HVAC controls froze - Bimmerfest - BMW Forums
E46 (1999 - 2006)
Old 12-10-2009, 04:05 PM
ddkk10 ddkk10 is offline
Mein Auto: 2004 330Ci
HVAC controls froze
The weirdest thing happened the other night when I was driving home on the interstate. I reached down to turn on the defrost because my windows were fogging up and when I pressed the button it wouldn't turn on. I tried changing the temperature settings and the fan speed and they didn't work either. The HVAC display was frozen and none of the controls worked. I had to pull off to the side of the road because I couldn't see squat out of my foggy windows and even when I turned off the car and took the key out of the ignition, the HVAC system stayed on and kept blowing. I ended up having to disconnect the battery to get the darn thing to turn off. Anyone else experience something like this? I guess I should have expected sooner or later I'd experience some sort of electrical bug...german cars don't exactly have the best reputation for reliability in that area.
2004 BMW 330Ci - Sport Package
Old 12-10-2009, 11:35 PM
Starless Starless is offline
Mein Auto: 2002 325i Auto
There is this thing - Blower Motor Resistor aka Final Stage Unit. When it goes bad the usual symptoms are erratic fan behaviour or even HVAC controls failure.
I'm not 100% sure that's your case but it looks like it might be it. Research it and see if someone else had the similar symptoms due to FSU. The part is not expensive and it's like 30 minutes diy.
Good Luck!
Old 12-11-2009, 03:27 AM
Beltane's Avatar
Beltane Beltane is offline
Yankee
Mein Auto: 2003 325xi 5-spd
It does sound a lot like the blower resistor - I've already replaced mine twice. The first time it went the blower wouldn't turn on, the second time the blower was stuck on and I had to take out the fuse to turn it off. Relatively easy fix on my car - had to pull the glove box out and feel around behind there. If you do a search you'll find a bunch more information on it. Good luck.
2003 325xi 5-speed & 2009 Massey 1540 HST
Old 12-12-2009, 08:33 PM
Thanks for the help guys. I searched through the site and found quite a few threads discussing the same problem just like you said. Sounds like the resistor might be a little tricky to get at but it's a relief to hear it's actually a relatively common issue with a straightforward DIY fix rather than something more serious.
Old 12-12-2009, 08:42 PM
KrisL's Avatar
KrisL KrisL is offline
Ubergeek
Send a message via AIM to KrisL Send a message via Yahoo to KrisL
Mein Auto: 330i ZHP
The same thing has happened to me twice in the last 5 years.
Pulling the fuse is faster than disconnecting the battery.
It's not the final stage resistor.
climate control, fan, frozen, hvac, stuck
