E46 (1999 - 2006)
Old 12-12-2009, 09:26 AM
dcc13 dcc13 is offline
Mein Auto: acura
Transmission fluid 2002 325i
What type of automatic transmission fluid is needed for my sons 2002 325i ? How do I check the transmission fluid? Where do I add the transmission fluid?
Old 12-12-2009, 09:51 AM
KrisL's Avatar
KrisL KrisL is offline
Ubergeek
Send a message via AIM to KrisL Send a message via Yahoo to KrisL
Mein Auto: 330i ZHP
All of your answers can be found in the wiki. Sticky post at the top of the forum, also linked from my signature.
Old 12-12-2009, 01:01 PM
Starless Starless is offline
Mein Auto: 2002 325i Auto
Depends on the transmission type - ZF or GM (can be either or for this year and model). Most likely GM though. There is a sticker on the transmission pan with the part number of the fluid(can be covered with grime and hard to see) GM fluid will be 83220024359 which is Texaco ETL 8072B. ZF fluid is part # 83229407807 which is ESSO ATF LT 71141 fluid.
You would add fluid through the fill plug with the car running and fluid warmed up to the temperature between 85 and 120 F. Here is the picture of the fill plug # 7 Torx 45 in case of the GM transmission:
Hope this helps
Old 12-12-2009, 01:33 PM
mujjuman mujjuman is offline
tappa tappa toit
Mein Auto: hoopty
Is there something wrong with your son's car's transmission?
mujjuman
Old 12-12-2009, 02:42 PM
Mein Auto: acura
Smile
I think a transmission line has a leak but no more fluid leaking due to no more in it? He pulled off the highway and had the car towed to my house.
