: Pics Track Pics Vids
Hers: 997-1 C4S: Pics
Old 11-24-2009, 06:24 PM
Yep, this is exactly what I ordered and intalled
+1 on Turners obvious confusion!!
