Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series DIY
7 Series DIY
Do It Yourself forum dedicated for 7 Series BMW Owners
Old 12-11-2009, 08:06 PM
UltZeven UltZeven is offline
Mein Auto: 2002 745LI
Originally Posted by wilson009 View Post
Ok I think I figured out the source of Oil in my Intake Manifold.
Both hoses that run from the Valve Covers are regulated by pressure regulator valves. Those hoses both have oil in them. Those hoses run directly into the Intake Manifold right? Since I have my car apart I can't just look lol.
But but following the trail of oil it went from the Valve Cover, pressure regulator valve, down the hoses and into the manifold where it weeped through the cracked Intake Manifold Gasket on to the Block or was quickly burned off.
Keif remember when I was getting those valvetronic error codes with No description? I wonder if that was the problem....Just Bad Pressure Regulator Valves
Anyway I'm sure this is the problem. No bad pistons No bad pistons!
During my waterpump install the small black Hose that attaches on the boot right infront of the mass air flow meter to the Throttle broke of at the base. It started running rough after that. I can't figure out where that hose goes to. Somewhere in the back of the engine and probably unrelated........But maybe.
http://www.realoem.com/bmw/showparts...68&hg=13&fg=15 parts 4 and 7
Wilson I just replace both of those parts. But mine broke on the boot connector. It did run a little rough and after installing it feels much better. The rubber hose (part # 7 on the link you provided) connects to a metal/aluminum thin pipe that is on the right side of your power steering resevoir. If you look around in that area I'm sure you'll find it easily. I ordered both parts from ECStuning.com (what's cool about these guys is that they're prices are cheaper than RealOEM.com and the dealer). Hope this helps you out. If you can't find that pipe PM me and I'll take a picture and send it to you.
Old 12-11-2009, 08:41 PM
Keif Keif is online now
Master Tinkerer
Mein Auto: 2007 Alpina B7
Yup! ...the hoses from both CCV valves run directly into the upper and lower holes on the face of the intake manifold (see here).
While you have everything apart, make sure the hoses going from the secondary air pump to the secondary air non-return valves (under the back of the intake manifold) don't have any cracks (part #1 here).
On your parts 4 and 7...I broke that a while ago, too. Even a small air leak like that after the mass air meter will definitely cause it to run a little rough / stumble, especially near idle (when there isn't much flow past the air meter to begin with).
White 2007 Alpina B7
Supercharger clutch/bearings (check DIY), sunroof seal, quarterto8's 6000K angel eyes, bumper side mounts
Black 2002 BMW E66 / 745Li (sold)
KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator, sunroof seal, CCVs, NGK Laser Platinum plugs, sway bar bushings, battery, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, alternator bracket mounting gasket, sanded headlights...
Old 12-12-2009, 11:12 AM
wilson009's Avatar
wilson009 wilson009 is offline
Mein Auto: 2002 745i 116k
Removing the Alternator Housing
Ok Why remove the alternator housing?
Because one of the brackets sits directly infront of the lower timing case. So To remove the timing lower timing case you remove the alt housing.
However the engine support bracket sit in front of the Alt Housing and is bolted through it on to the Block. Thankyou to Tommie (07841) for figuring this out before hand and the advice.
http://www.realoem.com/bmw/showparts...73&hg=22&fg=05
Use a front engine support brace on front of car
Remove Top screw of motor mount
Raise the engine about 4-5 inches. This gives you just enough space to get in and start removing bolts
raise motor mount up and stick something under it to keep it out of the way
Remove 4 torx bolts. I had to put heat on 1 to break the grip. Recommend replacing bolts
push bracket to side
Remove last bolt holding alternator housing
Remove assembly and clean
Replace gasket
ID:	211512   Click image for larger version
ID:	211513   Click image for larger version
ID:	211514   Click image for larger version
ID:	211515   Click image for larger version
Old 12-12-2009, 11:15 AM
wilson009's Avatar
More alternator Bracket Pics
Replace this Seal. A bad seal here would definitely cause oil dripping/weeping. As there and opening directly into the block.
No clue why its here doesn't' seem to do anything or go anywhere.
ID:	211518   Click image for larger version
ID:	211519   Click image for larger version
ID:	211520   Click image for larger version
ID:	211521   Click image for larger version
Old 12-12-2009, 11:29 AM
07841-tb's Avatar
07841-tb 07841-tb is offline
Mein Auto: 02' BMW 745li & 04 Rover
Good job Ed.
