Old 11-21-2009, 06:50 AM
05hexhead 05hexhead is offline
Mein Auto: `04 330CiC
Z3 with 19" Rims?
I am thinking about looking at a 2002 3.0 Z3.
It comes with 19" rims. I was wondering if there would be clearance issues with this size of rim? I imagine that it that it is going to have a fairly harsh ride as well.
http://www.autotrader.ca/used_cars_C...play3.jpg&zd=3
Any comments from experienced owners would be appreciated.
Thanks, Nick
Old 11-21-2009, 10:09 AM
SUNZOUT SUNZOUT is offline
Mein Auto: '00 M Roadster
As long as the tire is the correct size and the wheel has the correct offset then there is no reason they would rub.
TC Kline S/A Coilovers | Sharked | Turner Slotted Rotors | Axxis Ultimate Pads | SS Front Strut | IE Subframe Bushings | IE Rear Toe/Camber Kit
Whalen Shift Machine | Stygar Clutch Pedal | CDV Delete | LeatherZ Armrest | Whalen seat bushings | Z3Solutions Windblocker | Shift Pin fix
Old 11-21-2009, 10:25 AM
aestheticstorm's Avatar
aestheticstorm aestheticstorm is offline
Rad Racer World Champion
Mein Auto: '08 Z4 M Coupé (S.Bronze)
If the wheels are already on the car, it must be working?
'08 Z4 M Coupé Sepang Bronze, Black/Black, Madeira Wood, CDV delete // 49th from End of Production
Old 11-21-2009, 10:44 AM
GB5416 GB5416 is offline
Mein Auto: 2002 M roadster and coupe
The car doesn't look like it has rub issues. If in doubt you can feel the fender liners just inside the wheel well lip to see if they're smooth. The liners are easily abraded if there's rubbing. You do get a harsher ride on the 19s but not to the degree that it should deter you, it's a popular wheel size, especially with Z coupe owners. I looked at the full listing, there is no such thing as an M sport package, non BMW dealers think that there is because of the M on the steering wheel and shift knob, but all late model Z3s have that and there is nothing else M about it.
Old 11-21-2009, 02:25 PM
Randy Forbes's Avatar
Investigative Tinkerer
While those really don't look too bad (except for all the grease on the sidewall__SLIPPERY!), in general, too large a wheel/tire combination will hurt performance rather than enhance it. You have to get those big wheels rolling, stopped and the suspension has to work harder to keep them in contact with the road.
Yes, the Z4Ms may have come with BIG wheels, and do just fine, but the older Z3s were not engineered with that in mind. Unless you plan on running any kind of competitive events, like autocrossing, it doesn't make too much difference.
Randy Forbes
1999///M Rdstr Cosmos Black
2001///M Rdstr Steel Gray
