Old 12-21-2009, 01:58 PM
tjh54 tjh54 is offline
Mein Auto: bmw 2001 z3
2001 z3 heater problem
I had some water damage from rain water soaking the floorboard (about 1/2 inch deep) causing the airbag and dsc light to be on. The shop told me that the computer is not working and this is causing my heater not to function .Could this really be the cause?
Old 12-21-2009, 02:53 PM
wildag's Avatar
wildag wildag is offline
///M 'n it up!
Send a message via AIM to wildag
Mein Auto: '06 Z4 M Roadster
The Z3's heater is completely manually controlled, as far as I know.
The fan speed selection is done electronically through a computer. The selection of heat, and vent combination is done through manual tension wires.
A the temperature selection knob breaking is a common failure in the Z3. If the temperature selection knob doesn't move at all, or moves very easily, its likely that the arm behind it has snapped, or the tension wire is caught.
DreamingWell.com Web Services
Old 12-22-2009, 08:06 AM
Thanks wildag the fan is blowing cold air and I have the temp set to high. It looks like I need to find a new mechanic or do it myself.
Old 12-22-2009, 08:26 AM
Mpire's Avatar
Mpire Mpire is offline
The Anti-Rice
Send a message via AIM to Mpire Send a message via MSN to Mpire Send a message via Yahoo to Mpire
Mein Auto: S54 M Coupe x2, M52 Z3
I am about to attempt this very repair. I will take pictures.
2001 Alpine / Schwartz Coupe
2001 Estoril / Estoril Coupe
2001 Steel Grey / Estoril Coupe
1999 Estoril / Estoril Coupe
Sunroofs are for girls.
Old 12-22-2009, 08:43 AM
Thanks Mpire, that would be a great help.
Old 12-22-2009, 09:36 AM
wildag's Avatar
///M 'n it up!
If no hot air is coming out of the vents, its one of these things:
1) The heater core is broken
2) The door that switches between hot and cold air is stuck
3) The tension wire has come loose of the door, or at the control knob end
4) The knob that pulls the tension wire is broken
Number 4 and 3 are most likely. Three happens a lot, and four is easily noticeable as stated in my post above.
You can access the HVAC control knobs by removing the stereo. Search this forum for those instructions. The HVAC controls pop back into the console. You can twist them away from you to see the tension wires on the bottom. Takes small hands and a lot of patience, but you can do it.
Old 12-23-2009, 09:45 AM
Thanks again Wildag I will give that a try.
2001 3.0 liter, computer, heater, z3
