Old 11-22-2009, 04:28 PM
morrieschoice's Avatar
morrieschoice morrieschoice is offline
Mein Auto: 2001 3.0 Z-3 ROADSTER
Z3 Differential tool
Where do I find a 14mm differential tool...in other words a 14 mm hex (allen)head socket 1/2 inch drive for a "reasonable" cost?? I am about to change the diff. fluid and replace with a redline product. Maybe someone has one f/sale?? Please advise. Thanks!!
Old 11-22-2009, 05:05 PM
FredR FredR is offline
Mein Auto: 96 BMW Z3, 97 BMW M3
I found mine @ Autozone.
Still had to cut about 1/2" from the hex so I could use a rachet.
96 Z3 1.9 Black/tan/black
97 M3/4 Estoril/dove gray
08 3400HST Kubota Orange/gray
08 GMC Sierra CrewCab
Old 11-22-2009, 05:21 PM
Randy Forbes's Avatar
Investigative Tinkerer
Just DO NOT tighten them upon reinstallation to the factory torque spec of 75Nm. Several people have cracked the cover BEFORE reaching that value.
I only tighten them to 45-50Nm, and haven't had any leak, crack or come loose in the past nine (9) years.
Buy two (2) new replacement sealing (crush) washers and reuse your existing plugs.
Randy Forbes
2001///M Rdstr Steel Gray
Old 11-22-2009, 05:30 PM
postalZ3 postalZ3 is offline
Mein Auto: 2000 Z3 2.8
Got mine from Bavauto, send me a deposit, I'll mail it to you and refund your deposit upon return. Forgot to mention is a 3/8"
<img src=http://i.imgur.com/JMjPR.jpg border=0 alt= />
Old 11-22-2009, 05:38 PM
Ron Stygar's Avatar
19,585 Miles
In HC Hotel parking lots .
Old 11-22-2009, 08:02 PM
aba4430 aba4430 is offline
Mein Auto: 1987 Subaru Brat
Thumbs up
I just bought a 9 piece metric set from Harbor Freight. It is made oversees, but for $12.99 (sale price), you get 4 to 8 mm and 10 mm - all 3/8". Then you get 12, 14 and 17 mm - all 1/2" drive. For once in 20 to 30K miles, it should be fine. Link below:
http://www.harborfreight.com/cpi/cta...emnumber=98229
Sears also sells these on-line. See following link:
http://www.sears.com/shc/s/search_10...hex+bit&vName=
Old 11-22-2009, 09:17 PM
jmillet's Avatar
jmillet jmillet is offline
Mein Auto: E86 Z4 M Coupe 7LM08376
FACOM from Ultimate Garage
Order this one from Ultimate Garage:
http://www.ultimategarage.com/shop/p...roducts_id=890
Jim Millet
2007 Imola Red Z4 M Coupe'
Premium Package, Nav, HD Radio, Heated Seats, CDV Delete, RPI Scoop, Strong-Strut fire wall braces, TCK DA Coil Over Suspension with Camber/Caster plates.
Old 11-22-2009, 09:25 PM
Ron Stygar's Avatar
19,585 Miles
Different pic from what I got from him.
Not many will pay for that.
Old 11-22-2009, 09:33 PM
Ron Stygar's Avatar
19,585 Miles
Guide pin socket
STAHLWILLE SOCKET.
Old 11-23-2009, 06:18 AM
bubba1 bubba1 is offline
Mein Auto: 92 toyota p/u 2wd
I got the tool at sears.
Does your clutch still have the squeak?
Old 11-23-2009, 06:55 AM
That was certainly the first one I knew about, but several more since then, judging by the number of people that have wanted the take-off ///M covers. These were owners of ///M cars, not Z3s doing updates.
Randy Forbes
Old 11-23-2009, 08:05 AM
Gentlemen,
How crucial is it that a "stuby" socket be used? If that is the case then I should be looking at the Facom tool or the Stahwille. But do they have them in a 1/2 in. drive cause that's the size of my torque wrench. Please advise.
Old 11-23-2009, 08:34 AM
Gentlemen,
Nothing but a "stuby" socket will fit, specially with a torque wrench.
Old 11-23-2009, 09:32 AM
Ron, can the Stahwille socket be purchased in a 1/2in. drive (my torque wrench is that size) and where can I get it? Please advise. Thanks!!
Old 11-23-2009, 11:15 AM
Ron Stygar's Avatar
19,585 Miles
I posted the STAHLILLE socket since it's like the FACOM one and some may want to purchase it.
The FACOM is a 3/8" 14mm for the diff.
The STAHLILLE is a 3/8" 7mm for the caliper guide pins.
You need more than one torque wrench if working on a car.
I have a 3/8" - 25 > 250 inch pound one along with a couple of 1/4" lower inch pound ones.
I have a 3/8 - 5 > 80 foot pound (one I use the most)
I have a 1/2" - 25 > 250 foot pound (lug bolts)
If you have the room you could use your 1/2" torque wrench and a normal 14mm hex socket.
http://www.unofficialbmw.com/e36/dri...id_change.html
Old 11-23-2009, 03:55 PM
jmillet's Avatar
Gentlemen,
Hazet offers a 14mm hex in 1/2" drive: http://www.samstagsales.com/images/hz985-14.jpg
Unlike the E36 the E36 Z3 M Roadster/Coupe does not have a clearance issue with the top (fill) differential plug, therefore, you don't need a stubby socket.
Clearance is also not an issue with the side mounted differential plugs on the Z4M. The Z4 transmission plugs are a different matter. They require an 8mm hex and the top (fill) plug has minimal clearance. I use a Matco stubby 8mm hex P/N BXYS8M to access the top plug with a torque wrench.
Jim Millet
Old 11-23-2009, 04:19 PM
Ron Stygar's Avatar
19,585 Miles
Less than the Snap-on one. What's the over all length?
Old 11-24-2009, 05:55 PM
Thanks for everyone's advice/help...today looked at 3/8 socket wrench....think I will go with that and get the Facom 3/8 hex socket....much easier than trying to find a 1/2 in socket to fit my torque wrench.
