Reference: N62 engine firing order - Bimmerfest - BMW Forums
Old 12-23-2009, 02:32 PM
Keif Keif is offline
Master Tinkerer
Mein Auto: 2007 Alpina B7
Firing order for a N62 engine (4.4L) --> here.
(used in the E65/745i and E66/745Li, as well as others)
Not sure if the later years differ, but this is for a 2002.
Black 2007 Alpina B7
Tension strut bushings
White 2007 Alpina B7
Supercharger clutch/bearings, replaced exhaust valve/pulled head, sunroof seal, 6000K angel eyes
Black 2002 BMW 745Li (sold)
KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator & mounting bracket gasket, sunroof seal, CCVs, plugs, sway bar bushings, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, sanded headlights...
Old 12-23-2009, 09:13 PM
wilson009's Avatar
wilson009 wilson009 is offline
Mein Auto: 2002 745i 116k
Thanks keif!
Old 03-25-2011, 07:04 PM
Hpiracer Hpiracer is offline
Mein Auto: 2003 745Li
keif is a lifesaver!
Old 03-26-2011, 04:37 AM
Lastcombo's Avatar
Lastcombo Lastcombo is offline
Mein Auto: BMW745I E65 ,BMW318 IS 94
Sticky pls
Bayerische Motoren Werke
Old 03-02-2014, 04:43 PM
kief2007 kief2007 is offline
Mein Auto: 04 745Li
P1347
I had a problem with code: P1347, I changed all the spark plugs and my car was still running rough. I ran the diagnosis again and I was still coming up with the same code. I started searching on the web, and found P1347 refers to cylinder 3, so I changed the ignition coil (only that one) and the car runs great now.
PS cylinder 3 is located on the passenger side, second from the rear going towards the headlights. Hope this helps.....
I have a 2004 745Li
Old 03-02-2014, 06:28 PM
fratan fratan is offline
Mein Auto: 2006 750i
Glad you could find it on the web but most all the regulars have the list of every BMW code that exists. That being said you were 100% correct.
2006 750 I
engine, firing, n62, order
