Rough idle and hard cold start - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E28 (1982 - 1988)
E28 (1982 - 1988)
Old 12-12-2009, 08:52 AM
boomhuck boomhuck is offline
Mein Auto: 1988 528e, 2007 328i
Hello Everyone,
A couple of things happening on my '88 528e.
1. Before the cold truly set it, the car starts after a couple of tries. Then after hitting a steady state idle, everyone once in awhile the idle speed will drop a few hundred RPM and then jump back up.
2. With the frigid weather in WI, I came out in the morning to my garage (~50 deg F), and she started up OK (typically the same) as any other morning. Drove to work, and parked outside. Temp about 12 deg F all day. When I came out that night to go home, it was very difficult to start. Turn over fine, but just wouldn't fire off right away. Took about 10 cranking tries to get her going. Once started, still had the rough idle (dipping a few hundred RPM's for a second or two).
Any ideas?
Thanks.
Old 12-12-2009, 09:45 AM
south26 south26 is offline
Mein Auto: 535i 1989
Maybe the cold start valve?
Andy
Old 12-14-2009, 03:18 AM
jvaughn21 jvaughn21 is offline
Mein Auto: 1988 E28
Mine (same year) is really cold blooded, so i let it warm up a while before i drive it, or else it is really hard to motivate.
cold, cranking, rough idle, starting
HTML code is Off
