Old 01-02-2011, 08:48 PM
BMR2009's Avatar
BMR2009 BMR2009 is offline
Munchen bound
Mein Auto: Ferrari
No, they are not.
2016 750i, ordered 5.11.16, delivered 7.9.16, custom build.
2009 750Li 9.14.09 ED
Dropped in Munich on 9/28, Redelivered by ELEKTRA, delivered to my home 11/2.
Old 01-03-2011, 02:43 PM
fallen7 fallen7 is offline
fallen7
Mein Auto: 2010 750i
has anyone tried or know if there's any new products on www.e92-lighting.com that might work for our f01/f02's??
750i. Jet Black. AC Schnitzer Front Bumper , Side Skirts, Deck Spoiler, and Roof Spoiler. Dinan Stage 1 Performance Engine software Boost. 22" Asanti AF 134 forged wheels. Escort Passport 9500ci custom radar system. 8000K HID headlights/ foglights. 3M carbon fiber roof wrap/tape. 3M Crystalline window tint. Matte black trim and badges. MTEC angel eyes bulb.
Old 01-03-2011, 02:48 PM
umnitza's Avatar
umnitza umnitza is offline
www.umnitza.com
Mein Auto: ///M
The ICE Lite will work for your car for a lot less, plus we offer resistors in the unlikely event you get an error, total cost? $80 + possible resistors $24.
Old 01-03-2011, 03:28 PM
fallen7
u have any pics (with n without headlights on) on an f01/f02 7 series? thanks!
Old 01-03-2011, 03:41 PM
fallen7
i like the 65w MTEC's..
Old 01-03-2011, 04:42 PM
BMR2009's Avatar
Munchen bound
Mein Auto: Ferrari
I mean no disrespect, but without pictures, it's all talk folks. If they're good, put 'em up and we'll all see.
Old 01-05-2011, 12:08 PM
mbworldz mbworldz is offline
Mein Auto: 2011 740i Blk/Blk
Angry
Originally Posted by TheBanker View Post
I wouldn't suggest E92 lighting due to the reports about them and the way that they replied.
They are just horrible. Once you bought their stuffs, they want you to keep it no matter what.
Old 01-05-2011, 05:35 PM
BMR2009's Avatar
Munchen bound
Mein Auto: Ferrari
Returning electrical items is always tricky. Unless you know EXACTLY what you're buying, or have an iron-clad return policy, I would not buy. It's just not worth the headache of convincing sellers their stuff is misrepresented or junk. I have five sets of bulbs I tested for the angel eyes, and ALL of them were MISREPRESENTED products.
If you don't see it on a car, in person, or see pics here with great write-ups, you're throwing your money away.
Old 01-05-2011, 08:39 PM
csmeance's Avatar
csmeance csmeance is offline
Mein Auto: 760Li
have any of you guys thought about running a switched, independent Angel eye system?
Basically you wire up a resistor to mimic a factory halogen bulb to the end of the socket. Then you take the positive wire and tap that. That tap will connect to a relay that switches on a separate electrical harness.
This separate harness will basically power up a separate set of bulbs to run as angel eyes. The relay will signal this system to turn on and off as if they were factory angel eyes. You wouldn't have to worry about voltage spikes and as well what the appropriate voltage is or dimming or anything of the sort; electric flow is electric flow and thus will switch the relay either on or off, no inbetweens!
You could do this with a simple HID relay harness and hook up some sort of bulbs to the end, but rather than plugging the trigger wire into the factory headlight harness, you tap the angel eye harness and then place a resistor on the end of that!
Also as I mentioned before, you could run this system with an HID bulb. I see some of you are running bulbs greater than 50 watts! An HID system runs at least 3x cooler than halogens so you wouldn't risk melting anything. As well you would have almost 3200 lumens of light illuminating the rings!
This is just an idea for you guys to toy around with. Implement it if you choose with your own research and caution! If the E65/66 had the ability to run H8 bulbs, I'd already be doing this!
Old 01-07-2011, 06:36 AM
BMR2009's Avatar
Munchen bound
Mein Auto: Ferrari
Read the rest of the thread. It's been done with HID--I posted the pics and commentary.
http://www.bimmerfest.com/forums/sho...415604&page=10
Old 01-07-2011, 07:38 AM
mjr244 mjr244 is offline
Mein Auto: 2011 750li X-Drive
OK...to recap through 23 pages. In terms of H8 bulb replacements, some look good with just the angel eyes on....but almost all of them go back to yellow with headlights on, right?
Bill, did you ever get those bulbs than SAN had posted a pic of and try them? What bulbs are those? Phillips 5k or 6k?
I assume our next option is either doing a LED or HID kit in the angel eyes? Those won't go yellow when they dim.
