The X5 SAV Forum
Old 12-15-2009, 07:25 PM
Camiam Camiam is offline
Mein Auto: X5, 328
Help!! Change brake light bulb on 2005 X5 4.4i
Can someone please help me with some step by step instructions ( and if possible some pictures ) on how to change brake light bulb. Dealers want 200+ dollars to change a 5 dollar bulb.
Best Regards
Old 12-16-2009, 08:42 PM
someplaceelse someplaceelse is offline
Mein Auto: 2002 X5 3.0
I noticed no one had replied - I have a 2002 but if they're the same it's about easy as can be. Mine just has bulbs plugged into a plastic housing that you can get to by removing the rear access panel(s) inside the car.. It may be a totally different set up for a 2005 but it still should be pretty easy.
It's the front turn signal bulbs that give me grief. Doable, just a pain in the arse.
Old 12-17-2009, 12:07 AM
AlsX5 AlsX5 is offline
Mein Auto: 2005 X5
I also have '05 4.4. It's very easy to change the bulb. Just open the side cargo panel right or left. You'll see the bulbs attached to "white" bulb housing. There's three but the brake light is the middle one. Reach in with your hand, grab the white housing and give it a quarter turn counterclockwise and the housing will come loose. There are no wires attached so replace a new bulb into the white housing and place it back into the slot with a quarter turn clockwise until it's tight. ridiculous that the dealer will charge for this. it should be free.
Old 12-18-2009, 05:21 AM
Mein Auto: X5, 328
Help on Brake lights
Thx so much guys. I will try it today. Appreciate your help in this matter
Old 12-18-2009, 06:17 AM
Marshotel Marshotel is offline
Mein Auto: 2017 X3xdrive28i on order
The dealer reall rips you off for some things. I had to change a rear turn signal bulb in my wife's X3 last weekend so I went to the dealer to buy the buld. They wanted $25 for the bulb! Needless to say, I went to a local auto parts store and got 2 for under $10.
I'll keep my guns, freedom and money.......You can keep the "change"
Old 08-29-2010, 02:09 PM
pwdoc16 pwdoc16 is offline
Mein Auto: 2006 X5 3.0
Don't pay the dealer to replace tail light bulbs. Got a 2 pack of bulbs from rockauto.com for $1.27 + $1.43 s/h...less than 5 bucks. Once you remove the rear inside panel just locate which of the three white bulb-housings you need (middle one for brake light), give the bulb housing a quarter turn counterclockwise to remove. From there remove old bulb then insert your new bulb, and return to socket with a quarter turn clockwise. Literally took me a minute and a half, and I'm no mechanic by a long shot. Save your money for the big stuff.
Old 09-07-2010, 07:37 PM
KaseyD KaseyD is offline
Mein Auto: X5 4.4i
be careful. i did replace the bulb and it was super easy, but ultimately both rear brake light assemblies had to be replaced.... apparently the 2005 X5 has a well known problem (but, not enough for BMW to cause it to be a defect...). Cost of replacement of the assemblies $300 apx apiece. took less than 1 hour.
Old 12-12-2010, 11:18 PM
vtrotter vtrotter is offline
Mein Auto: 2001 X5 3.0i
Temperamental Rear Lights
My tail lights, rear brake lights, and rear turn signals occasionally stop working. I have to go in the back, open the access doors, and jiggle them to get a connection and they start working. Any suggestions on how to keep them working? Now the cops have stopped me for lights out. I need a permanent fix. Thanks.
Old 12-13-2010, 12:25 AM
Raimo Raimo is offline
Mein Auto: 550i
Poor ground maybe. Unplug the plastic socket from the light and bend the two metal clips upwards to get a better contact. Also check if the metal on the taillight itself insn't oxydized.
Old 12-18-2010, 10:06 PM
Thanks. I have actually done that. Looks like I am on the right track, so I will do it again.
Old 12-10-2012, 05:18 AM
nezarnuaimat nezarnuaimat is offline
Mein Auto: X5 E53
Is it 5 watts bulbs?
Old 12-10-2012, 09:01 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Help us help you better...give a model year or at least a build date so that we can be sure we're giving you the correct answer/suggestions.
Below, is info from my 2006 owners manual....it says to use a 21 watt bulb. I'm not sure if the 2000-2003 use the same bulbs or not...so take consideration that this info may not be the same for the earlier models.
Q {BMW CCA Member #191509}
(SOLD)
Old 12-12-2012, 12:05 AM
white_lancer white_lancer is offline
Mein Auto: E53 X5 2004 3.0 SPORT
Had similar problems with the brake lights on my E53 2002 4.4 one stopped working - then the other. landed up replacing both bulb holders with new and both bulbs with new - sorted. must have been poor contacts
E61 2.0D Auto
Old 08-25-2013, 01:35 PM
X5BimmerCT X5BimmerCT is offline
Love my UDM
Mein Auto: 2005 BMX X5 3.0i
Angry The bulb and THEN some...
Hey guys, saw this post and need some help. 2005 X5 3.0i. I too have had and issue with the rear taillight message. Like most, I headed to the parts store and bought the replacement bulbs. Noticed that I still got the error and upon some checking, found some scoring around the white bulb socket?
1). should I replace it? and
2). could this cause a short to draw AC current from my battery? My X5 just died in someones driveway today (very embarrassing) got a jump and drove away. I purchased a new battery but have yet to install it until I can get some feedback.
Thanks you guys.
Name:	bulb housing.jpg
ID:	393527   Click image for larger version
Old 11-23-2014, 12:45 PM
mlio's540 mlio's540 is offline
Mein Auto: 2003 E 39 540i
Lamps and bulbs
THIS WAS VERY HELPFUL FOR ME - THANKS - REPLACED BRAKE LIGHT BULBS - NOTICED THAT REFLECTOR LAMP NOT ILLUMINATED - APPARENTLY THE BULB HOUSING IS MISSING - THE CAR HAD SOME "REAR END' WORK DONE BEFORE WE TOOK OWNERSHIP AND I THINK THE BODY SHOP "FORGOT" TO REPLACE THEM!!!!!
Old 11-24-2014, 06:07 AM
QSilver7's Avatar
You may want to refer to the rear tail light bulb index for your e39 and note the location for each rear tail light bulb. The ones shipped to the USA did NOT come with the bulb for the rear fog light...so most BMWs have an empty location if they have their original rear tail lights.
(SOLD)
