X3 E83 (2004 - 2010)
Talk about the E83 BMW X3 in this forum! |
finicky hatch
One peeve I have with my '05 X3 is that unless you close the hatch fairly hard it will not latch completely. I then start my car and the door ajar light is open.
Is this a particular trait for all x3's, or just mine. If so, is there any adjustments I can make? |
We don't have that problem. I don't know if it's because we have the aero kit that has the extra piece at the bottom of the hatch that weighs it down a bit, but it has always shut easily.
I always close it FIRMLY on my 05. If I do not, it does not latch completely.
Cheers
Just Some Consultant "I never understood the dread term "terminal illness" until I saw Heathrow for myself." Dennis Hopper |
I had this on my '07 and on my current '09. It doesn't seem misaligned, just that it needs a little extra something when closing.
"You will have goosepimples." - Kay Segler, Ph.D. |
My '08 X3 suffers the same hatch problem. It requires a firm closure.
2013 535i - ED, Oct 2012 | Cashmere Silver | Oyster/Black Nappa Anthracite | ZCW | Sirius | Air Blue 80 2008 X3 | Monaco | Sand/Black Light Poplar | ZAP | ZPP | ZCW | Xenon | Rear Fog 1988 Grand Wagoneer | Burgundy | Ghost Flames | 360 ci | Holley carb BMW CCA #422951 |
That's odd. I just use the pull-handles, pull it about half way down firmly, and it shuts itself via gravity/momentum. Love German engineering.
same here with an '06
My 07 requieres "firm" closure too.
Maybe you guys that are having issues got a batch of heavy duty hatch struts!! lol. If it is bothersome you could probably get weaker struts to make it close easier. Like Azn, our's basically closes by itself when pulling on the inside handle with a firm pull.
My '06 requires a good slam or the light stays on and i have to stop and close it again. I even cleaned out the latch on the sill but didn't help. I just don't even think about it anymore, just slam it down.
Mine is now silky smooth, but the dealer had to adjust it last month, cause the latch wasn't disengaging propally.
Just a theory, but I tend to think that being overly forceful with slamming it shut can make an initial small misadjustment worse over time. |
Super, you are probably right. However, slamming it down does close it fully and keeps the annoying light off the dash and the courtesy lights out in the back seat.
(OO \ (|||) (|||) / OO) |
Speaking of German Engineering, have you ever taking out the factory jack? Who was the A**hole that designed the bracket that holds it? Note sure if I put it back right but it looks like you slide it under the bracket to the right. The only problem is that I couldn't get both sides to slide under the bracket - maybe it is supposed be like that but one side pops out/slides around easy. I left it like that. I don't hear it rattling because the cargo cover seems to keep it in place
My '04 definitely needs to be closed hard as well...which sucks because if you slam it too hard the plastic tabs that keep the rear panel attached to the door come undone and then it rattles. So I've learned to perform "the perfect slam" - just hard enough to latch and not jostle the tabs. Annoying at times....
My '06 required no particular attention to get it closed. My '09 needs a solid slam.
I wish it would say which door was ajar and would also have an audible warning. I figure it is usually the hatch but it would be nice to have a little voice come out and say which one it is. Maybe the next gen will have the auto hatch closure. This gen of X3s will then be classified as retro. |
Is there any car in this world which "tells" you which door is ajar....?
Yes my other BMW does
My 99 528 shows which of the four doors or the trunk is not closed completely with a dash indicator- pretty cool
May be a Rolls does that.
Agreed! My 2009 works just as expected.
Yup, I had that option in my '07 Passat Wagon, and there is no benefits to it, unless you like to show off in the parking lot ![]() It's slow to open/close, and it doesn't like cold weather. |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
