Which 18" rims fit w/ BMW center caps? - Bimmerfest - BMW Forums
Sponsored by The Tirerack. Moderated by Rudy@Tirerack.com
Old 12-08-2009, 07:08 PM
bhuether bhuether is offline
Mein Auto: BMW 2010 335d
Just want to make sure I order a set that will accept the center cpas.
thanks,
brian
Old 12-09-2009, 10:11 AM
Rudy@Tirerack's Avatar
Rudy@Tirerack Rudy@Tirerack is offline
Moderator
Mein Auto: 1-800-428-8355 X4664
thanks,
brian
The ASA AR1, Moda EB1, and the Bremmer Kraft line of wheels will all accept BMW caps.
Wheels http://www.tirerack.com/a.jsp?a=AB2&...eels/index.jsp
Refer to 'Rudy/Bimmerfest' as your previous contact when you order online. Credit Bimmerfest.com by CLICKING HERE.
Rudy@Tirerack.com
Old 12-09-2009, 11:19 AM
thebmw thebmw is offline
'Fest Advisor
Mein Auto: BMWs and other fine cars
My rims don't take BMW center caps (MSW). Are there alternatives, (i.e. stickers, appliques?)
Old 12-18-2009, 10:35 PM
Jsborn Jsborn is offline
always learning...
Mein Auto: '89 Porsche 944 S2
Any others?
Is there an easy way to search for or somehow find all wheels that take BMW center caps?
E93 335is DCT w/ Invisihitch + 1Up, split armrest, stainless lines, track pads...super fun
Recent ex: Porsche 944 S2
Former Bimmers: Dinan E39 M5, E90 335i 6mt sport JB+, E36 M3
Old 12-21-2009, 11:19 AM
Moderator
Originally Posted by Jsborn View Post
Any others?
Very few wheels do, but I have to check each one manually. Were there two or three wheels you'd like me to check on?
Rudy@Tirerack.com
Old 12-21-2009, 03:47 PM
always learning...
Thanks for the offer! The few you listed will work, though, if I end up ordering a set for this winter.
Old 12-22-2009, 08:09 PM
always learning...
Actually, I'll take you up on that offer. How about the Sport Edition KM11? Also, I don't see an option to PM you, which probably makes sense given how many you would get--but I've got a question:
1. If a test drive goes well, I'm going to pick up an '07 335i sport pkg about 250 miles away later this week. I need to be able to drive it home so I'm going to order wheels and tires in advance and have the dealer install. I'm not sure whether to select rubber or metal valve stems--does it matter which I select since I'm swapping wheels and tires? If so, is this something I can have the dealer check (how exactly?)?
Thanks very much! Given the complicated order, I think I'm going to call. Should I just tell the person about this forum? (I need to know when it's going to arrive, ask about TPMS, this valve stem question)
Old 12-23-2009, 05:43 AM
Moderator
While the KM11 does accept BMW caps, it is sold out and discontinued, sorry.
Call me directly, see signature. The metal versus rubber valve stem info is needed as it tell us which TPMS system you have.
Rudy@Tirerack.com
Old 07-07-2013, 02:29 PM
DavidNJ DavidNJ is offline
Mein Auto: 01 530i; 04 S2k; 94 Supra
Why doesn't the Bremmer Kraft BR09 come in an F10 bolt pattern?
Old 07-08-2013, 05:54 AM
Moderator
All modern BMW bolt patterns are 5-120 and the BR09 is indeed available in this bolt pattern. However, there is much more to wheel fitment than bolt pattern. What actual year and model of BMW are you trying to fit these wheels on?
Rudy@Tirerack.com
Old 07-08-2013, 07:28 AM
I was using the 2013 F10 although it would be on a 2014.
I was looking for a clean BMW-like design that would take a BMW center cap and have a chance of surviving NJ roads. I was looking for a silver similar to the BMW silver, not chrome, polished, grey, or black.
Old 07-08-2013, 11:29 AM
Moderator
Since wheel fitment is more complicated than just using the bolt pattern, I'll need to search by the year and model of the BMW. The full model, IE 2013 550i, 2013 535i X drive, etc. Once I know your actual model I can confirm that a given wheel is made to fit your car. Alternately, you can enter your year and model of car into our wheel search online to view available fitments here :
Rudy@Tirerack.com
Old 07-08-2013, 11:45 AM
2014 530d
Old 07-09-2013, 08:32 AM
Moderator
We have not been able to get a 2014 530d to test fit as of yet, so we are unable to confirm any wheel fitments on this vehicle. We expect to have more data in a couple months.
Rudy@Tirerack.com
Old 07-09-2013, 08:54 AM
The 2014 is the same as the 2011-2013 models. Does the wheel fit those?
