E90/E91/E92/E93 (2006 - 2013)
TPMS Valve Stem Caps - Warning!
If your car has TPMS, and they all do since 2005, don't put aftermarket metal valve caps on the stems!
The stems require silver colored plastic caps, or nickel plated metal caps. If you use chrome plated caps, or metal caps made the old way then you may be in for a big surprise. I had to tow in a car today which the customer put metal replacement caps on two years ago. When he tried to remove the metal cap the valve stem snapped off, the core popped out and the tire deflated before his shocked eyes. We tried every trick we know to get the other three caps off. We couldn't, they had become one with the valve stem. All four TPM sensors had to be replaced. What is happening is that road salt is getting between the components and causing corrosion to accelerate. Eventually corrosion eats right thru the stem greatly weakening it. Although I've read about this problem for a while in the trade mags, this is the first time I have personally encountered it. So, a special advisory to you snow belt 'Festers; don't use those fancy looking aftermarket metal caps. You could get a rude shock one day when you go to add air to a low tire.
I rarely drive in road salt. I had to take the car out yesterday and when I got home it was dirtier than it has never been. It was washed as soon as I got back to the garage and is now happily sleeping under its cover. CA
Drivers Club at Lime Rock The Glen Club International Motor Racing Research Center BMWCCA Cayman Club Nor'Easters Madison Ave. Sports Car Driving and Chowder Society (Only a Vice President) Sports Car Club of America Polish Racing Drivers of America (PRDA) American Mural Project Last edited by captainaudio; 12-22-2009 at 10:19 AM. |
Galvanic Reaction. Years ago I was installing the sprinkler system in a Post Office. When it came time for the punch list corrections, one item on the list was a 1/2" brass nipple in the otherwise galvanized piping for the alarm valve. Shaking my head in disbelief, I approached the inspector (Lieutenant, Army Corp of Engineers, newbie) and asked about it. He says that the brass nipple has to be removed due to possible galvanic reaction. I started laughing and pointed out that EVERY valve (drain valve, inspectors test, check valve..) in the system is brass and oh yeah, what about ALL the sprinkler heads, they are brass, what are we gonna do with them? He agreed and the nipple remained. Bottom line, No Electrolytes (salts), No Corrosion, at least in sprinkler systems.
dj
'08 535i Deep Sea Blue Cream Beige Dark Poplar 6 Sp Manual Sport Premium Rear Shades BMW CCA #392316 |
Isn't it all one piece?
![]() dj
No, they're Beru's as suggested by Orient, above, but I didn't want to go into too much detail. Beru makes a two piece unit and the stem can be purchased separately. Only Beru makes them this way.
Captain/DSX,
Please clarify re: "aftermarket valve caps". Are these one and the same as the caps sold under the P/N 36 11 0 009 840 that are available from BMWUSA?
If your sport doesn't put blood, dirt or grease under your fingernails, then it's just a game. Euro Modded|Split Armrest|Rear Foglight Mod|CDV Delete|Shark Fin Antennae Delete|Front Reflector Delete|LUX H8 Angel Eyes|No Bells|Few Whistles|Das Fahren im Freien| BMWCCA#445793
![]() Also presumable you check your tire pressure more often than every 2 years. ![]() dj
Our Acura MDX (and my dad's Honda Rdigeline)--both with TPMS--had a safety recall for this exact issue. The vehicles came with metal caps standard, and Honda just mailed out four replacement gray plastic caps to every registered owner on file, with the instructions to swap them out.
It does not take 2 years for galvanic corrosion to wipe out your valve stems. My MDX valve stems froze to the metal caps in one summer stored in my garage basement. The tire pressure checks you all seem so fond of making your selves are not necessary in the MDX because the TPMS reads out in PSI so you can check your pressure any time (and watch them change as the sun hits the tires on a freeway good for 1-2 PSI depending upon the season). So when I put my tires on in the fall, all 4 stems were frozen, and I don't carry Vaseline or any anti-seize for my schrader valve stem caps so don't even start with that.
