Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series DIY
7 Series DIY
Do It Yourself forum dedicated for 7 Series BMW Owners
Closed Thread
Old 12-14-2009, 11:29 PM
Keif Keif is online now
Master Tinkerer
Mein Auto: 2007 Alpina B7
DIY - 02 745Li Oil pump/front axle support drop procedure
See my flickr set --> here for steps/pictures.
Fyi, you won't likely ever have to replace your oil pump...the oil pump on the N62 is practically indestructible. Though there is a spring that can break, it apparently very, very rarely happens.
Regardless, if there is another reason that you need to drop the front axle support, here is how, and what to expect.
White 2007 Alpina B7
Supercharger clutch/bearings (check DIY), sunroof seal, quarterto8's 6000K angel eyes, bumper side mounts
Black 2002 BMW E66 / 745Li (sold)
KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator, sunroof seal, CCVs, NGK Laser Platinum plugs, sway bar bushings, battery, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, alternator bracket mounting gasket, sanded headlights...
Old 12-14-2009, 11:38 PM
robohopar's Avatar
robohopar robohopar is offline
Mein Auto: 06 750Li
wow amazing DIY write up Keif...
i give you props just on the attempt. you got the car put together and running now?
2006 BMW M5
SOLD: 2006 750Li Monaco Blue/Black|Sports Package|Convenience Package|Comfort Access|Logic 7|Rear Entertainment|Night Vision|SAT/HD|Cold Weather|Luxury Seats|Rear Power Sunshades|35% Tint|22" Custom Wheels|H&R's|Alpina Trunk Spoiler| ACS Roof Spoiler| MTEC v3|
Old 12-15-2009, 02:29 AM
Master Tinkerer
Oh yeah, the car is all back together and running fine now...I've actually had these pictures up for quite a while but didn't realize that I hadn't posted a link anywhere.
This was only one part of my low oil pressure troubleshooting that went on every night for the entire summer of 2008 (you can see one of my later troubleshooting plans in some of the later pictures). What a nightmare. I actually ended up dropping the oil pump twice...I did a simple replacement the first time; the second time I took it down to vacuum small pieces of plastic out of the block and heads (through the main oil bore near the crankshaft), which ended up being the actual reason for the low pressure. I think this was actually the first thing I had to do to the car aside from an oil change...what a pleasant entry into E65/E66 mechanics! Through this I did learn a lot about the engine and the various resources available for these cars, so I am thankful for that.
One of the most valuable things I learned doing this was that you really don't need any BMW special tools for a lot of things. For example, BMW lists several front axle support pieces that total a few thousand dollars -- which you supposedly need to lower the front axle support. As you can see, I found a much cheaper - and in my opinion much better - method of lowering it using just dowels threaded into the front subframe (to guide the front axle support up and down) and a single jack on axle carrier's jack pad (to raise/lower it).
As a side note, a while back I reordered some of the pictures, so if any seem out of order please let me know.
Old 12-15-2009, 05:11 AM
wilson009's Avatar
wilson009 wilson009 is offline
Mein Auto: 2002 745i 116k
There the pictures are!
Closed Thread
axle, front, oil, pump, support
HTML code is Off