2002 BMW 745Li
2004 LAND ROVER RANGE ROVER HSE
Old 12-12-2009, 11:41 AM
wilson009's Avatar
Fuel Injector RnR
Since my Fuel Injectors were out I took the opportunity to replace the o-rings. Bad o-rings cause leaking gas and fire. My originals weren't too bad but someone may find this of use at some point.
Remove each injector one at a time and replacing before moving to the next one.
unclip leveling clamp
unclip electrical connections
Pull Straight UP
inspect each injector for damage or clogging
Replace upper and lower o-rings
Make sure housing is clean q-tip
Reinsert injector
Lock clip in with Clamp
Clean Electrical connections with Electric Cleaner and reconnect with electric lubricant sealer
ID:	211525   Click image for larger version
ID:	211526   Click image for larger version
ID:	211527   Click image for larger version
ID:	211528   Click image for larger version
Old 12-13-2009, 10:28 AM
wilson009's Avatar
Pressure regulator valve replacement
Called Crank Case Vent CCV on as well
Simple replacement
When malfunctioning can allow oil to escape into intake manifold. Causing white smoke.
Members have reported howling noises in engine, rough lean running,hesitation as well. Some years had recalls on this.
Replacement is simple just pop off old ones and snap on new ones in same position. push it down each section till you get 6 clicks.
http://www.realoem.com/bmw/showparts...58&hg=11&fg=15 #13
ID:	211650   Click image for larger version
ID:	211651   Click image for larger version
ID:	211652   Click image for larger version
Old 12-13-2009, 10:56 AM
wilson009's Avatar
Crankshaft Hub removal
After pulling the crankshaft bolt
Attach vibration damper to hub with 2-3 screws. Pull Hub straight out.
Pull out crankshaft seal
ID:	211658   Click image for larger version
ID:	211659   Click image for larger version
ID:	211660   Click image for larger version
ID:	211661   Click image for larger version
Old 12-13-2009, 11:07 AM
wilson009's Avatar
Lower Timing case removal
Unbolt all timing bolts. Should be 13 but use realoem as reference
Remove 5 bolts connecting oil pan to timing case
then remove 2 more on each side of the oil pan to take pressure off timing cover (0781tb trick)
remove 2 bolts from each side of engine upper block though head gasket to timing cover
see attached pic for bolt locations.
off timing cover from driver side first.
ID:	211664   Click image for larger version
ID:	211665   Click image for larger version
ID:	211666   Click image for larger version
Old 12-13-2009, 11:49 AM
wilson009's Avatar
tic tic tic tic
OK heres the reason i decided to go through the trouble of removing the lower timing cover.
After i removed the valve covers i noticed the timing chain was shiny on the top.
This is a sign of the chain hitting the block an grooving it. makes a tic tic sound.
Our chains are guided by sliderails which become brittle over time
Sure enough i found grooves on both sides. one rail was cracked. So i will be replacing these rails. See pics for location of grooves and cracks, couldnt get actual pic of grooves due to cams.
http://www.realoem.com/bmw/showparts...68&hg=11&fg=25
ID:	211669   Click image for larger version
ID:	211670   Click image for larger version
ID:	211671   Click image for larger version
ID:	211672   Click image for larger version
Old 12-13-2009, 05:57 PM
Blue Bimmer Blue Bimmer is offline
Mein Auto: 03 745Li
wilson, how are you doing all of this? How do you know to look for these "extra" things? Are you using the service manual? Can someone tell me how to get it?
Why not just pull the whole engine if you're going that deep? Seems like it would be easier to take it all apart and inspect it?
Old 12-13-2009, 06:40 PM
wilson009's Avatar
I'm just working out of my garage on weekends and evenings. My kids and wife are suffering but I gotta knock this out. My references are the electronic TIS which is an electronic manual, real oem for breakout of parts, google, and I read all the problems on this board and the solutions and get help from the guys on here.
I had a friend who was a mechanic that taught me about the timing chain.
I'm not going any farther than this so an engine pull wasn't needed I have no idea how to do that anyway.
By studying and documenting everything it helps me learn everything so I can get it all back together. One nice thing about BMW is all of the visual resources.
Old 12-16-2009, 09:55 PM
wilson009's Avatar
Replacing Driver Side Slide Rails for Timing Chains
--stayed tuned for passenger side, still deep in it.....
