E46 (1999 - 2006)
Old 01-21-2017, 02:08 PM
MikesBMW2016 MikesBMW2016 is offline
Mein Auto: 2003 BMW XI
Front Axle Nut size E46 -CV Joint.
I am trying to replace Driver Side CV Joint -Axle.
I purchased both a 46mm and 32mm- both 12 point and neither work. 46= 1-13/16. Nobody had a 46mm.
I cannot find any comments on any forum that do not either say use 32mm 12-point or 46mm 12-point socket. Does anyone know what size this really is?
I do not have a micrometer in my shed, if that is the only way to tell I will go buy one.
How can this front Axle nut not be either 32mm or 46 mm?
Any help is really appreciated. I drove all over the place before I finally found a 1-13/16 just to find out it is too big. 32mm is too small.
Hmmmm. 2003 BMW 325xi e46.
Old 01-21-2017, 03:20 PM
ld330xi ld330xi is offline
Mein Auto: 335i
My axle nuts on my e46 xi on the front were 36mm 12pt. I used that socket to do oil changes once I rebuilt the front axles. I got mine from NAPA.
Sent from my Pixel using Bimmerfest mobile app
Old 01-22-2017, 11:32 AM
Thank you for the reply. Turns out mine was an aftermarket Axle. Got the car from original owner so no idea what he bought.
All good so far.
axles, cv joint