Cost the boys at TireRack 4 TPMS, mount and dismount, plus my friendly face in their office for an hour! BTW, who checks air pressure every month? Do you all have leaky valve stems? Tires hold air, then they go flat, why check them all the time? My BMW tires hold air, all the time, every day, it's weird, but I think tires are supposed to hold air.
ED LeMans Fathers Day |
So tires have two states, full and flat?
Drivers Club at Lime Rock The Glen Club International Motor Racing Research Center BMWCCA Cayman Club Nor'Easters Madison Ave. Sports Car Driving and Chowder Society (Only a Vice President) Sports Car Club of America Polish Racing Drivers of America (PRDA) American Mural Project |
![]() dj
![]() dj
08 E90M3 6MT Alpinweiss/Schwartz |
And yes, I am pretty good about checking my tire pressures on a regular basis.
but you never know. They are not heavy I wouldn't think.
[Is that the Alps with the Matterhorn in your sig pic? Trying to outdo me?] Last edited by DSXMachina; 12-22-2009 at 03:19 PM. |
[Yes -- you guessed my sig pic. Not trying to outdo you, just trying to find something appropriately snowy so as to not get you too frustrated. (lurid (Picture was actually 4 panoramics taken with a 35 mm film camera from Gornergratt -I love Photoshop!)]
[This sig pic was taken from my hotel room in Anchorage, at sunset across Turnagain Arm. It was cropped from a larger pic but otherwise it is as taken. I may have pushed the exposure a little to bring up the water though.]
Yes, the refineries/chemical plants definitely have an effect. I'm lucky, being about 45-50 miles away from the Ship Channel, but 'minor' chemical releases at refineries and plants aren't uncommon, and even at ppm levels in the air, things like H2S can eventually eat into finishes. Our Canadian brethren were kind of razzing me about my obsession with waxing etc., but our air quality, combined with the brutal heat in the summer, can over the long haul be every bit as damaging as the salt/sand the northern climates have to endure during the winter months.
'Last time I stopped by the dealer, they were still selling both sets of caps: metal and plastic. They look the same, but the plastic ones, of course, feel much lighter and won't cause a problem.
To get the corrosion you need metals that are rather far apart on the galvanic series (http://en.wikipedia.org/wiki/Galvanic_series) and water. Pure water is a lousy electrolyte. Dissolve a salt in it, and you're good to go. But there are plenty of other impurities that can make water a better conductor and accelerate corrosion. So... even if you're in an area that never salts the roads (lucky you), I'd still be wary about the whole valve cover thing. And, btw, I had a flat recently. The RFT didn't look flat at all (naturally). Really. How hard is it to check tire pressures?
'09 328i Coupe: MT, Monaco Blue, Black Dakota, Dark Burl, ZPP, ZSP, ZCW, CA, Logic7, HD Radio, IPod Ordered: 14Jan09; Delivered: 24Feb09 from Stratham, NH BMW |
Now that I am aware of this issue I immediately went down to the garage and removed the fancy metal BMW logo caps and replaced them with the original cheap plastic ones.
The results were instantaneous and spectacular. My migrane headache went away, my acne cleared up, the interest rate on my IRA doubled and I won $500 in the New York State Lottery. This was particularly amazing since I hadn't even purchased a ticket. CA
Drivers Club at Lime Rock The Glen Club International Motor Racing Research Center BMWCCA Cayman Club Nor'Easters Madison Ave. Sports Car Driving and Chowder Society (Only a Vice President) Sports Car Club of America Polish Racing Drivers of America (PRDA) American Mural Project Last edited by captainaudio; 12-22-2009 at 07:42 PM. |
#25
Professor Cook,
On another topic (sorry) - where did you get the bra for your car? I've ordered a 328 coupe, and want to put a bra on it at the dealers when it comes in. I have a 30 mile freeway trip home. Thanks |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
