E46 (1999 - 2006)
Old 08-25-2010, 07:56 PM
G. P. Burdell's Avatar
G. P. Burdell G. P. Burdell is offline
Rambling Wreck
Mein Auto: E46
Originally Posted by gordo325xiwagon View Post
However, rather than removing the reservoir, I was wondering if there was a single line disconnect that would gravity drain most of the fluid? I know that would replace less fluid than a flush; but it is a heck of lot better than using a turkey baster to suck out the old fluid. I was looking at one of the bottom banjo bolts?? What do you think?
If you remove the banjo bolt for the rack-to-cooling-coil hose, you'll drain the reservoir and the coil, but there will still be fluid in the U-shaped pump-to-rack hose, the reservoir-to-pump hose, and the rack itself. You could remove both banjo bolts and drain the system through both hoses, then turn the steering wheel from lock to lock several times to force the fluid out of the rack. Make sure to have replacement crush washers on hand for both banjo bolts - they have different thread diameters.
A siphon pump drains the fluid from the reservoir with less mess than a turkey baster.
Old 08-25-2010, 08:08 PM
gordo325xiwagon's Avatar
gordo325xiwagon gordo325xiwagon is offline
Urban Knucklebuster
Mein Auto: '01 325xit & '93 300zx TT
Thanks Burdell... That is just the info I was looking for. BTW I was just kidding about the turkey baster...gordo
300ZX StgIII (360 rwhp@16 psi) // '97 Jag XK8 - Luxor Cruiser
// 325xit - Best Balance of Ride & Handling
Old 08-25-2010, 09:03 PM
Starless Starless is offline
Mein Auto: 2002 325i Auto
I could not have said better
Old 09-01-2010, 08:49 PM
phamine phamine is offline
Mein Auto: 94 Honda Prelude
Has anyone tried to remove the P/S hose leading the cooling lines w/o the tool?
Old 09-01-2010, 09:50 PM
People have and it took them more time than with the tool, it's a pita but possible...Have not tried it myself though...
Old 09-10-2010, 09:55 PM
I was able to take everything off except the quick disconnects. Oh well - Going to have to buy the tool
Old 09-10-2010, 10:14 PM
av98's Avatar
av98 av98 is offline
ZHP = Patlabor
Mein Auto: Mini Clubmn,Odyssey,Miata
Great DIY!
Old 09-10-2010, 10:16 PM
Originally Posted by 38wildwood View Post
Hey all,
Starless, best DIY presentation ever posted. I was planning on using a line wrench and brute strength for removing the ps lines in place of the $31 tool.
Then I realized I had an old door spring tool that I bought at harbor freight some years back for about $6. They are available at any parts store, possibly even for a free rental. It worked awesome. Fits on the second step-up in the line diameter rather than the first, but it was cake!
Phamine, before you buy the tool, you might want to try what this guy is suggesting. Sounds like it worked for him. Looks like he is referring to something like this:
http://www.harborfreight.com/gm-vehi...ool-95344.html
Old 10-07-2010, 04:46 PM
Tari's Avatar
Tari Tari is offline
Send a message via AIM to Tari
Mein Auto: 2001 330i
can someone save me I don't have that lock on my hose!!! So how can I get mine off ?!?!
** pic was a little disturbing for a signature - Tim330i ** ouch -Tari-
Originally Posted by sonspot View Post
to each his own..
Old 10-07-2010, 07:41 PM
the quick release?
picture??
Old 10-07-2010, 08:54 PM
Tari's Avatar
Its on the lower one and the upper one by the expansion tank has no release my uncle say's he's gonna use a machine and cut it off carefully.(My only resort now)
to each his own..
Old 10-10-2010, 12:39 AM
Tari's Avatar
I got it off. I have to cut it in half. After all these days my car is back together and now i'm having a little trouble stopping the leak from the new hose
to each his own..
Old 10-28-2010, 07:22 PM
Davie B Davie B is offline
Mein Auto: 2001 BMW 325ci
Hey Starless, Great write up!
Although Starless is kind enough to let us barrow his tools (BMW5346) I just used two pairs of channel locks to remove the hoses from the cooling coil. Had them off in no time! But it's great that people share tools on this site. Who knows..... Ya just might need it some day.
