E46 (1999 - 2006)
Old 12-22-2009, 06:49 PM
Fher 323i's Avatar
Fher 323i Fher 323i is offline
BMW is my lifestyle!!!
Mein Auto: BMW E46 1999 323i
Power mirror switch burn!!!Help
Hi, today i notice that my mirror not workc, so i check the fuses and find the mirror fuse blown(32 or 31 i think), i install a new one and my switch on the driver door star to blown smoke and ten seconds later the fuse blown again. In the afternoon i run some test to find the problem. Without the switch the fuse NO blown, i check the cable and foun one positive and one ground the others 7 or 8 cables not have nothing. Then i open the switch and found that is cooked medium well, so i remove the plastic cover and clean it , the conect the little board without the butoms and the fuse not blow.I know that i need to buy a new switch, but you think yhe problem is the switch or is another issue.The switch is about $65.00 damn!!!, mine is the one with two plugs, any help please
Old 12-22-2009, 06:57 PM
Fher 323i's Avatar
Is the part #1 (61318373691)
Old 12-22-2009, 07:08 PM
djfitter's Avatar
djfitter djfitter is offline
Mein Auto: BMW '08 535i
Hang in there somebody will help you. Sometimes it takes a little while for the one with the answer to read the post.
dj
'08 535i
Deep Sea Blue
Cream Beige
Dark Poplar
6 Sp Manual
Sport
Premium
Rear Shades
BMW CCA #392316
Old 01-08-2011, 06:14 PM
jay786 jay786 is offline
Mein Auto: BMW 318i SE
Smile
Hi there,
I have the same problem, did u resolve it.
Is the switch faulty or is it something else.
Old 09-08-2011, 12:19 PM
umermariner umermariner is offline
Mein Auto: 2000 (E46 )328I
Similar problem... switch started smoking and blew up.. want to make sure everything else is correct, before sacrificing a new switch .. did you find anything?
Thanks.
Old 02-14-2012, 06:14 PM
chase'sbmw chase'sbmw is offline
Mein Auto: 2001 bmw e46 330i
ya i have the same prob i have the 2 plug one did the same thing i got a new switch i worked fine then like ten seconds poof theres smoke so its not the switch im going to pull the door panle and look for shorts and check the wires
Old 01-25-2017, 09:45 AM
nuke21 nuke21 is offline
Mein Auto: 1998 328I
Exact same thing happened to me. If there was someone that had a schematic of how it is wired and if the wires go to the mirror directly or a model etc. I could take it apart and see what is doing it.
1998 Navy Blue BMW 328i
2009.5 Liquid Red G8 GXP
Old 01-26-2017, 06:18 AM
marcozandrini marcozandrini is offline
Mein Auto:
Obviously there's a short in the mirror system. I'd pull both door cards (interior panels) to see what's shorted or grounded. Be advised that the passenger mirror signals go through the driver mirror controls.