When replacing the guide Rails, I noticed BMW offers a kit for this with different part numbers than the originals. This means the product was improved due to issues with the original design guys.....
The new parts are longer and made of more durable metal and material.
Replacing the slides on the Driver wasn't to bad. However BMW has no information on this from what i could find so i went in blind.
Use nail polish to mark your chains to the exact gear notch.
Use zipties to shore put tension on the chain.
Use Clamps and any clamps you have to keep your chains in their original positions.
Loosing the Chain Tensioner Bolt
I replaced the lower slide 1st then the upper slide rail.
Just one or 2 bolts holding each side.
You have to slide the out carefully at the Cylinder Head doesn't give you much room to manipulate the pieces
Both upper and lower slider rails were broken on the tips and the plastic was brittle.
I found more evidence of wear the chain had been hitting the block.
Sliding the new ones in required careful manipulation of consideration of the cylinder head, head gasket and chain.
Last replace the chain tensioner at the top. It has 2 bolts. Lift up the oil spray slightly to removel
Once in tighten your bolts, and chain tensioner.
ID:	212037   Click image for larger version
ID:	212038   Click image for larger version
ID:	212039   Click image for larger version
ID:	212040   Click image for larger version
ID:	212042   Click image for larger version
ID:	212043   Click image for larger version
ID:	212044   Click image for larger version
Old 12-17-2009, 09:08 AM
Jerry 745Li Jerry 745Li is offline
Mein Auto: 03' 745Li
Wilson,
Where are you buying the parts from?
Thanks,
Jerry
I don't have all the answers, but I can do one helluva Google search!
Old 12-17-2009, 02:10 PM
wilson009's Avatar
Mostly at the dealership. All the small parts are oem only.some of the parts are shipped from gerrmany. Ive been gettn 20% discount on everthing. No shippng charges either.
Old 12-24-2009, 03:13 PM
Hope you get back to this project after the holidays. This is one thread I enjoy keeping up with.
Jerry
Old 12-24-2009, 06:39 PM
haz1's Avatar
haz1 haz1 is offline
Mein Auto: 2005 745i
Awesome project, enjoy the holidays if u can, although I never plan on going this deep, I appreciate learning and viewing the pics, much better than looking at a manual.
Name:	Copy of 1212091534.jpg
05 745I 58K
88 735-gone 288K
80 320 gone 300K
76 280Z 2+2 RIP 325K
Old 12-26-2009, 03:25 PM
wilson009's Avatar
Yeah I will be starting back up here. Ran into a few issues. I kinked the oil pan gasket when trying to get the timing cover back on. It was just too tight. Had to pull everything thing off and clear off all the silicone. Very frustrating day that was.
I dropped the lower oil pan then removed the screws to lower the upper oil pan so I can now get the lower timing cover on with no issues. Waiting on my friend to come over and help me with the timing first. After that I will start putting it all back together. I'm glad I did this log as its helped me memorize the parts and locations.
In retrospect it probably would be easier to just pull the engine since I got so deep. But I wasn't comfortable with that idea at the time.
Old 12-26-2009, 04:11 PM
wilson009's Avatar
Timing Rails Passenger side
The timing rails were clearly improved over the older rails in quality and also longer. It also included a new oil spray nozzle that was longer that the previous. However these length differences created all kinds of space issues for me.
This side was just a pain in the rear. I'll try to describe this so it makes sense. But it is just difficult! Unlike the driver side. These the bolts for the slide rails reside between the engine block and the slide rail. So that leaves you about 2 inches of space. Furthermore you will have limited ability to maneuver the rails laterally because they are blocked by the cylinderhead and head gasket that is sticking precariously out.
It almost seems the cylinder head has to be removed to to this procedure or the chains off completely
My solution to this was to break out the old slide rails. When trying to install the new slide rails I had issues with chain tension preventing the rails from being installed as the bolt between the engine was pushing outwards to much that it would have broken chains.
My solution was to cut the bolts leaving a minimum of 5 threads.
This left me just enough space to squeeze the slide rails into posistion and secure the bolts back into the engine using a wrench that I had cut off at the head so I could fit it in there.
I lost the timing during this mess. I have a friend who thinks he can time it. I'll know tomorrow when we give it a go. Otherwise I'll use the timing kit. But the procedure doesn't seem to difficult.
Lost a lot of days on this. But Glad I found it versus having my timing chain explode in the engine 400 miles from home.
