2010 X5 diesel engine malfunction error - Bimmerfest - BMW Forums
Old 12-18-2009, 08:33 PM
New2diesel New2diesel is offline
Mein Auto: 2010 X5d
Was driving the new X5 diesel on the highway with only 760 miles on it. During mild acceleration, I got an error messange that engine power was being reduced due to engine malfunction. After 10 seconds, the warning disappeared and never returned during the trip home. Has anyone experienced this. Should it warrant a trip back to the dealer?
Old 12-19-2009, 03:22 AM
Craig B Craig B is offline
Mein Auto: 2009 X5 35d 2007 Lexus LS
Someone on one of the other forums posted about this error. I've never seen it on mine. Post over on x post, I'm sure someone will answer your question.
http://www.xoutpost.com/bmw-sav-forums/x5-e70-forum/
Craig
Old 12-19-2009, 01:33 PM
GoVols! GoVols! is offline
Mein Auto: 2009 X5d
I got the same message a couple months ago, at 5000 miles. I think there are two options for the problem. If it goes away and doesnt come back, you probably got an air bubble in the fuel line from running the tank too low. Nothing to worry about. The other option is a bad fuel pump. This is what they determined my problem to be after an hour or so at the dealer. There has been quite people on xoutpost with the same issue.
Old 12-19-2009, 04:17 PM
XXX555 XXX555 is offline
Mein Auto: 2012 M3 cab
It may have to do with that intermittant diesel blow off per the owners manual which states this occasional burn off may reduce performance for a short period...
Old 12-19-2009, 05:27 PM
No it doesn't have anything to do with the burn off. I haven't noticed any loss of power, but have smelled the burn off when i've parked in my garage at home.
Craig
Old 12-19-2009, 05:33 PM
Craig
I recall the owners manual specifically mentions brief loss of power/performance may be noticed when the burn off occurs.
In any case, there is not supposed to be a engine malfunction light so I otherwise withdraw my response.
Old 12-19-2009, 06:16 PM
Marwan Marwan is offline
Mein Auto: 2018 X5 xDrive 35d
Craig
I also have not experienced any loss of power but have smelled something burning in my garage right after turning off my car on a few occasions now. How frequently does this burn off occur? Initially I thought the smell had to do with the brand new engine, but then I started getting worried and popped the hood once just to take a look (don't know what I was looking for or what I would have done if I found something abnormal, but I could not resist the urge). I now have about 1200 miles on it and I just came back home and that "something is burning" smell was there again.
I had read about the burn off in the manual but for some reason never connected the burning smell with it. Are you sure this is due to that burn off?
Old 12-19-2009, 06:54 PM
Yes, the smell is coming from the exhaust. I haven't noticed how often, but every now and then, I've had the smell. I've had mine for a year. It doesn't cause an engine malfunction light to come on. I don't notice any loss of power, but it sure smells up my garage when I shut off my car from time to time...
Craig
Old 12-19-2009, 06:57 PM
Penguin Penguin is offline
Mein Auto: Z4 and X5 Diesel
I recall reading somewhere that the particulate burn-off could happen as often as every 200-300 miles, but I'm not 100% sure of that, since I cannot remember the source.
Old 12-19-2009, 08:32 PM
Mein Auto: 2010 X5d
Thank you for your replies. I have decided to wait for the problem to declare itself with a CEL, if it truly is related to the fuel pump, before bringing it back to the dealer.
Old 12-19-2009, 10:16 PM
Mein Auto: 2009 X5d
The only way I've noticed the burn off is a pretty big hit on the instant mileage gage. Cruising along on the highway at 30+ mpg, all of a sudden it drops to 20 for 10-15 miles.
Old 12-19-2009, 11:26 PM
Armand Armand is offline
Mein Auto: 2010 X5 35D
I got the exact same thing on my 2010 X5 35D when I only had 300 miles on mine. It was about ten minutes after my first fuel up. The tank was still about half full when I decided to top it off for the journey ahead. The warning appeared after a short burst of acceleration and then it went away. I was on the freeway and you can imagine, it scared the hell out of me. Any way, I followed up with the dealer, took it in and they were unable to find any logged errors. I have tried to reproduce the error by driving fast, slow, you name it. It has not happened again. Hope it helps. I have about 1200 miles on the car now.
Old 12-20-2009, 11:46 AM
ard ard is offline
Resident Curmudgeon
Originally Posted by Armand View Post
I followed up with the dealer, took it in and they were unable to find any logged errors. .
That's really surprising...Personally, I don't trust dealers, but I suppose it is possible.
I'd still want a dump of the DME and look at every code.
A
Old 12-20-2009, 08:38 PM
jaaX3's Avatar
jaaX3 jaaX3 is offline
Yes, please!
Mein Auto: 318ti Clubsport
It's probably a good idea to at least have the fault code checked.
Old 12-22-2009, 08:24 PM
Mein Auto: 2010 X5d
I have since added another 400 miles to the X5 without a problem.
Old 05-09-2010, 07:05 PM
dtanner dtanner is offline
Mein Auto: BMW X3
I have an X5 diesel and it has been in the shop 3 times with exhaust fluid reservoir problems. I also got the engine malfunction problem and had to have the internal control unit replaced when it was less than 6 months old. Today while driving, the car jerked and the engine malfunction...power reduced message came on and the car would jerk and not accelerate. I had to have it towed to the dealer. I am really, really tired of the problem with this car, I don't trust it anymore.
