Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series DIY
7 Series DIY
Do It Yourself forum dedicated for 7 Series BMW Owners
Old 12-06-2009, 10:16 AM
wilson009's Avatar
wilson009 wilson009 is offline
Mein Auto: 2002 745i 116k
How to replace your coolant pipe, valve covers, timing gaskets and more
This will be my blog-log for installing the Coolant pipe kit, Alternator Timing Coversetc. Will post my successes and failures with pics. Hopefully mostly success!
In Retrospect this should have been titled my 745 R&R project... Lots of stuff out here so don't get confused. I'll try to make separate DIY's after I'm done.
Hopefully this will help others out there in similar situations and save you some serious money.
Note: During this project I am also replacing my leaking upper timing, lower timing covers, which requires removal of the valve covers. You do NOT need to remove the valve covers for the Coolant pipe Replacement.
I am also replacing a Bad Alternator and a few other maintenance items.
Old 12-06-2009, 10:33 AM
wilson009's Avatar
First check out this post by 07841-tb
http://www.bimmerfest.com/forums/sho...ht=head+gasket
Also 2002 has a fan attached to the waterpump and a water cooled alternator. 2003 up do not.
Also if your going to do this make sure you have a copy of The TIS.
Tools:
Metric Sockets and ratchets several sizes and angles will help you get into the back with odd angles.
metric torx socket set
metric inverted socket set
NM Torque ratchet
Disconnect Battery in the rear. -Replace the battery if your car is 6 years old or more. Its worth the preventative maint.
Remove the Fan Cowl
Remove Fan
Drain the antifreeze
Remove all the hoses
Remove Waterpump.
See waterpump DIY
remove both belt tensioners
http://www.bimmerfest.com/forums/sho...d.php?t=414607
ID:	210853   Click image for larger version
ID:	210854   Click image for larger version
ID:	210855   Click image for larger version
ID:	210856   Click image for larger version
Old 12-06-2009, 10:51 AM
wilson009's Avatar
One you have all the hoses labeled and moved out of the way.
Remove the Expansion Tank and the Air Filter and Box.
A key to this project is to make as much space in the engine to work as possible.
Wire Harness.
Get yourself a labeler or labels and start unplugging the wire harness.
Feed everything out and use string or zipties to hang the wire harness to the back of the hood out of the way.
ID:	210870   Click image for larger version
ID:	210871   Click image for larger version
ID:	210872   Click image for larger version
Old 12-06-2009, 11:08 AM
wilson009's Avatar
Making Space in the engine compartment.
Remove the Partition Wall. About 4 bolts and 2 screws.
Remove the Cabin air filters on passenger and driver side. Also the Adapter hose from the filter that goes through the firewall It comes off easily with by a clip with a flathead.
ID:	210874   Click image for larger version
ID:	210875   Click image for larger version
ID:	210876   Click image for larger version
ID:	210877   Click image for larger version
Old 12-06-2009, 11:14 AM
wilson009's Avatar
Remove the Injection System.
Couple of screws on the top.
Look for a valve on the top. Same fitting that you would blow air into your tires.
Sent low pressure air 3psi into it. This pushes the gas backwards into the tank.
Lift the injectors straight up. - Replace all the seals on this while its out.
Disconnect the hose and set aside.
ID:	210882   Click image for larger version
ID:	210883   Click image for larger version
ID:	210884   Click image for larger version
Old 12-06-2009, 11:51 AM
wilson009's Avatar
Remove Passenger Side Valve Cover.
Remove 13 Bolts
2 bolts are hidden under 2 ground cables. Remove the ground cable and then the bolts.
Remove the Servomotor and the metal plate underneath. make note to Replace the seal underneath.
Remove plates around Intermediate Shaft Sensors in the back these sensors sit underneath the valve covers and work on the timing. They are expensive to replace. but if your car is open your better off replacing it now instead of having to open the car again. #11-37-7-527-017
Remove the Injection Valve Wire harness. This is a attached via a clip and pops off easy.
Lift up the levers on the ignition coils and unplug the wires.
Lift up the harness and attach with other harness suspended on the hood.
Pull out the ignition coils. They slide right out
Break the seal slowly on the valve cover. Do not force.
The sparkplug domes will fall off as you lift. I reached in and pulled them out. BMW recommends these be replaced but they are 27 a piece. so i'll inspect them closer.
Getting the valve cover off involved twisting and lifting over the shaft sensors. Makes me wonder how difficult its gonna be when i need to put it back on but I'll cross that bridge later.
ID:	210893   Click image for larger version
ID:	210894   Click image for larger version
ID:	210895   Click image for larger version
ID:	210896   Click image for larger version
Old 12-06-2009, 12:11 PM
wilson009's Avatar
Driver side valve cover
Driver side Valve cover is the same process just different angles.
You will need to release and move the ARS container and a few small things to get the ratchet in there.
-more pics and pics with covers off
ID:	210906   Click image for larger version
ID:	210907   Click image for larger version
ID:	210908   Click image for larger version
ID:	210909   Click image for larger version
Old 12-06-2009, 12:30 PM
wilson009's Avatar
more pics valve covers off
ID:	210914   Click image for larger version
Old 12-06-2009, 12:42 PM
wilson009's Avatar
Air Intake Manifold
Remove 8 screws.
Unclip on more sensor on the rear. I used 2 flathead screwdrivers. Very Awkward.
Lift Right off.
I noticed some oil residue in one of the hose valves see pic. Plan to open the intake manifold later.