Old 02-21-2011, 09:09 AM
Nando779's Avatar
Nando779 Nando779 is offline
Send a message via AIM to Nando779 Send a message via Yahoo to Nando779
Mein Auto: 2003 325Ci, Orient Blue
Tackling this in the next couple weekends. Alex, I did you find this hose to leak as well:
Number 3:
Here at Autohauz #32416750156
Power Steering Hose; Power Steering Pump to Steering Rack
I am replacing all the hoses as well as this one. I took a look under my car and sure enough there was some a good of ATF saturated on it. I will try to snap some pics.
Do you have any idea it this sucker is pretty straight forward to take out?
Thanks.
My bimmer and the son of Sam himself.
http://www.facebook.com/Nando.Alvarez
Old 02-21-2011, 10:13 AM
Rambling Wreck
Mein Auto: E46
That's the pressure hose from the pump to the rack. It's easy to remove and replace. Be prepared to catch plenty of fluid from the pump outlet and the rack when you disconnect the hose ends.
Make sure to get new crush washers for the banjo bolt connection at the rack. Torque to the value found in the Bentley manual.
There is also a little green O-ring for the fitting that connects to the pump. The threaded fitting does not necessarily bottom out on the pump body; the O-ring is what makes the seal. Use a flare nut wrench on this fitting.
If you are changing from the LF-20 pump to the LF-30 pump, the pressure hose is not the same for each. Make sure you get the hose that's particular to the pump.
Old 02-21-2011, 10:26 AM
Nando779's Avatar
Burdell,
Does this green 0-ring come with the new hoses or is it another item I will need to add to my basket. I am not seeing it anywhere listed at Autohaus, would you by any chance have the p/n or a link to Realoem on which part it is? Thanks for the help! Really sucks a special tool is needed to remove one of the lines though. $30 for a little piece of aluminum, dam.
Old 02-21-2011, 10:44 AM
Rambling Wreck
Mein Auto: E46
I think the O-ring is part number 4 on the RealOEM diagram you posted earlier. The new hose I bought at the dealer did not include the O-ring.
The $30 AST tool for the quick release couplings is well worth the price for the convenience it offers. Plus, they're good people over at AST.
Old 02-21-2011, 12:38 PM
Nando779's Avatar
Cool, thanks Burdell.
Old 03-12-2011, 09:58 PM
Germane Riposte's Avatar
Germane Riposte Germane Riposte is offline
Go Hokies!
Mein Auto: 2001 325i Touring 5-speed
Another great Starless DIY!
I did all four hoses + reservoir today. Went surprisingly well, and I managed not get everything soaked in ATF. I had a leaky pressure hose and decided to replace the other three while I had the system open. Bought the AST tool for the connections to the cooling loop, and it worked like a champ.
If you do the pressure hose, you'll also need a 19mm socket for its banjo bolt at the rack end, and IIRC, a 17mm flare nut wrench on the pump end, as G. P. Burdell mentioned. This was for the hose for an LF-20 pump, YMMV with an LF-30 hose.
The bracket/isolator assembly at the end of the loop in the Codan pressure hose (okay, so I wanted to save a few $$$) was a little different than my old hose, but it fit okay after finagling the angle of the connection to the pump.
Old 04-06-2011, 08:14 PM
jrcarter_2000's Avatar
jrcarter_2000 jrcarter_2000 is offline
16 Time Nat'l Champions
Mein Auto: 2012 328i
tool
Where can you buy the removal tool from?
Old 04-06-2011, 08:18 PM
genuity genuity is offline
Mein Auto: 2001 330iS
http://www.amazon.com/Assenmacher-AS.../dp/B002UBO1WA
Old 04-06-2011, 09:50 PM
Pendulum's Avatar
Pendulum Pendulum is offline
Mein Auto: '05 AW/IR M3
I was able to get at the hoses without the removal tool but its was quite frustrating and took a bit of tinkering. The bottom one gave me the most difficulty. I got it loose using two vice grips, or you could try some adjustable pliers.
Maximum PSI Stage 1 Turbo
Old 04-17-2011, 07:26 PM
What did ya'll use to get the banjo bolt off??? That joker is on there and can't seem to get any leverage on it working from underneath....
Old 04-17-2011, 10:46 PM
As far as I remember just a socket wrench. But I do recall the space was tight there.
Old 04-18-2011, 05:45 AM
Rambling Wreck
Mein Auto: E46
In addition to the Amazon link genuity posted, you can also call AST and place an order directly. They're very friendly people.
Same here. No special tools required.