ID:	212945   Click image for larger version
ID:	212946   Click image for larger version
ID:	212947   Click image for larger version
ID:	212948   Click image for larger version
ID:	212950   Click image for larger version
ID:	212951   Click image for larger version
ID:	212952   Click image for larger version
ID:	212953   Click image for larger version
ID:	212955   Click image for larger version
Old 12-26-2009, 04:46 PM
wilson009's Avatar
DCS Valve Block Replacement
I had this diagnosed as bad at the dealership earlier. When turning to the left at a certain speed I would hear at distinctive Pop in the lower engine on the passenger side. This is also where the Valve block is located. After pop the Dynamic Stability Control Error would pop up and shut down DSC. I could reproduce the error anytime I wanted by turning to the left and it would reset itself when I shut off the car.
The part at the dealership is $1000 like everything else.
I got lucky and picked up a new one on ebay for $250.
The valve block is nothing more than a heavy piece of aluminum with passageways for the fluids. The fluids are controlled by solenoids in the block. I guess BMW can't isolate which solenoid is malfunctioning so they just replace the entire thing........
To get to the block
Remove the wheel on the passenger side
Remove the access panel to expose the block
Remove some bolts on the under-body protection to give space to get under.
Removal is fairly straightforward.
Use Crows feet to remove each line.
Problems you may run into are the lines being seized up with Rust and needing to be replaced.
Remove the 2 electrical connections.
remove 2 bolts on the bottom holding the block.
Installation requires some care as as the block is aluminum and you don't want to strip the threads from the steel high pressure lines.
I installed the lines on the top of the block first so I could manipulate the block to line up with the lines. They are at a weird angle so it is very difficult to get the threads lined up correctly.
I broke apart the old block to show the components of the block
ID:	212957   Click image for larger version
ID:	212958   Click image for larger version
ID:	212959   Click image for larger version
ID:	212960   Click image for larger version
ID:	212962   Click image for larger version
ID:	212963   Click image for larger version
ID:	212964   Click image for larger version
ID:	212965   Click image for larger version
ID:	212967   Click image for larger version
ID:	212968   Click image for larger version
Old 12-26-2009, 04:56 PM
wilson009's Avatar
Pictures of the Lower Timing Cover
For Visual Reference
ID:	212970   Click image for larger version
ID:	212971   Click image for larger version
ID:	212972   Click image for larger version
ID:	212973   Click image for larger version
Old 12-26-2009, 08:50 PM
Master Tinkerer
Those solenoids look quite similar to the VANOS solenoids. Any indication which part was actually causing the valve block trouble? That first lower timing cover picture gives a great view of the weep hole location. Keep up the good work!
Old 12-27-2009, 08:06 AM
wilson009's Avatar
I have no clue which part of the block was causing the malfunction. The only way aside from a bench test, would be to reverse engineer... I'm sure turning to the left was putting pressure on one of the lines and a solenoid was failing to operate correctly. Just not sure which one that would be..... Good technical docs on the block would help that process if they exist other than in the German labs. This is definitely an ebay or junkyard replacement over new....
Old 12-29-2009, 09:21 PM
wilson009's Avatar
Finally Putting it Back together....
Timing Cover on Last Night and Upper Oil pan and alternator housing tonight.
Slow and tedious but I'm over the hump!
Put in my nonallgerman stock coolant tube and put in extra sealant.
Then moved to the lower timing cover
Timing cover is hard to align with all the metal gaskets and fitting between headgaskets. Its a process I care not to repeat without taking the engine out.
I put sealant around everything. Better safe than sorry.
Put in Crankshaft seal and Bolt
Installed alternator housing with new seal and lil extra sealant and installed motor mount arm. Major pain hardly any room to maneuver tools in there!
ID:	213233   Click image for larger version
ID:	213234   Click image for larger version
ID:	213235   Click image for larger version
ID:	213236   Click image for larger version
ID:	213238   Click image for larger version
ID:	213239   Click image for larger version
Old 12-29-2009, 09:26 PM
wilson009's Avatar
Replacing Stabilizer Bar Rubber Mountings
Unlike the gaskets which got hard. These were soft, and pliable. The new ones were much more firm and held their shape. Should help the Stabilzer Bar which ties into the DSC system.
ID:	213241   Click image for larger version
ID:	213242   Click image for larger version
ID:	213243   Click image for larger version
HTML code is Off
