E46 (1999 - 2006)
Old 05-31-2011, 02:25 PM
TheTemplarSaint TheTemplarSaint is offline
Mein Auto: '01 325i and '09 XRS
Thank you so much Starless! This helped massively and was very well done.
I do have a question for everyone, in the attached photo I have circled a bolt in turquoise. I removed that bolt because I initially did not look close enough at the DIY instructions. I replaced all the lines and res. but I have PS fluid leaking from that bolt I highlighted. It seems to be tightened just fine. I dont recall there being a washer or anything underneath it when I took it out. But I wanted to know what you all thought.
I also could not find that bolt on realoem to see if it showed a washer.
Any help is greatly appreciated!
Thanks in advance!
[IMG][/IMG]
Old 10-27-2011, 10:34 AM
RCorney RCorney is offline
Mein Auto: 325i with M56
Originally Posted by Starless View Post
Hey, guys. If anybody needs "the tool" I'll loan it to you. Just PM me. You leave me the deposit (20$) through paypal, pay for shipping both ways, use it for your repairs, send it back to me, I return the deposit back to your paypal account. So, you end up paying only for shipping both ways. Fair enough?
I'm planning on doing this replacement/ flush along with replacing my pump and res this weekend. Any chance I can borrow your tool? PM me and I can give you my paypal account and fed ex # to ship overnight to my address
Your thread looks straight forward enough to tackle this job myself. Thanks!
03 E46 with M56 engine
Old 09-30-2012, 07:12 AM
semockr semockr is offline
Mein Auto: 323i
Why would you go thru this procedure and not replace the noisy PS pump?
Old 10-26-2012, 10:03 AM
envoid envoid is offline
Mein Auto: 2004 330i
Just wanted to say thanks for having this write-up, Starless! I used it when replacing my pump, resv, and the two resv hoses (turns out one was ready to split open ).
One thing with the hose connected to the cooler, it can be a PITA to remove without the tool. I didn't have the tool and ended up using a crescent wrench but only got it to pop off after sliding out the DS headlight assm. After pulling out the headlight (it just needs to come out enough to give you room, no need to disconnect wires) I put some rag as a leverage point to push against the clip on the hose with the wrench and it popped right away.
Before that I tried with my hands and could tell was really close but not there, and the wrench I just couldn't get the leverage with it (until the headlight was out).
Old 03-12-2013, 01:17 PM
SDpnoy SDpnoy is offline
E46Fanatics
Mein Auto: BMW 330Ci
Wow! Great info OP. Found this from E46Fanatics.com