ID:	210918   Click image for larger version
ID:	210919   Click image for larger version
ID:	210920   Click image for larger version
ID:	210921   Click image for larger version
Old 12-06-2009, 12:51 PM
johndade johndade is offline
Mein Auto: 2002 bmw 745li
Excellent write up wilson. Keep it coming. And let us know when your all done how she runs. All the work you done to it lately you should be running worry free soon.
Old 12-06-2009, 01:40 PM
Keif Keif is offline
Master Tinkerer
Mein Auto: 2007 Alpina B7
Beautiful! Keep up the good work!
Old 12-06-2009, 02:37 PM
wilson009's Avatar
Getting to the pipe.
After pulling the Air Intake. A pan sit above the pipe. Take the screws off and pull of exposing the pipe.
Take a SawSaw or Jig Saw and cut the pipe in half.
From there I just pulled out the pipes out. I didn't need to drill a hole and use a block to wedge it out.
Seal in the front was a corroded mess. The seal in the rear looked brand new.
Engine is ready for the Pipe Kit.
Waiting on the mail now.
ID:	210931   Click image for larger version
ID:	210932   Click image for larger version
ID:	210933   Click image for larger version
ID:	210934   Click image for larger version
Old 12-06-2009, 02:54 PM
wilson009's Avatar
more pics of the cooling pipe
Figured the pipe deserved its own area since its the root of the problems
ID:	210937   Click image for larger version
ID:	210938   Click image for larger version
ID:	210939   Click image for larger version
ID:	210940   Click image for larger version
Old 12-06-2009, 05:28 PM
Judd944 Judd944 is offline
Mein Auto: 03 745i Sport / 01 986S
excellent work so far! how soon until your part comes in? was the car leaking from the rear or the front seal?
2003 745i Sport Sterling Gray/Black
2001 986S Seal Gray / Boxster Red
Past:
98 540i Sport
6 944's
Old 12-06-2009, 07:45 PM
mbz1 mbz1 is offline
Mein Auto: bmw e66
All the ones that have gone bad, that i have seen on here have all had green coolant, not the blue coolant that bmw uses.. wonder if that has anything to do with the seal going bad?
Old 12-06-2009, 07:48 PM
I was thinking same thing ^
Old 12-07-2009, 11:26 AM
Wilassasin's Avatar
Wilassasin Wilassasin is offline
Wilassasin
Mein Auto: 2013 S550 amg sport pack/
Great job so far!
Previous: 335i xdrive coupe(sold),745(sold),750 sport(sold).
Current: 2013' S550 4matic, 2016' C7 (stingray).
Old 12-07-2009, 05:10 PM
wilson009's Avatar
No Clue. You could make a survey?
The gasket on the front is clearly degraded and corroded. The other seal is like new in the rear. But it has a different design more traditional oring.
I think it may have to due with heat and its contact with the engine. It has direct contact with the engine block. Clearly a poor material choice that breaks down overtime.
Old 12-07-2009, 05:57 PM
07841-tb's Avatar
07841-tb 07841-tb is offline
Mein Auto: 02' BMW 745li & 04 Rover
My car actually had the bmw coolant in it when the leak started. The pics I posted showed green coolant from me topping it off to find the leak.
2002 BMW 745Li
2004 LAND ROVER RANGE ROVER HSE
Old 12-07-2009, 06:01 PM
07841-tb's Avatar
Looking good dude, keep it up.
2002 BMW 745Li
Old 12-08-2009, 12:54 AM
UltZeven UltZeven is offline
Mein Auto: 2002 745LI
Amazing write up! Cheers!
Old 12-09-2009, 07:30 AM
wilson009's Avatar
Ok for those just doing the All German project. you have do use a wire brush to remove the old seal in the front which is fused to the engine block. This is why I think heat contact is the main cause of this weephole problem(my opinion only) Once the pipe is installed everything just goes in reverse.
I'm going deeper because I have more problems.
Sooo moving on
Removing the WaterCooled Alternator.
I have to say up until this point everything had been surprisingly pleasant.
Now it gets dirty and frustrating
Few bolts on the front of the alternator housing No problem come right out.
Alternator will not budge. This is because there is a bracket that secures the alternator from behind and the bolts are impossible to reach or fit a hand in.
So I dropped the Front Stabilizer Bar/ dynamic drive. I did this by removing the 4 screws securing it to the axle, taking off the bolts, swing support, and loosing the vent pipe which is the black and yellow wire connecting to motor on the stabilizer bar. if you follow the vent pipe it goes to a small fuel filter on the drivers side pop it out and and you can drop the bar.
http://www.realoem.com/bmw/showparts...32&hg=31&fg=10
After dropping the stabilizer bar i bought a set of metric racheting wrenches. Using a 13MM I was able to get my hand in and release the bracket and release the alternator.
wow what a pain. Difficult to get good pictures in there. Did my best.
ID:	211193   Click image for larger version
ID:	211194   Click image for larger version
ID:	211195   Click image for larger version
ID:	211196   Click image for larger version
Old 12-09-2009, 07:36 AM
wilson009's Avatar
couple more pics involved with alternator removal
ID:	211199   Click image for larger version
ID:	211200   Click image for larger version
Old 12-09-2009, 08:12 AM
07841-tb's Avatar
Hey Ed, Why are you removing the Alternator? The reason I ask is because when installing the All German expandable pipe , it does not require removing the timing cover.
2002 BMW 745Li
Old 12-09-2009, 10:00 AM
Blue Bimmer Blue Bimmer is offline
Mein Auto: 03 745Li
I think he said he "is going deeper for other issues", so doing more than necessary for the coolant pipe issue.
I thought Keif did his alternator recently and didn't have to drop too much to get to it?
HTML code is Off
