E36 (1991 - 1999)
Old 10-11-2011, 12:01 PM
Poorboysracing's Avatar
Poorboysracing Poorboysracing is offline
I <3 Underpowered BMW's
Send a message via AIM to Poorboysracing
Mein Auto: '00 BMW 528i '68 BMW 1600
I say buy it matt, theres alot of possibillities there, if it was local to me i'd snatch it up and lola would be a bit quicker
*The I Drove to Both East and West Coast Bimmerfest Club* Member #1
Old 10-11-2011, 12:43 PM
FenderBender's Avatar
FenderBender FenderBender is online now
Needs Boost
Mein Auto: Red Sled
Gonna have to wait to look at it until I get back from Louisiana next week.
Emailed some peeps about E30s as well.
Turbo Build Here
Parting Out Complete 96 328is
Old 10-11-2011, 01:29 PM
E30 FTW
they make great beaters
cant wait until spring, gonna make mine all nice and pretty again
Old 10-11-2011, 02:13 PM
Ryan...'s Avatar
Ryan... Ryan... is offline
Please, call me Brian.
Mein Auto: 02 WRX
Hey Matt, what gauges are you running in your car? I've already got a boost and wideband in mine, but I need 3 more to occupy another gauge cluster I'm buying..
I'm thinking oil temp, oil pressure, and water temp? I found those 3 gauges for like $60 on ebay..
Old 10-11-2011, 03:47 PM
Needs Boost
Mein Auto: Red Sled
Yea I want a daily E30 with an M50 in its future.
Ryan, I've got Prosport electric gauges.
Boost
Oil pressure
Fuel pressure
A/F
Water temp
I would like to add oil temp to mine.
Sent from my ADR6400L using Bimmer
Turbo Build Here
Old 10-25-2011, 04:04 AM
Kdoherty's Avatar
Kdoherty Kdoherty is online now
bimmerfest Supporting Member
Mein Auto: 1996 328i
Hey matt, do you think running the turbo top mounted would save me from having to run the charge pipe under the subframe and from having to dick around with the AC? I'm looking at these Ebay kits and it looks like i could just flip the manifold over and mount the turbo top right front. I'd probably move the coolant res, but anyways. You think that's doable? I've seen it done on E36's I just don't know much about that method.
insert witty signature quote
Old 10-25-2011, 05:44 AM
Needs Boost
Mein Auto: Red Sled
I plan on going top mount, but a couple of issues.
You want an Ebay kit?
What manifold?
You can't flip the manifold, it would require modification.
Bottom mount you don't have to mess with AC at all and running under the subframe isn't a big deal, I have yet to scrape it. However you need to modify your motor mount arm or buy a different one.
Top mount you will have to move the two hard AC lines and the expansion tank.
Turbo Build Here
Old 10-25-2011, 05:48 AM
Kdoherty's Avatar
http://www.ebay.com/itm/BMW-E36-6CYL...ht_6600wt_1270
this is the one I'm looking at. It appears to pretty comprehensive. I'm wary of the "oil filter relocator" what all did you do to the motor mount arm? I don't have a lift or any cool stuff so if it goes down, it's going down at ground level.
Old 10-25-2011, 07:13 AM
Needs Boost
Mein Auto: Red Sled
I wouldn't get any of that Lol. That manifold will crack, and the turbo will blow up.
Get it piece by piece. A nice turbo. What are your power goals? Top mount or bottom? Stock HG?
Turbo Build Here
Old 10-25-2011, 07:20 AM
Kdoherty's Avatar
welp, to be honest, I don't have power goals.(flame suit) I just want to run enough boost to not grenade my engine. I like the bottom mount because of how out of the way it is, but top mount seems easier for maintenance and such. stock HG for sure. I don't have the facility or proper equipment to break the motor down in my garage.
Old 10-25-2011, 08:01 AM
Mr Gusta's Avatar
Mr Gusta Mr Gusta is offline
Fireballs inc.
