Hi I have a 1999 528i. I can drive this car from Florida to California and not overheat ( as long as I don't stop ) I have to keep on bleeding the system and the car will be good for the day! I had a friend test the coolant for exhaust and thankfully there was none! I changed every thing in the cooling system except for the radiator, after work I checked the radiator with a tempature sensor gun it was showing about 200 degrees at the radiator upper hose connection and only 146 at the lower radiator hose connection, also the tempature from the clutch fan was about 156, does this seem right, and could a blocked radiator cause air locks?????
