Old 12-10-2009, 04:03 PM
hanzo540i hanzo540i is offline
Mein Auto: 2009 X5 35d
Right turn signal won't cancel
Howdy all.
On my 99 540i the right turn signal works in the neutral, or in the right position, as long as the key is on, or if the car is running. When I turn the key off the turn signals stop flashing. The left side appears to work fine, but if I return the stalk back to the center position, or the right position, the right side starts flashing. All of the turn signal lights, front and rear work like they should, (flash at normal speed) and the dash indicator lights work fine.
I haven't modified anything within the light system, factory Xenon system. I don't think it is the LCM, since they stop flashing when I turn the key off. I am at a loss. Anyone out there have any ideas? Maybe the turn signal stalk is bad?
Thanks.
Old 12-10-2009, 09:47 PM
bmw_n00b13's Avatar
bmw_n00b13 bmw_n00b13 is offline
Freude am Fahren
Mein Auto: 99 528iA
Probably the turn signal stalk. http://www.bimmerboard.com/forums/posts/551946
'99 528i ('98/12 build). 282,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals, increasing amounts of duct tape and glue
'99 540i (grandfather's)
Old 12-11-2009, 08:33 AM
Thanks for the great writeup. It will make this job much easier! By the way I disconnected the battery last night, to try to reset everything and when I reconnected the battery, the right parking lights came on... another indication that the stalk is broken internally.
Thanks again for your help.
Old 12-11-2009, 09:23 AM
bmw_n00b13's Avatar
Freude am Fahren
Mein Auto: 99 528iA
Yep, guess you have the new LCM with the one-side signal lights.
If it's not the stalk, it's probably the LCM or trunk wiring harness. Try to find a used stalk though, new ones are pretty shockingly expensive.
e38.org is an overlooked, excellent resource!
Old 12-12-2009, 01:54 PM
Yeah, I know what you mean. I did find a used switch for $30. It will take a couple of days to ship though. I went through all of the wiring pretty good and checked everything, including all of the grounding points.
I took apart the old switch and nothing looks bad... maybe one of the tiny resistors has gone out, time will tell when I get in the new switch.
All of the part numbers I found said that if the car was built before 02/99, then it has one type of switch, if it was built after 02/99 then it used the latter type. My car was built on 11/98, but it has the latter type of switch... weird. Maybe this has something to do with the Sport package?
Anyhow, I'll wait for the new switch and see what happens. Thanks again for your help.
Old 04-22-2014, 11:11 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
See also:
> E39 (1997 - 2003) > Turn signal stalk locked into position, until I forced it, & something snapped!
> E39 (1997 - 2003) > Turn signal/high beam switch repair
> E39 (1997 - 2003) > Turn signal wont reset after I make a turn
