Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > BMW Motorcycles (aka Beemers) and the Competition
Have an interest in BMW motorcycles or just motorcycles in general? Discuss the line of BMW motorcycles and how they may compare to the rest of the competition in this forum!
Old 12-20-2009, 03:57 PM
Infedel 07 Infedel 07 is offline
Mein Auto: BMW R1100R
Fuel Injection system
Hi guys I'm new to this site and I was wondering if you could be of some help. I took a four hundred mile ride around my state on my BMW R1100R and it was great. But in the last seven miles my two brothers pipe separated from its header. The header was still attached to the end of the exhaust pipe but there was an inch gap between the pipe and header. I was on the freeway so it was hard to pull over but when i did i parked the bike and looked at the damage. I guess who ever I paid to put on the pipe was incompetent and put the rivets in, in a weird way. Thus saying it came apart. Well I field stripped it and then put it back together and it fit fine for the short ride home. But when I went to start the bike it would idle for a couple seconds then die. I tired it four or five times with no avail. So I had my riding buddy go pick up my truck and trailer.
This being said I think riding at such high speed for the short while screwed up my fuel infection. In my opinion it leaned it out so now it won't run. My question is "are there any ways of resetting or rebooting my fuel injection system or has this happened to anyone else?"
Old 12-21-2009, 11:38 AM
mullman's Avatar
mullman mullman is offline
friend of the marque
Send a message via AIM to mullman
Mein Auto: '09 MINI, '09 HD, '67 BMW
Try disconnecting the battery for 15 mins or so.
If that does not work, let it sit overnight.
Personally I would check the plugs as well, basically just out of habit - although I realize the system probably shut down the bike before serious damage would have occurred.
• BMWCCA VBMWMO BMWVMCA •
'09 MINI S: 'Ronin' '09 H-D Nightster '67 R60/2+'52 Steib sidecar
•previous '95 318i '00 540i6 '61 R50S '69 R69US '98 R1100R '65 R50/2 '64 R50/2 '07 BMW 530i6 ED
Old 12-24-2009, 09:24 AM
I tried that but it still stalls after a couple seconds at idle.
Old 01-04-2010, 08:21 AM
mlinkibikr mlinkibikr is offline
On the Road!
Mein Auto: 335 E90
BMWs have a reset procedure after removing the battery. On my bike it involves switching on the ignition and then twisting the accelerator to full on and off three times.
I can't imagine any permanent damage could have been done. You could contact Two Brothers if the reset doesn't work and see what they say. Not sure if there are any servos / flaps in the system you bought or not. You say the bike won't idle - will it run under higher revs? Could the pipe be clogged up with something?
Dave.
E90 335i 6 Speed MT
Alpine White, Terra, Aluminum trim
Premium, Sport
HTML code is Off