Send a message via AIM to Mr Gusta
Mein Auto: 11:1 hx40 s50b28 sedan
if your running pump gas no meth 14-15 psi will blow that headgasket....
but if you had an mls headgasket and a big turbo there was a 328 that went 711whp and developed rod knock
Turbo lag is actually a headstart to make it fair
Old 10-25-2011, 08:09 AM
Kdoherty's Avatar
I think anything over 10 PSI on a street driven non tracked car with stock internals is a bit much.I'd probably set mine for 8 and call it a day. specially with the cams and such I've got.
Old 10-25-2011, 08:12 AM
Mr Gusta's Avatar
Fireballs inc.
If you lurk a bit in the fi section on bimmerofrums you will learn alot
a freind of mine who tunes for ics now has a 93 325 with an m52 and just a mls headgasket with arp studs and that car makes 515whp daily driven and beat on every day the m52 can take it believe that
Old 10-25-2011, 08:14 AM
Kdoherty's Avatar
geez, sounds exciting.
Old 10-25-2011, 09:10 AM
Needs Boost
Mein Auto: Red Sled
Frank you know Jordan??
Anywho it's like i told Chad, if you keep the stock gasket, switch to ARP studs. You can do so one at a time.
Give us a power goal, that determines everything. Top or bottom mount are about the same in terms of difficulty. 300whp?
Turbo Build Here
Old 10-25-2011, 09:13 AM
Mr Gusta's Avatar
Fireballs inc.
Yea man he's a good freind of mine he brought me the rear trailing ARM when ny car was stuck on the side of the highway overnight, he's a good guy and smart when it comes to boost.
His green car is a testament to reliability on a stock motor with mls and the right tuning
Kdoherty's Avatar
300 sounds like a nice ballpark, given existing mods so far, are the cams, the shark tune, cat back, flywheel clutch, fan delete. 350 wouldnt be to lofty to aspire for.
Old 10-25-2011, 11:47 AM
Needs Boost
Mein Auto: Red Sled
Nice. Thats awesome man. He is right there to tune your car.
Alright Ken, so 350whp is your goal.
Get ARP2000 studs.
Buy a turbo around the size of a GT30.
Tuning?
Top or bottom mount?
Buy 42lb injectors.
Turbo Build Here
Old 10-25-2011, 11:51 AM
Mr Gusta's Avatar
Fireballs inc.
he could stay on stock head bolts and gasket if he runs e85
Old 10-25-2011, 12:42 PM
Needs Boost
Mein Auto: Red Sled
Almost no one tunes for E85 right now, even then the stock bolts don't hold up to much.
Turbo Build Here
Old 10-26-2011, 04:11 PM
Needs Boost
Mein Auto: Red Sled
Got the bushings out, and sandblasted.
Welding in the sway bar reinforcements tomorrow, as well as welding up all the seams.
Turbo Build Here
Old 10-26-2011, 04:16 PM
ZeGerman's Avatar
ZeGerman ZeGerman is online now
Warm Leatherette
Mein Auto: 1998 BMW 328is
Lookin' good, Matt. Take photos of your welding.
1998 BMW 328is
1966 Pontiac GTO
Old 10-26-2011, 04:24 PM
Needs Boost
Mein Auto: Red Sled
Ehhh, ok
I don't have a lot of experience in welding, so we'll see how it goes.
Turbo Build Here
Old 10-26-2011, 04:32 PM
ZeGerman's Avatar
Warm Leatherette
Yeah, I was going to say, no pressure...
Better not look like popcorn.
1998 BMW 328is
1966 Pontiac GTO
Old 10-26-2011, 05:15 PM
Needs Boost
Mein Auto: Red Sled
In other news, going to pick up an oven tomorrow, then my powder gun will be on order.
Karl, what LCA bushings are you running?
Turbo Build Here
:3