Old 01-07-2011, 12:44 PM
SAMLAMBO SAMLAMBO is offline
Mein Auto: BMW, Mercedes, Ford
Not as yellow as stock, slightly. The first photo is stock.
ID:	261331   Click image for larger version
ID:	261332   Click image for larger version
ID:	261333   Click image for larger version
2012 BMW 740i
2011 Mercedes E250
2007 Lamborghini LP670-4 SV
Old 01-07-2011, 01:04 PM
SAN....do you have a link to find those bulbs and buy them?
I've been doing a lot of research on this and ordered bulbs from Bimmian. They were $50. It sounds as if this is the best bulb out that is a halogen replacement....whether it ends up being any good we'll see.
I have also ordered LED bulbs, as well.....both will be here next week.
Short of opening the headlight and replacing the angel eyes.....it doesn't seem like there is much out there for us.
There are LED and HID systems.....but I have heard the LED are VERY bright....meaning when you turn your low beams on you aren't going to see the difference between the angel eye and low beam....making it one big huge blob light.
Some of the really good recommended LED ones don't fit our cars....they fit the E90/E92. The Weisslicht...which the LED I bought....are supposed to be the best LED's in terms of what will fit our cars....no error codes, nothing. My concern with the LED is supposedly they are very dim during the day. Again, it depends on the product....so we'll see with these.
Old 01-07-2011, 01:30 PM
Also....as for the MTechs.....one person said they looked like crap, another said they looked great. I'm not sure we can dismiss it based on 1 opinion where pics weren't even posted. Problem with the guy who posted the good pics of the MTechs is they need to be taken in a darker setting....it's just too hard to see otherwise.
If I am not satisfied with the 2 I have coming....I might order the MTechs and break that 1-1 tie. I also would love to try those Philips SAN has. SAN, did you ever send a set to Bill? Or no?
I think the final choices at this point.....the Philips....MTech (possibly...again 1-1)....the Bimmians I am trying....and the LED's I am trying are the best choices we have right now. Hopefully I can narrow that list down in a few days to 1-2 that will produce white error-free light. I have no issue paying $150-200 for LED's if they will do this.
Old 01-07-2011, 08:16 PM
I bought it locally from a shop in Singapore and and have not checked recently if they have stock which they ran out before. It's Philips 5000.
2012 BMW 740i
2011 Mercedes E250
Old 01-08-2011, 04:52 AM
bruno787 bruno787 is offline
Mein Auto: 740Li (F02)
anybody with better bulbs than Philips Diamond Vision 5000k????
i use it and the outer rings are greenish when viewed from the side, and the eyelids are still yellow
15 Maserati Quattroporte GTS
10 740Li (gone)
11 Mini John Cooper Works
12 Range Rover Evoque Dynamic Si4
Old 01-08-2011, 06:49 AM
swb3's Avatar
swb3 swb3 is offline
SWB3
Mein Auto: 2014 i8 and some others
Are those chrome accents on the bumper below the headlights and if so was it a factory install?
2014 i8
Old 01-08-2011, 09:57 AM
Yes it is the factory M sport kit, they offer it in black or chrome
2012 BMW 740i
2011 Mercedes E250
Old 01-08-2011, 08:15 PM
BMR2009's Avatar
Munchen bound
Mein Auto: Ferrari
No, I haven't got them to test yet. It slipped my mind, to be honest.
What do you say Sam, any bulbs for me to test?
Old 01-10-2011, 04:27 PM
hammadurb hammadurb is offline
Mein Auto: 2009 BMW 750li
I bought two sets of the Philips Diamond Vision H8 from this site: IPMart
The two sets with air mail shipping came out to $48. The only downside is having to wait 3-4 weeks to receive the bulbs!
2016 BMW 750i
Carbon Black Metallic - Cognac Nappa Leather - Driver's Assitance Plus I & II- Executive Package - Cold Weather Package - M Sport Package
13 M5 / 12 650i / 09 750li / 06 750li / 03 745li / 00 540i
Old 01-10-2011, 07:36 PM
To be honest, I have not even checked, my bad. I will give thema ring now.
2012 BMW 740i
2011 Mercedes E250
Old 01-10-2011, 11:41 PM
dbs600 dbs600 is offline
Mein Auto: 2011 750LXi Individual
Anyone know how much replacement headlamp assemblies for the F01 7 Series and the F10 5 Series cost?
Trying to get an idea of how much LED assemblies for a facelifted F01 might cost...
Old 01-11-2011, 04:56 AM
huh???? facelifted F01???? does it exist????
10 740Li (gone)
Old 01-11-2011, 08:22 AM
Ha. No, not just yet...
Old 01-11-2011, 06:15 PM
BMR2009's Avatar
Munchen bound
Mein Auto: Ferrari
Between $1,500 and 2,000.
